I have lost the hose adapter that connects the hose to the a/c unit, any idea of where i can get a replacement. are the connections standard?
  • 27 Answers
I'm not sure exactly what hose you are talking about other than the drain hose but everything to do with fittings is standardized. Manufactures aren't going to reinvent the wheel. I would say an Ace Hardware probably, an A/C-Plumbing Supply house definitely would have what you're looking for.
Posted on Jun 30, 2009
Standard garden hose does not work since Haier drain hose connection is metric, not standard. Any solutions?
Never heard of a metric garden hose connection. Was this unit purchased in the US or overseas?
Check box or bag with manual. There may be an adapter in there.
Sep 13, 2017 | Haier Dehumidifiers
Leaking washing machine faucet adapter
fit the rubber washer into the adaptor that seals off on the tap face
can be obtained from any garden tap fitting
Jan 24, 2018 | Washing Machines
HI, unfortunately I lost the power adapter of my Gemini FX 7000. I want to replace it with a universal power adapter with the accurate voltage but the connector is quite weird for a power supply (RJ 45)...
Don't even think of using a universal adapter !!! I could not find the schematic of this unit, but other Gemini mixers like this use center tapped AC power transformers. Any universal adapter will be DC, not AC. I have found that the FX7000 indeed uses an 18 VAC adapter... Try this as a source:
http://www.topdjgear.com/gemini-110vac18v.html
Jul 05, 2011 | Gemini Sound Products Gemini FX7000 10...
The quick connect hose does not fit into any of the taps - do i need an additional adapter, where can I get this? no one seems to have a problem connecting to the water tap - why me>? Alos can it...
these washers only connect to some standard taps, for others you will need an adapter. another thing is the hoses are generally short but you can definitely connect to your laundry taps if the hose is long enough.
Dec 24, 2010 | Danby DTT420 Top Load Washer
I have a Durabuilt power washer model PW0501400. I have lost the adapter that connects the hose to the unit...Can you tell me what this piece is called and where I can get it?
well it is called a hose adapter you can get them at rural king for around $8.00 or so they come already fitted to a piece of threaded pipe so all youhave to do is remove whats left of your old coupling and reinstall new one .
Mar 18, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
I have the hose hooked up to the back but it keeps filling the tank and shuts off when it's full ,how do you just use the hose to drain
I believe you have to put a plug to drain that drains into the tank ,then it can only drain out the hose.
Jul 14, 2009 | Maytag M7DH65B2A Dehumidifier
Danby portable dishwasher 1805W hose too short. Where I can find a extension hose.
First cut the hoses off near where they would connect to the plastic quick adapter. Leave a little slack at 2-3 inches between where you cut and the metal clamp.
Take those two pieces you just cut off to home depot or lowes. Afterwards you can chuck them if you don't want them (I did read below). Take the metal faucet adapter with you too.
For the water supply hose (this is the smaller one) need a Hose barb adapter 3/8 Barb x 3/8 FIP
You need a clamp for this.
Get a plastic hose the length you want and the right barb to fit the drain hose and your new hose. You need two clamps. Also you might consider hooking it up to an external water pump depending on your situation. If the hose is long or has to go up above 36 inches then you may need a pump.
Then you want a standard dishwasher connecting kit. They have them from 4-6 feet, they come with a 3/8 brass fitting make sure you get that.
You also need plumbing teflon.
I also wanted to replace the faucet connector because the plastic one it came with leaked all over the place. I got a quick snap that goes to a garden hose. It fits the metal faucet adapter that came with the dishwasher. . I had to get a few connectors to go from the garden hose adapter to the standard dishwasher hose.
Installation. Take the clamp for the supply hose and put it on the hose connected to the dishwasher. Put insert the barb and tighten the clamp.
Put teflon on the 3/8 male connector that came with your standard dishwasher kit. Connect it to the Barb adapter you just installed. Connect your standard dishwasher hose.
Connect the other end. Its pretty straight forward just don't forget to put teflon on any of the thick threads.
From this you can pretty much figure out the rest with the drain hose.
If I were to do it again I probably wouldn't have used the standard dishwasher kit. I would have gotten a cheap plastic tube and connected it. Also if you're happy with the plastic adapter they gave you save the plastic connectors you cut off and you can use another 3/8 barb adapter to connect it to the other end of your extension hose either a simple plastic tube or the standard dishwasher connector.
Dec 04, 2008 | Dishwashers
Cannot find network 1394 network adapter nor the standard Network Adapter connection
Try having a System Restore on your computer back to the date before you installed the wireless HP printer device and software.
Sep 13, 2008 | Computers & Internet
Power adapter barrel connector
Check ebay for a repacement unit, I have gotten several power units out there.
Jul 26, 2008 | HP Photosmart 2610 All-In-One InkJet...
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
