After watching it for a couple hours it turns itself off, sleeper is turned off mind you. but it will turn back on with the remote
SOURCE: LG tv turns on by itself
this problem is with the inner small micro-swtches ,the side buttons inside are getting intermittantely short...changing of those switches will solve the prob. tc--
SOURCE: My tv Wont Turn On
My 32" hyundai LCD TV will not turn on. The power lead is ok the on / off switch on the side turns the red stand by light on and off. I am unable to get the LCD TV off stand by. I have tried the the stand by button and this does not do anything. Can anybody help.
SOURCE: TV turned itself off, won't turn back on
I had the same issue with my 42HP95 after about two and a half years. Same symptom, red flashing power light, reset doesn't work and most of all, the last day of the Ryder Cup starts in 3 hours. Any other time (with exception of SuperBowl Sunday). I frantically searched the web for like symptoms and came across someone that posted the fix was to bypass the Seine Module but I had no clue what that was! So what do you do? Tear off the back of the TV and look for something that says Seine on it... Right! After that failed and 500 screws later, I decided to look for a Service Manual online. Nothing like RTFM (Google it!). I paid my $11.99 for a download Service-Manual.Net and found what appeared to be the Seine Module (SEIN). Through a little trial and error, here is what I came up with. The pic below shows the location of the said Module in the red rectangle.
I ultimately found that if I unplugged the connector from the module (in red circle) and put it in the cable management loop (other red circle), the TV would power on and has been working ever since.
According to the post I read (grains of salt) the SEINE Module is only needed if you are using coaxial type (rabbit ear) antenna. I personally don't know but it works for me. Granted, this is my experience and may not work for you but for $12, I am a happy camper. BTW, what a Ryder Cup!!! USA USA USA!!!
SOURCE: 42 in LG LCD TV turns off by itself
Found that TV started switching off by itself. Would try to come on..green light blinked for 2-3 seconds, tv came on (with picture and sound) for 1 or 2 seconds and then it would turn itself off. Found that the issue is with one channel only. If you are facing this issue....try quickly changing the channel the moment it comes on. You can do it either with remote or with the TV buttons directly. also in the same logic, if this is still happening, try changing the source to another (rgb-pc, av1, av2 etc). Basically change it from whatever input it is on currently, if changing the channels does not work. My symptom was that the tv made a loud 'TIK' 'TAK' sound which is louder than normal.
SOURCE: tv turns on and off by itself
check batteries on the remote/or hide remote and see if it stops/if not bigger problem
