Question about LG Refrigerators
Temperature problems with LRBC 22544ST - our freezer gets iced up and then the refrigerator does not get cold enough. I just found a lot of accumulated water below the bottom drawers in the refrigerator. Not sure if that is related.
catriver
  • 878 Answers
SOURCE: Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Posted on Sep 04, 2006
SOURCE: Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
______________________________
http://www.SubZeroLosAngeles.com
Posted on Nov 12, 2008
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    Sea Breeze
    • 4655 Answers
    SOURCE: Water is accumulating in bottom of fridge under produce drawers
    Possibly your defrost drain found inside the freezer back wall is blocked. If you could send me the model number I could help you better. Thanks, Sea Breeze
    Look at following areas for the model number
    • Beneath Or Inside Food Compartment On Cabinet Frame
    • On Plate Lower Front Or Rear Of Cabinet
    • Beside Compressor Door On Right End
    • Near Rear Of Cabinet
    • Inside Liner At Top
    Posted on Mar 28, 2009
    • 291 Answers
    SOURCE: Maytag freezer & refrigerator not coold enough
    It's not cool If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
    First, answer these questions:
    • Is the refrigerator completely dead? If so, see “It's stopped completely.”
    • Is the thermostat knob turned to the proper setting? If not, reset it.
    Next, see if the compressor motor is running
    The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
    • The compressor
    • The Thermostat
    • The overload, relay, or capacitor
    • The defrost timer
    • The condenser fan motor
    Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
    Evaporator coils
    Condenser
    Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
    Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
    The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
    Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
    • The defrost timer
    • The defrost thermostat (also called the bi-metal switch)
    • The defrost heater
    If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
    Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator. I feel heat/warmth on the front edge of my refrigerator....why?
    Older refrigerators had electric heaters on the edges of the refrigerator cabinet to help prevent moisture from building up, especially in the hot/hazy weather in the summer time. These electric heaters usually had a switch where you could turn them on or off...had words like..."switch here to prevent moisture"...switch here in damp weather".... in the picture it is in the top left of the control assembly.
    Then along came the energy crunch. The manufactures stopped using the electric heaters and started running a pass of the hot condenser tubing on the edges of the cabinet where the electric heaters use to be. This is often called ayoder loop tube SxS version and the yoder loop tube Top freezer version. This has now replaced the electric heaters. If you feel heat/hot around the door opening of your refrigerator you should....
    clean the condenser coils as a dirty condenser can make the tubing hotter than normal
    - check/clean & replace if necessary the condenser cooling fan   ( # F ) motor, if the condenser fan motor is slow or has quit the yoder loop pass will get very warm/hot to the touch
    - If the condenser coils are clean and the condenser fan motor is running ok, check the fresh food and freezer section temperatures...if the refrigerator is not operating well and the temps inside are warming up, you could feel more heat/warmth than normal
    Posted on Apr 03, 2009
    I just replaced my automatic ice maker in my Samsung french door refrigerator. Now the temperature is not cold enough to freeze the water which leaves the ice bucket with water not ice. Freezer works
    Repair for a Freezer That Is Running But Not Freezing ...
    homeguides.sfgate.com > ... > Other Types of Mortgages
    This is the heat you feel blowing near the freezer when it's in a cooling cycle. ... Also, using a freezer to cool hot items or opening the freezer frequently will ... If you noticewater pooling on the floor when the freezer is running but not freezing, ...
    Why Is My Freezer Not Cold Enough? - Articles - Networx
    www.networx.com > ... > Electrical > Appliance Repair > Read Article
    Sep 1, 2011 - Next, make sure the freezer isn't overloaded and that the evaporator fan ... are choked with frost, restricting the airflow that makes the freezer cold. ... In verycold weather, a freezer in the garage may heat up, since there isn't enough warm ...unit (even on automatic-defrost units, in case there's a lot of water).
    refrigerator - Freezer is cold but not freezing at all - Home ...
    Dec 20, 2015 | Refrigerators
    I have a 2yr. old Maytag Frig.,freezer on top.I cannot get a stable freezing temp. I can set, with the setting control, readings of 4 or 7 with no effect on the actual temp. I bought a freezer thermometer...
    If the refrigerator is not cold enough then please check the following and also click on the blue coloured links for more info.
    How To Check the Temperature1x1.gif In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
    Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
    The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
    Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
    Goodluck,
    Please don't forget to rate the solution.
    Mar 27, 2008 | Refrigerators
    Why doesnt the refrigerator and freezer not get cold enough?
    You need to check a few things -
    1. settings for the temperature are not set too low. Not cold enough.
    2 there is no leakage through the door seals.
    3. there is not too much ice formed inside the freezer walls. Needs defrost.
    4. the fridge is not overloaded with stuff - not enough capacity to cool things.
    5. Not enough free space behind the fridge to allow air movement for coils to cool
    Please provide more details of the problem if above not helping. For example model number, is the problem happening both in freezer and refrigerator settings. Get a fridge thermometer and monitor temperature in both sections. should be 4 deg C in fridge and -18 deg C in freezer after stable operation.
    Apr 23, 2014 | GE Refrigerators
    Freezer side not cold enough, similar temperature as Refrigerator side
    It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
    Nov 12, 2013 | Refrigerators
    Ice in freezer, on back wall, but products defrosting
    Temperature Sensor in some models is located badly. You need to defrost the whole fridge by powering off then. The sensor will work again. We found this occurring because we'd go on long holidays.
    Nov 14, 2017 | LG LRTBC1825T Top Freezer Refrigerator
    Ge refrigerator is not cold enough and ice is not working
    What is the model number?
    The ice maker will only run if the freezer is at the correct temperature.
    Do you see any ice buildup on the back wall of the freezer or behind it?
    Nov 27, 2012 | Refrigerators
    MAKING ICE TOO SLOW
    A lot of times, the reason ice production slows down is because the freezer isn't cold enough, usually because the freon level of the machine is low. Sounds weird, but even though the freezer is below 32 degrees F, which is freezing, the ice maker requires the temperature be below 10 to function properly. Another cause for the temperature not being cold enough is if the coils are dirty and ther machine is passing the heat to the machine itself
    May 30, 2012 | Maytag MBF2556HEW / MBF2556HEB /...
    I have a Roper RT21LMXKQ00 Freezer wont freeze
    The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
    Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
    MY FREEZER IS GETTING TOO COLD AND THE FRIDGE IS NOT GETTING COLD AT ALL
    Oct 08, 2008 | Whirlpool Refrigerators
    Freezer not cold enough; fridge OK
    Hello cokoliso,
    Welcome to Fixya
    You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
    To check the temperature you can buy a refrigerator thermometer at the hardware store.
    Ask if it can be used in the freezer too!
    The fridge sounds slightly to cold and the freezer not enough.
    Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
    Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
    If freezer was not I blocking the vents or even full to the max.
    Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
    Let me know how it goes and send me any questions.
    Thank You, Huuum
    Please remember to leave a rating .
    Oct 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
    Refrigerators Logo
    Top LG Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a LG Refrigerator Expert? Answer questions, earn points and help others
