Question about LG enV VX9900 Cellular Phone
Phone makes a werid sound when on speaker phone.
It won't play any of my ringtone with out making the sound.
    Problem Solver:
  • 11 Answers
Your speakers are probably blown out
Posted on Jun 30, 2009
My phone doesnt ring for incoming calls
It can be confusing and frustrating to miss calls because your iPhone isn't ringing. There isn't a single reason why an iPhone stops ringing - but most of them are pretty easy to fix. Try these steps before concluding that your iPhone is broken and needs an expensive repair.
If you're not hearing your iPhone ringing, there are five possible culprits:
  1. A broken speaker
  2. Mute is turned on
  3. Do Not Disturb is turned on
  1. You've blocked the phone number
  2. A problem with your ringtone
Does Your Speaker Work?
The speaker at the bottom of your iPhone is used for every sound your phone makes. Whether that's playing music, watching movies, or hearing the ringtone for incoming calls, the speaker makes it all happen. If you're not hearing calls, your speaker could be broken.
Try playing some music or a YouTube video, and make sure to turn up the volume. If you're hearing audio fine, then that's not the problem. But if no sound comes out when it should, and you've got the volume up loud, it could be that you need to repair your iPhone's speaker.
Is Mute On?
It's always good to rule out the simple problems before diving into more complicated ones. In this case, you need to make sure that you haven't silenced your iPhone and forgotten to turn the ringer back on. There are two ways to check this:
  1. Check the mute switch on the side of your iPhone. Make sure that it's turned off (when it's turned on, you'll be able to see an orange line inside the switch).
  1. On your iPhone,go to Settings and tap Sounds (or Sounds & Haptics, depending on your model). Make sure the Ringer and Alerts slider isn't all the way to the left. If it is, move the slider to the right in order to turn up the volume.
Is Do Not Disturb On?
If those aren't the problem, it could be that you've enabled a setting that mutes phone calls: Do Not Disturb.
This is a great feature of the iPhone, introduced in iOS 6, that allows you to stop sounds from calls, texts, and notifications when you don't want to be bothered (while you're sleeping or in church, for instance). Do Not Disturb may be great, but it can also be tricky - because you can schedule it, you may forget that it's enabled. To check for Do Not Disturb:
  1. Tap Settings.
  2. Tap Do Not Disturb.
  3. Check to see if either the Manual or Scheduled sliders are enabled.
  4. If the Manual is enabled, slide it to Off/white.
  5. If Scheduled is enabled, review the times Do Not Disturb is scheduled to be in use. Did the calls you missed come in during those times? If so, you may want to adjust your Do Not Disturb settings
  6. If you want to keep Do Not Disturb but allow calls from some people to get through no matter what, tap Allow Calls From and select groups of contacts.
Is the Caller Blocked?
If someone tells you they called you, but there's no sign of their call on your iPhone, maybe you've blocked their number. In iOS 7, Apple gave iPhone users the ability to block phone calls, FaceTime calls, and text messages. To see whether the number that someone is trying to call you from is blocked on your phone:
  1. Tap Settings.
  1. Tap Phone.
  2. Tap Call Blocking & Identification (it's simply Blocked on earlier versions of the iOS).
On that screen, you'll see all of the phone numbers you have blocked. If you want to unblock a number, tap Edit in the top right corner, tap the red circle to the left of the number, and then tap Unblock.
Is There a Problem With Your Ringtone?
If your problem still isn't solved, it's worth checking your ringtone. If you have an iPhone custom ringtone assigned to contacts, a deleted or corrupted ringtone can cause your phone not to ring when someone calls.
To address problems with ringtones, try these two things:
1. Setting a new default ringtone. Here's how:
  1. Tap Settings.
  2. Tap Sounds (or Sounds & Haptics).
  3. Tap Ringtone.
  4. Choose a new ringtone.
2. You should also check to see if the person whose calls you're missing has an individual ringtone assigned to them. To do this:
  1. Tap Phone.
  2. Tap Contacts.
  3. Find the person's name and tap it.
  4. Tap Edit in the top right corner.
  5. Check the Ringtone line and try assigning a new ringtone to them.
If the unique ringtone seems to be the source of the problem, you'll need to find all the contacts that had that ringtone assigned to them and select a new ringtone for each. It's tedious but necessary if you want to hear those calls as they come in.
If None of This Fixed the Problem
If you've tried all of these tips and still aren't hearing your incoming calls, it's time to consult the experts. Make an appointment at the Apple Store and bring in your phone for inspection and, potentially, repair.
Dec 14, 2017 | Lands Phones
How can I make my speakerphone work again?
call someone or tun on music on phone menu select loud
Feb 27, 2016 | Cell Phones
My iPhone 5c won't ring
Does the phone plays music without any problem? If you play music to hear it on the loud speaker, and there is no sound, then you probably have a hardware failure, (bad speaker). But if you get to listen to the music, then try this next steps to see if it can be fix.
  • From the iPhone's home screen, tap the Settings app.
  • In Settings, tap Sounds in the third group of options.
  • In Sounds, swipe down to the Sounds and Vibration Patterns section. In that section, look forRingtone. That displays what you have set as your current iPhone ringtone. Tap it to change that.
  • This menu shows you the list of all the ringtones available on your iPhone.
    To get new ringtones, tap the Store button in the top right corner. This will take you to the ringtone section of the iTunes Store where you can stock up on new ringtones.
  • If you choose not to buy new ringtones, but instead use the ones loaded on your phone, the first set of options in the Ringtones section are ones that you bought from the iTunes Store or created using another app and have synced to your iPhone. The ones below the divider came pre-installed on the iPhone.
    Alert Tones, farther down the screen, aren't ringtones exactly. They're alert sounds normally used for alarms and other notifications, but they can be used as ringtones, too.
  • When you tap on a ringtone, it will play so you can preview it and decide if it's what you want. When you've chosen the ringtone you want to use as your default, make sure it has the checkmark next to it. Then tap the Sounds button in the top left corner or click the Home button to go back to the home screen. Your choice is saved automatically.
  • Now, whenever a call comes in, the ringtone you just selected will play (unless you've assigned individual ringtones to callers, that is. If you have, those ringtones take precedence). Just remember to listen for that sound, and not a ringing phone, so you don't miss any calls.
  • Mar 13, 2014 | Cell Phones
    No music or ringtones
    Dear Brother,
    As you said you Did Restore Factory Settings Well.So there is no chance of Problem for Software.It is Mostly seems to be a Complaint of your Hardware .You just Type *#7370# & enter Phone Code to Hard Reset(If already done Ignore it)
    • Hardware might be speaker (Buzzer)
    • You need to Change Speaker
    • Or Problem with Audio IC /Some Supporting Components
    • Disassemble your handset and Change it CAREFULLY only if you able to do yourself
    You cannot Activate or make Loudspeaker/ Speaker Phone Now ...Right...??!!!!
    Hope this Helped you....Thanks for Contacting FixYa......
    Apr 20, 2010 | Nokia E63 Cell Phone
    My blackberry bolds ringtones dont work all it does is viberate
    Make sure the speaker phone works. play the ringtones in the media folders if they play your phone's speaker is good, if they dont your speaker is bad.
    If the speaker is good then go to the sound profiles and advanced to edit the profile of your choice... make sure it is the one you are using. Make sure it is set with ringtone volume play sound always
    Feb 20, 2010 | RIM BlackBerry Bold 9000 Smartphone
    Motorola Adventure 750 phone-- no speaker sound. Why?
    You've probably already tried these, but what the heck; you asked...
    1) Check in MENU -> SETTINGS & TOOLS -> SOUND SETTINGS -> CALL SOUNDS -> CALL RINGTONE to make sure that you have actually selected a ringtone instead of the "No Ring" option at the bottom.
    2) With the phone open, try the up/down buttons on the left-hand side of the phone (above the Push-To-Talk button) to make sure that your volume isn't set to "All Sounds Off," "Alarm Only," or "Vibrate Only." It has to be at least at "Low" before a ringtone will play.
    Hope this helps. If not, you probably need to take it in to a Verizon store for an expert assessment; they'll usually take a look at your phone and install any software updates for free.
    Mar 10, 2009 | Motorola Mobility V750 Cellular Phone
    Phone Speaker does not seem to be working
    Same here. It doesn't play music and the incoming calls cannot hear when the cover opened.
    Nov 04, 2008 | Sony Ericsson W380i Cellular Phone
    Sony Ericsson W890i ringtone and alarm doesnt make noise walkman works.
    The front speaker needs replacing. Songs/MP3's are played through the back speakers, thats why you can hear them when you play them individually.
    Ive been quoted around £50 from an online mobile phone repair centre to replace it.
    Needless to say, Ive sent my phone back for a refund, and i wont be buying this phone again.
    Oct 01, 2008 | Sony Ericsson W890i Cellular Phone
    Ringtones
    Did you create a folder for the Ringtones? if you did, make sure you have it on 2 (sounds)...go to Menu, Press 7 (my stuff), press 2(sounds) open your Ringtone folder and Voila!!! der they r...press d options (dont play the song, just highlight d ones u want to set as a ringtone) press 2...n der u go.
    Reps are appreciated :)
    Nov 28, 2007 | LG Shine KE970 Cellular Phone
    LG enV VX9900 Cellular Phone Logo
    37 people viewed this question
    Top LG Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Raphael Josiah
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
