Question about Canon PIXMA iP3000 InkJet Photo Printer
Error 5100 i can't print any document,then it has shown one sentence" error 5100". help me, please
  • slamman2 Dec 21, 2007
    i get error 5100 every time i try to print i turn the printer on and off and try afain but the same error code cimes up. I tried cleaning the bar and the strap and try agqain but same eror comes up. What is wrong. I dont know what else to do. Please help.
    Genius:
  • 1,601 Answers
Error 5100 is either a logic board, or
the code strip (if that is the problem) is another matter -
It is the plastic strip that runs across the printer and through the head
carriage, it is supported at each end (one end under spring tension).
If it has become dislodged it will give this error, also if it has any ink,
grease or other foreign matter on it, it will give errors.
You can clean it with a cloth dampened with water but you need to exercise
great care to avoid pulling it off its anchors.
The other thing to do is clean the stainless steel bar that the carriage sli
des
on and lubricate it with a cloth moistened with 3-in-1 or light machine oil.
If neither of these works then I guess it is repair shop or replacement time
Posted on Nov 19, 2007
I can't print my documents. My Printers model is Canon IP2700 and it says there that the error code is 5100. How can I fix the problem? we need the print immediately. Is there any solution we can fix it?
Usually, error code 5100 means some kind of obstruction in the print path, maybe something that had fallen inside the printer, the gears being jammed by something that got loose inside the printer, or ink on the clear plastic encoder/timing strip (a plastic strip about 1/4" in width that you can see running from side to side and connects to the print head).
Clean the plastic strip with alcohol , check if there is nothing blocking the head carriage set (sometimes kids play and hide toys, pens, coins, inside printers, VCRs or any other devices that have "doors"...).
Hope this info may help you!
Mar 12, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Double images, error 5100 when printing, copying
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Jan 02, 2010 | Canon PIXMA MX700 All-In-One InkJet...
My kodak 5100 all in one printer will not print out my documents but only prints out what is on my scanner, how do i solve this?
did you recieved an error message printer not responding? If yes please double check the icons of printer on the printer and faxes, if you can see 2 icons delete both icons and unplug your USB cable, then restart computer.
Now if the computer is already restarted connect USB cable then try to print.
there are several reasons why it will not print using computer, there might a problem on USB cable and its connection or the drivers., Please verify the problem, or you may contact kodak toll free 1 800 421 6699. hey will help you on this issue., Gudluck!
Nov 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer canon1700 shown message ''service 5100 error''
Call your dealer or servicing agent. The device has a hardware problem that needs to be addressed by a trained service tech.
May 05, 2009 | Canon Office Equipment & Supplies
Regarding service error 5100 in canon ip1880 printer
1. Try to reset the ink counter by iptool software (sometimes it help)
2. Unplug the usb cable and then turn off and on your printer for a few times.
service error 5100 seems like indicating of mecanism exhausted or out of buffer ram in the printer. You should reduce the amount of pages to print at one time.
Good luck.
Jan 25, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Error 5100
Use the link below to fix the error
http://www.fixyourownprinter.com/forums/laser/25975
2nd solution :
o to the canon website (listed below) - under Tech Support - click on Technical FAQ's (this will pop up another small window)
then click on Search by Key Word
next - type in error 5100 and click on the circle next to - Include all words and hit Search
next - click on the link with your answer "how to.... "
this should show the answer
http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=238&modelid=11865
Oct 20, 2008 | Canon PIXMA iP1600 Printer
Service error 5C00 or 5100
5100 Make sure nothing is blocking the cartridge movement, if not requires service.
Mar 27, 2008 | Canon BubbleJet i560 InkJet Printer
Canon iP 1300
I am also with the same problem of Canon IP1300, need to know how I can solve this problem of the error 5100, as soon as I bought the product and not used yet, for this mistake, I wonder if this problem is also frequent in the canon machines? !
Jan 23, 2008 | Office Equipment & Supplies
Error 5100
where is the best place to get this repaired>
Nov 06, 2007 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
71 people viewed this question
old marine
old marine
