Question about ASUS Computers & Internet
Asus p5 vdc-x motherboard not recognizing ddr2
Asus p5 vdc x motherboard not recognizing ddr2 ram. Im trying to upgrade the ddr ram that im currently using to ddr2, i have 2x 512mb sticks and when i put them in the computer fails to boot but will start when the old ram is replaced. Any suggestions?
Im not using ddr and ddr2 at same time, i have placed them in the correct slot.
HI it sounds like a speed issue,check your
motherboard info for support or if you
have no manual download it from asus site
check for ddr2 support via the manual
regards john sykes
Posted on Jun 30, 2009
My EPoX 4PDA5 has 2 512mb ddr ram's, I was wondering if i could replace them with 1gb ddr2 or ddr3 without changing the motherboard, or would i be able to get 2 1gb DDR's and still use the 512's? because...
From http://www.motherboard.cz/mb/epox/EP-4PDA5.htm:
4 DDR modules for DDR 333/400 dual channel architecture
If you have 4 ram slots and only 2 are filled, you just need to match the speed of the two you currently have, they can be any size(500mb, 1gb, etc). I'm not sure you'll be able to find DDR ram anymore though.. and NO you cannot use DDR2 ram.
Jan 12, 2018 | EPoX EP-4PDA5 Plus Motherboard
DDR or DDR2
DDR 266 is DDR, not DDR 2 . The 266 is the frequency value in Mhz.
Try having the memory refunded or resell it on Ebay, so that you do not lose your money.
Here is supported memory, many older motherboards do not accept modules of over 512Mb each, ask to the seller:
PC2100 Memory DDR266 DDR-266 184-Pin Upgrade (266MHz) Memory Upgrades
Aug 22, 2009 | Computers & Internet
Ok i am just guessing here
maybe your motherboard does not support
ddr2 rams and hence it wont boot up as it does not detect any ram in the slots......
try to boot with one old and one new ram (ddr and ddr2) and post the result
are you sure whether the ddr2 ram is supported?
Jun 30, 2009 | ASUS P5VDC-X Motherboard
I have ms 7142 TO INCREASE RAM
hi im josh in cebu phils.may i help you? friend sad to say there is no way you can use DDR2 because your motherboard MSI K8MM-V doesn't support DDR2 it is DDR and SDR RAM. so you better use DDR having higher freq.to upgrade your pc. thats all good luck.hope i helped you.
Feb 27, 2009 | MSI K8MM-V Motherboard
Use of DDR2 RAM in ASUS MOTHER BOARD
This motherboard only support DDR type of RAM up to 4GIG , 400 MHz • 333 MHz this are the support speed of DDR RAM, so you can go ahead upgrade up to 4 GIG of RAM and that will make your computer very fast...
Nov 04, 2008 | ASUS GeForce® 4 V9180SE MX 440, AGP...
Upgrading Ram
Make sure you have the RAM seated in slot #1, and that you do not have DDR RAM installed as well, as DDR2 with DDR RAM will not work. Also, make sure the RAM you bought is on the QVL (Qualified Vendors List) for that motherboard. I know I have had problems with ASUS motherboards and OCZ ram before.
QVL Found HERE
Sep 05, 2008 | ASUS P5VDC-MX Motherboard
DDR2 RAM for P5RD1-VM
The ASUS P5RD1-VM takes the PC2700/3200 DDR SDRAM DIMMs. You can upgrade your ASUS P5RD1-VM to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory. For best system performance use the maximum amount of allowed Memory per slot for your system i.e. 1 GB.
Thanks
Iqbal
Apr 14, 2008 | ASUS P5RD1-VM Motherboard
Processor upgrade for my Asus P4V8X-MX motherboard
ya it has ddr u could beef ram up aint much chip u can get higher in this mobo need new mobo to run quad cores amd ect is am2+ mobo better cheaper ram too get more up to 8 gb 16 sum mobos on new egg
Feb 04, 2008 | ASUS P4V8X-MX Motherboard
Ram memory upgrade not recognized in system info.
does your mother board ddr2 compatible? do you have the manual of your motherboard? because there are brands listed in your manual which are compatible. if you have an existing ddr installed temporarily uninstall this and try this ddr2 512mb alone and let it run, if a beep beep sound occurs that means this is not compatible with your computer. remove this and bring this together with your ddr that work to your supplier, ideally the cast latency timer of these should be the same including the brand. hoping that this will help you
Nov 26, 2007 | ASUS Intel 440BX Chipset P2B-S Motherboard
Computers & Internet Logo
255 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
