Question about Nikon Speedlight SB-600 TTL Flash
Flashing negative sign
When shooting outdoors only, my SB600 flash is flashing a negative sign and goes into negative exposure numbers slightly overexposing my images - tried compensating with aperture, etc with no luck.
    Problem Solver:
  • 11 Answers
A few suggestions for outdoor flash too bright with SB-600.
1 - If flash is in the auto mode, try hitting the (-) symbol a few times to lower the flash output
2 - Quick fix for close shooting - pull down the diffuser. You loose about 2 stops of flash light and effect is much softer. Don't forget to raise it later or you might think you have the opposite problem
3 - On the camera side, you play with your ISO. Depending on the scene, changing ISO can increase or decrease effect of flash vs background. This can be tricky to predict in auto because the camera is doing calculations of its own.
4 - You can put the camera in aperture mode and set your apeture so that you get a good balance between flash and ambient light. The camera will adjust the shutter speed, which increases or decreases the effect of the background - while the flash remains a constant. This can be very effective in tricky lighting situations, but be prepared to take lots of test shots to get it right.
5 - You can put the flash in manual mode. That will give you a consistant fixed reduced flash output regardless of what the camera tries to change. You have to keep checking your display to see the effect, but with camera in auto this can be a winner.
6 - Finally, you can go "old school" and put both camera and flash in manual and find your best combination. When I'm pressed for time in tricky conditions I often do this by finding a good setiting for a fixed distance, and then adjusting my apeture up or down as I shoot closer or farther things. We had to do it like this back in the day, and with the histogram on the display, I can get dead on where the camera "brain" would get tricked.
Posted on Mar 31, 2010
Too much brightness when using s6800
I do not know the S6800 model specifically however, nikon cameras all generally work in the same way. Somewhere on your camera, probably a button or in the menus, there is an exposure compensation setting. The symbol Nikon uses for the button is a "+/-" enclosed in a circle (often half black on white/white on black printing). Press the button and you will either see a zero, a positive or negative number or a a scale with zero in the center with positive numbers to the right and negative numbers to the left.
If the exposure compensation is not at zero, set it to zero. Your exposures should now be correct. If it is already at zero, set it to a negative number to reduce exposure and darken the picture and to a positive number to increase exposure and lighten the picture. Let me know if this solved your problem.
Jul 31, 2014 | Nikon COOLPIX S6800 Digital Camera Black
Dark Pictures
try reseting the camera back to default settings, there should be a function for that in the menus or a small reset hole somewhere in the camera.
Jul 23, 2008 | Canon PowerShot A640 Digital Camera
If i can use vivitar285 hv with my canon 600d without any problum
Yes, just put the camera in manual mode with shutter speed within x-sync range. Select the aperture based on either the auto flash or guide number (manual flash). The flash can provide auto exposure but excess ambient light will not cause any exposure adjustment by the camera, so just be aware if shooting flash involves going out into daylight, etc.
Feb 10, 2014 | Vivitar 2800 Flash
Sb600 keeps flashing
The the signal to the camera to shoot flash off the camera
change your settings
Jul 11, 2013 | Nikon Speedlight SB-600 TTL Flash
D90 dropped and caused a seal crack at front cover (cracked above lens mount). Build-in flash does not popup. It works well without flash. Do I have to replace the front cover? What should I do with...
The SB600 isn't made any more. I would recommend the SB700. Before you buy an external flash however, make sure that the hot shoe on you camera is still fully functional. An external flash is superior to the pop-up flash under almost any circumstances. Where your pop-up flash limits your shooting distance substantially, I have take pictures at night using an SB700 almost 100 feet from the subject and gotten correct exposure with my D90. Now there is one thing you will not be able to do without the pop-up flash, but I suspect it will never matter to you. You will not be able to use the pop-up flash to trigger the SB700 off camera.
Jun 14, 2011 | Nikon D90 Digital Camera with 18-200mm...
Light facial detail in my Nikon D60
Are you using the flash? If so, dial in some negative flash exposure compensation. Otherwise simply dial in some negative exposure compensation.
However, you will have to leave behind the Auto and the other point&shoot modes.
Dec 28, 2009 | Nikon D60 Digital Camera
Nikon SB600 / D90 out of sync
Check that the terminals on the flash and the camera foot are clean Use a pencil eraser to clean thyem by using a gentle rubbing motion. reconnect and test.
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Nikon Speedlight SB-600 TTL Flash
Flashing asterisk in left bottom of screen.
The flashing asterisk is the low battery warning.
Press f 4 to see four digits.
Payments with a negative sign indicate payments you make. Payments with positive values indicate payments you receive.
Nov 28, 2008 | HP 12c Calculator
SB600 Works Erratically...
If red light on flash is blinking, flash is charging. In shooting rapidly, sometimes flash will go off even though it isnt fully charged. This can give dark shots. Flash eats batteries like crazy, best to always use fresh batteries for each shoot.
Apr 14, 2008 | Nikon Speedlight SB-600 TTL Flash
Sb600 doesn't fire well off the sb800
The sb600 needs to be able to see the preflashes of the sb800, so this is probably caused by one of two things.  The first thing I'd check is whether or not the light sensor on the side of the sb600 was covered, blocked, or facing away from the sb800.  I've had problems outdoors when I forgot to have the light sensor face the camera.
If the sensor was facing the camera, it is possible that the flashes didn't have a good line of sight to each other.  That normally shouldn't matter, but if there is a high ceiling and lots of people, it could be the case.  I don't know if it will help, but in any case I would recommend using a StoFen Omnibounce on the sb800 to increase the likelihood that the light finds a direction where a surface to bounce off of is found.
Good luck.
Feb 02, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon Speedlight SB-600 TTL Flash Logo
91 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
