Question about Dryers
I changed the thermal cutoff. it dried one load and then wouldnt heat again
  • 58 Answers
Check the thermo again, it might be going out due to a short in the element, or obstructed venting causing too much heat, clear venting or replace therm/heating element if needed.
Posted on Jul 01, 2009
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
I just changed the heating element and thermal cutoff fuse. after putting everything back and turning power on, the clean light blinks 7 times. i am not able to reset control board using the reset...
the thermostat is shorted out, You need to change that and the run diagnostic to clear the code which is high temp ,heated dry, high temp ,heated dry, high temp heated dry key dance and let it do its thing. When it is done you should have no more problems. If you change the thermostat. Usually locate near the front under the near the electrical box but not always.
Mar 14, 2015 | Kenmore Dishwashers
Dryer tumbles, no heat, thermo fuse has been changed. Can it be the cycling thermostat or the heating element?
If you have changed the thermal fuse you may have a defective thermal cutoff (located at the top of the heater housing in the back). The thermal cutoff will come with the high limit thermostat located at the bottom of the heater and you should change both parts if the thermal cutoff is bad.
You can take both of the parts (the heater and the thermal cutoff) to a parts supplier to have them checked for continuity (they should both read "closed" if they are good).
Good luck to you!
Oct 07, 2010 | Whirlpool WED5300S Electric Dryer
Dryer wouldn't work last week. Found the Thermal Fuse with no continuity and replaced it. After drying one load of clothes yesterday, dryer won't work again. I suspect the thermal fuse again. What else ...
Or your breaker. The dryer will work just won't heat with the thermal cutoffs or element or the breaker. Dryer won't do anything if the thermal fuse is bad. You might also want to check the outlet from L1 to N and L2 to N for 110 on each side. Good luck.
Aug 22, 2010 | Whirlpool Dryers
I replace the thermal cutoff kit and the dryer worked just fine for about a week. Started the dryer and did dry for a while, then stopped turning in the middle of drying a load. I hear a tick sound. I...
You say you change the kit must be an electric dryer. Did you replace the whole kit you must replace the thermal cutoff and the high limiter both they come in the kit You may check the other fuse its just above you thermostadt on the other side of the dryer on the back about 2" long all white and plastic.
Apr 21, 2010 | Dryers
Dryer shuts off before load is dry. it will not turn back on for about a half an hour. is this an easy fix?
Yes it is. It is more than likely your high limit thermostat. The high limit thermostat is located on the back of the dryer after the heating element, (right before the entrance into the drying chamber). They high limit and thermal cutoff usually come as a kit because they should be replaced at the same time. The thermal cutoff is located on or around the body of the heating element. good luck!
Apr 06, 2010 | Dryers
Clothes dryer not heating
I eventually changed the thermal cutoff switch and the high limit thermostat as suggested in one of your replies to another consumer and now the dryer is working fine. Thanks.
Nov 13, 2008 | Zanussi TC7114W Electric Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
