Question about Lands Phones
Magic jack beeping sound heard by receivers of my calls
  • 11,896 Answers
You will experience lots of sounds with magic jack, sometimes beeping, sometimes crackling, sometimes it cuts out. They are not reliable. I gave mine up.
Posted on Jun 30, 2009
I moved. magic jack says no line when hooked back up
  • Is everything turned on?
  • Is the blue light, inside your Magic Jack dongle, on? (Note that the Magic Jack Plus should have a flashing red and green led as well.) If you use the older model you might need to connect it through a powered hub to ensure the device receives enough power to operate properly?
  • If this is a new installation, is your internet service and computer capable of handling the requirements placed upon them by Magic Jack?
  • Do all your connecting cables appear to be firmly attached?
  • Are you watching Netflix, downloading or streaming files at the same time you are attempting to place a call?
  • If you are using the Magic Jack Plus, does the system report Error 3002?
Next, you should ask yourself what recent changes you have made to the computer/Magic Jack software? What recent upgrades have you performed to your hardware? Could this have effected the performance of your Magic Jack?
If your difficulties persist, it is time to divide and conquer. Google a 'you tube' link and watch the video. If you cannot connect to the internet, consult your internet provider for assistance. If the video is choppy, the internet connection might be too slow or bogged down. Perhaps your computer is too slow or requires maintenance. If you cannot hear sound, you might be experiencing problems with your soundcard or sound drivers. You should check Control Panel/Sound and ensure that 'USB internet phone by Tigerjet' is installed.
If the video ran correctly, the next step would be to test your handset and phone cord at another location.
If you prove the handset/phone cord to be correct, you have pinpointed your fault to either the Magic Jack or its software. Contact online support for Magic Jack.
Oct 11, 2014 | magicJack Plus Pc To Phone Adapter
I bought a magic jack plus my old magic jack broke I pluged the new one all my contacts came back but I can only receive calls but I can not call out
Lets try this. When you installed your new magic jack, did you install the new software from the website, or did you just plug it in and go "HEY all my peeps are here. We are done?" Install the new software from magic jacks site and if you did this then and it still doesn't work, then i am out of ideas for this one. Only other thing i can think off is in your settings and you have it on incoming calls only.
Mar 15, 2014 | magicJack Plus Pc To Phone Adapter
My magic jack do not work , I can not call out and can not get call .
Try uninstalling and reinstalling the magic jack software.
Note: The magicjack software needs to be running in order to receive and make calls.
Jan 25, 2014 | Computers & Internet
Magicjack problems
Try another telephone as the magic jack device only provides a certain level of voltage output which does not supply enough power for a dial tone and power to older telephones. There are work arounds provided within the magic jack forum blogs which can be found by visiting this website, found on google.
Dec 22, 2013 | magicJack New & Improved 2012 Plus Free...
Magic jack contact number
Contact MagicJack: http://www.magicjack.com/plus-v05/customercare.html
Nov 11, 2013 | Computers & Internet
Calls cutting out with magic jack
Your ISP connection speed may be inadequate. Typically, the upload speed (outgoing voice) is much slower than the incoming speed. To check majicjack recommends that you test your system on http://www.speakeasy.net/speedtest/ .
It's also possible that your internet provider is purposely delaying the outgoing latency in order to discourage VoIP that THEY don't provide. I think this is (or at least should be illegal) but in any case a complaint to the FCC might be in order.
Aug 23, 2009 | Computers & Internet
Magic Jack- Other person hears beeping every few seconds
You can use Magic Jack customer care at http://www.magicjack.com/2/customercare.asp
I talked to 3 operators. The long and the short of it is that they had me:
1. remove a Majic Jack related folder from an applications folder
2. insert MJ1 and MJ2 in the Windows Firewall exceptions
3. format the Majic Jack software "drive"....and then install an upgrade.
Based on this, I think the problem crops up in the Majic Jack software. So far, it has fixed my problem, though I've not made a long call yet.
I found the Majic Jack operators very helpful. Be sure to have them step you through this.
Good Luck!
Amy
Jun 17, 2009 | Computers & Internet
MagicJack VOIP sound cuts in and out
Try your magicjack device in another usb port, as they sometimes share an irq internally with other devices, hence the chopped sound. Also make sure your computer is no trying to go into sleep or suspended mode, check the power settings to make sure the system is not shutting down devices in low power or battery mode if using a laptop, make sure the connection speed is good and strong, especially if connected to a laptop, and make sure nothing is hogging the cpu, causing the chopped sound. Also there could be issues with the router. Lastly, perform a firmware upgrade on your magicjack device, restart the machine, and then test it again. Good luck.
Jun 12, 2009 | Computers & Internet
Lands Phones Logo
313 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
