Question about Mitsubishi VS-50707 50" Rear Projection Television
Mitsubishi VS-50707 - Scrambled picture
After I turn my TV on, the picture is scrambled/wavy and then in about 15 minutes the picture is normal. It couldn't possibly be warming up . . . could it?
  • 2 more comments
  • Fr33dom7 Dec 15, 2007
    picture is intially scrambled, like a horizontal hold problem. after a few minutes it unscrambles, but vertical columns can be seen in the picture if the background is dark. the problem on my tv has now escalated to where it turns itself off as soon as i turn it on.
  • jholts Mar 09, 2008
    When the tv is first turn on there are vertical lines in the picture after 10 hours they slowly disappear with on on other issues what could this be. Thanks
  • Ringo2321 Apr 07, 2008
    I might be more patient than most. I first began to have this problem several months ago. I turn the tv on and it flickers and is wavy for a while before eventually calming down and becoming normal. But recently it has started to take longer and longer to get to the normal stage and now it is pretty much wavy all the time. HELP!
  • Anonymous Apr 10, 2008
    My 1993 Mitsubishi VX-50VA Projection TV scrolls.  Sometimes it stabilizes, but mostly not.  It does this with the DVD player and antennae.  We got it from a friend and don't know how long it has been doing this.  Any suggestions?
  • 4,402 Answers
On the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Posted on Dec 15, 2007
I have a Mitsubishi VS-55707 and I have a couple of problems. first it takes 5-10 minutes to warm up (scrambled picture) after that it works fine, but its getting longer to warm up. Second every once in...
i had the same problem. im sorry to say that you are out of luck and you tv is on the way out. i had the same problem and spend $100's of dollars to have people come and try and fix it to no luck. sorry
May 23, 2010 | Mitsubishi VS-55707 TV
Wavy line or scrambled picture when l turn the tv on it takes 30mins for the picture to come in clear
If you have a normal picture with lines through it, or if the picture jumps, tears or rolls, you have a Hyper Board that is failing. The last I checked, the Hyper Board is not available from Toshiba and has not been available for a number of years.
I hope this helps,
Feb 07, 2010 | Toshiba 50H82 50" Rear Projection...
Picture colors scrambled
Ur convergence it dead,Know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair,Tv Repair Kits.
Dec 12, 2009 | Toshiba 57H82 57" Rear Projection...
The picture is scrambled from start and never gets normal
You have numerous Surface mounted capacitors to replace in you PIP module. This is not and easy repair for the average person to attempt. The module is No Longer Available so we repair the original.
Jul 11, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Scrambled picture mitsubishi VS-60805
Hello deltamech,
Are you using your component video cables? if you are check to see if you are using the correct inputs. Look at the babck of your TV and see if the RGB (Lettering) matches with the box you are connecting to. What I am talking about is the YP(b)P(r) vs the YC(b)C(r) they are incompatable with each other.
Check that and if that is the case either match the two proper RGBs up or use another interface.
I hope this helps,
Thank you,
Jan 25, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Mitsubishi VS-50707
Click here to get more info on the subject and also check the other links in that post.
Good Luck.
Apr 29, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi vs 50707 50 inch projection tv problem
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Dec 15, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 50" Rear Projection Television Logo
452 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
