Question about Ricoh Aficio 1515MF All-In-One Laser Printer
AFTER PHOTOCONDUCTOR REPLACED PAGES ARE BLANK
SAVIN 8025E - REPLACED THE PHOTOCONDUCTOR UNIT BUT ALL THE PRINTED PAGES ARE COMPLETELY BLANK AND THE "REPLACE PHOTOCONDUCTOR UNIT" STILL FLASHING ON THE SCREEN. DO I HAVE TO DO SOMETHING ELSE OR IS THE REPLACEMENT UNIT DEFECTIVE??
  • 143 Answers
IF you replaced the entire PCU, make sure you pulled the plastic tabs from the unit and removed the protective paper from the drum area. I don't remember if the new PCU comes with developer pre-installed.
If you replaced the drum/developer, it is common for the lower developer unit drive gears to wear down and break off some of their teeth.
Hope this helps.
Posted on Jul 09, 2009
Photoconductor unit
what model machine and what do you want to know about the photoconductor unit
Apr 10, 2014 | Savin Office Equipment & Supplies
Savin 8025e jam won't reset
Sometimes it just wants you to open a certain cover. open and close them all.
Mar 09, 2012 | Savin Office Equipment & Supplies
Savin 9927dp photoconductor ?
THE MAINTENANCE PROMPT COULD BE TURNED OFF BUT THAT IS AGAINST THE MANUFACTUREERS RECOMENDATION. THE PCU
WOULD LAST A LITTLE LONGER BUT IT WILL START DUMPING TONER AND DEVELOPER IN TRAY1 IF IT ISNT ALREADY THAT JUST ADDS TO THE CLEANUP TIME AND COST THE PCU WAS DESIGNED TO MAKE 60,000 PAGES.
May 06, 2010 | Office Equipment & Supplies
Replace photoconductor unit
take all paper out. check to see if any paper is jammed in the rollers
go to application folder for your computer, dbl click icon for make of printer, for settings, check to ensure everything is order.
lastly, check make of printer trouble shooting web site for more information
hope this helps, good luck.
Apr 29, 2010 | Gestetner DSm725 All-In-One Laser Printer
After installing maint. kit and new toner cart.still have the left half of pages are blank,right half faded
Hi, try the following. Send a print job of a few pages and when the first page comes out then open the front cover of the printer like if you were going to remove the toner. Remove the toner and look at the Photoconductor. If the image in the photoconductor is complete, no half of the print image and no blurring on the other half then the problem is your Transfer roller. Could be that is not installed properly or needs replacement it could also be that the High Voltage power supply (HVPS) is not sending enough charge to the transfer. If the image of the photoconductor is appearing just like the one printed on paper then the problem could be the charge roller or the HVPS.
Jan 18, 2010 | Lexmark T642 Laser Printer
Savin 816 photoconductor troubleshooting
Enter the SP mode.
Clear Mode 1,0,7 Hold down the Clear/Stop Key. Select Copier SP the go to SP7 - Data Log, then go to 804 and hit enter/execute. This will clear the PM Counter.
Sep 01, 2009 | Ricoh Aficio 250 Copier
PRINTED PAGES ARE BLANK AFTER REPLACING PHOTOCONDUCTOR
The machine should automatically recognize the new PCU. Blank copies would lead me to think you have further problems, charge corona? transfer issues? If you try to make a copy and open the front door real fast when the paper should be at the transfer unit, is there an toner image showing on the drum? If yes, then you have charge but not getting transfer. This is a hard problem to troubleshoot without seeing machine. Anyway good luck, please rate this. Thanks ..... Wait... just had a thought. On the shaft, on the inside of the rear frame, that drives the drum there is a coupling that is spring loaded. Sometimes the shaft gets gunked up and coupling does not pop out not connecting to the PCU, which could cause blank copies and will still say replace pcu. You could add a couple of drops of oil to that shaft to loosen it up if that's the case.
Jun 30, 2009 | Savin Office Equipment & Supplies
Resetting the photoconductor unit
After replacing the PCU, you can clear the counter by going to Clear mode, 107, push and hold Clear/stop. Screen should change. Push Copier, 7804 should clear drum counter.
Jun 28, 2009 | Ricoh Aficio 450 Copier
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
415 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
