Question about Sony CDX-M630 CD Player
Pre set ,raido stations.. grrrrrrrrr!!!!
I have tried to follow the instructions but it seems to not work , like there is a step missing or something.i cant get it to save to a button, their are no buttons to press for 2 sec. can someone please help me?
  • 752 Answers
Re: pre set ,raido stations.. grrrrrrrrr!!!!
I believe that you have to press and hold the number buttons ON THE REMOTE for 2 seconds....
Here's the manual for ya.
Posted on Nov 09, 2007
0 characters
3 Points
How do I use the Pre-set function for am & fm radio stations ?
press and hold the button you want to assign a station to.
Apr 13, 2016 | Car Audio Receivers
New Xm, went through the steps in manual; no sound in car
The stations you set it to have to be complete static for the xm to come in. Your best bet if you head unit has an aux input is to buy an aux cable(few dollars) and hardwire it. it will give you the best quality for sound for xm.
Dec 27, 2009 | XM Radio (XMP6000)
I cant get my raido to save my time or my radio
make sure that you have wired it to the manufacturers spesification, ie, that you have one wire, ususlly the yellow , going to a permanent, not switched power sourse
Oct 22, 2009 | JVC KD-S580 CD Player
7835 pre set stereo
tune to station ,press (for example)1 and hold till it starts blinking , then press 1 again,continue in this manner until you've set all presets.
Dec 05, 2008 | Alpine CDM-7835
Pre set stations
Here's a link to the manual download page at Alpine. It should tell you everything you need to know.
USA - EUrope FM band stations frequency differences
I have a car stereo purchased from the US and I can’t pick up all radio stations in Europe/UK, what can I do?
If you have purchased a car stereo from the US you will find that it will not pick up many European radio stations. This is due to the fact that US radio frequency steps are different to here in Europe.
You may be able to set the tuner to European stations by following this procedure.
Press and hold down the SRC button to power down the unit completely.
While the unit is off press button 1 & 5 together, while momentarily pressing the SRC button.
If this does not work try the following proceedure;
Press and hold buttons 1 and 5 together, while momentarily pressing the reset button.
If this does not work then the unit is not designed to pick up European frequency steps.
Jun 11, 2008 | Kenwood KDC-MP2035 CD Player
LPF and Sub Woofer settings missing from menu
I had the same problem and I just worked it out. Its because your pre-out is not switched to 'subwoofer'. It will be on 'rear' instead. Go into the menu when its in standby and change the SWPRE option to subwoofer and then your subwoofer options will be back in the menu !
Mar 24, 2008 | Kenwood Sirius KDC-MP825 CD Player
Cdx m 630
Do you lose them only after the car is turned off? if so, your 12 volt Costant wire (yellow) is hooked to a switched 12 volt source.
Nov 08, 2007 | Sony CDX-M630 CD Player
Very weird Radio Tuning Problem
This is a USA model and by default in the USA all FM stations end in an Odd number. This is completely normal. you can try holding preset 1 and 5 down while pressing the reset button on the unit and it may allow you to switch to a Europe style of tuning.
Oct 10, 2007 | Kenwood Sirius KDC-MP522 CD Player
Sony CDX-M630 CD Player Logo
65 people viewed this question
Top Sony Car Audio Receivers Experts
Larry Stiles
Larry Stiles
xxxxxx xxx
Are you a Sony Car Audio Receiver Expert? Answer questions, earn points and help others
