Question about Logitech QuickCam Pro 9000 Web Cam
I have a Logitech Pro 9000. After installation, I found that my head phone set that I am using for SKYPE calls was disabled and the Pro 9000 microphone is enabled. There is an echo problem when I speak on SKYPE. Is there a way to get my head phone set working again, without disabling microphone of Pro 9000?
    Sniper:
  • 84 Answers
I have version 4.0.0.206 of Skype. Don't know whether this works on versions below that. If in doubt update your version of Skype, the current version is 4.1, click here to download it if needed.
Within Skype, click Tools, Options
Click on Audio Setting, in the General Tab. Now under the microphone section, click on the down arrow and select your other device and then click 'Save'.
If the other device is not present it may need to be re-installed, Nik.
If this helps click YES below.
Posted on Jun 30, 2009
  • Logitech Master
  • 10,322 Answers
1st You download Webcam Driver.
camera installation After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Posted on Jan 06, 2014
  • 453 Answers
Hello !
May b you can try a couple of steps like,
1) Disconnect the microphone pin of the headphone you are using from the laptop or desktop.
if this does not work.
2) Try with a headphone which does not have a microphone in it.
If it works well then it is better to use the headphone without mic in it.
Then you can isolate whether the problem is with your headphone or the microphone.
Good luck !
I have a logitech Pro 9000. It works completely fine with GChat, but not for Skype. Skype complains " bad internet connection" and the video I transmit is mostly frozen. On the other hand the...
hi freeman319
you might want to try and uninstall the quickcam application. as i've researched skype is having problems with certain cams compatibility. just try and uninstall the quickcam application but not the drivers. with this you may still be able to use the quickcam with other applications.
you can uninstall it through the control panel>add remove programs
also if you are using a headset or separate mic and headset with the video call you would want to disable the mic on the quickcam
go into Device Manager and disable the microphone in the Pro 9000
ofcourse this is just some things you can try but is not guaranteed to solve your issue. please let me know if this works. thanks.
hope this helps
janc30
Feb 11, 2011 | Logitech QuickCam Pro 9000 Web Cam
Using Skype with my Logitech QuickCam Pro 9000
The advantage of having a logitech webcam is the support you have.
I just launched my logitech toolbar and clicked on the lowest panel to see what help you have with your webcam in Skype - check this out
http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=9266&p_created=1227724918&p_sid=PlhfBfJj&p_accessibility=&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD00NCw0NCZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Mb2dpdGVjaMKuIFdlYmNhbSBQcm8gOTAwMA**&p_li=&p_topview=1
Also there is a good logitech forum from other users as logitech tends to have teflon shoulders when it comes to chat programs
Sep 29, 2009 | Logitech QuickCam Pro 9000 Web Cam
"error 2178 logitech quick cam pro 9000 installation"..cant insta
Normal 0 Double click on this site
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
Then
Search by Image (Match what yours looks like)
or
Search by Name
and
Product Name.
This will then take you to the next window where you need to select your
Operating System
. Then you will get your download driver.
Then do this:
Disconnect the Camera from the USB port and reinstall the CD or Downloaded softwareprogram. When the program asks you to connect the camera to theUSB port, do so and it should work.Then to use it on the Web, do this.
Web Camera’s have to besetup on the program they are to be used with. Just installing the cameraon your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Yourfriends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hopethis helps. Bud
Hope this helps. Bud
Mar 31, 2009 | Logitech QuickCam Pro 9000 Web Cam
Mac Software for Logitech QuickCam Pro 9000
The solution (or, should I say "supposed" solution) posted by yooperbud is 100% wrong, wrong, wrong. As a matter of fact, he couldn't BE more wrong. While the original question asked had to do with software for the QuickCam Pro 9000 for the Mac, the answer he gave is 100% directed at the Windows OS, NOT the Mac. To anyone, and everyone, who has voted his reply a "Yes", I am sorry.
Mar 21, 2009 | Logitech QuickCam Pro 9000 Web Cam
Video webcam logitech 9000 pro is to slow on pentium 4 2,6 GHz XP
http://www.logitech.com/index.cfm/webcam_communications/webcams/devices/3056&cl=US,EN
go to this link, scroll down to instant messeging and click on learn more.
follow setup instructions.
if this does not help, come back and i will try to work out another solution.
Feb 25, 2009 | Logitech QuickCam Pro 9000 Web Cam
My Logitech Pro 9000 view in Yahoo
Normal 0 See section B. Yahoo Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
Feb 19, 2009 | Computers & Internet
Loaded Skype . My friend can't hear me talking.
try and change the audio settings under the tools menu option of skype and goto the general settings. You will find the audio and select for the correct audio device.
Feb 11, 2009 | Logitech QuickCam Pro 9000 Web Cam
Logitech QuickCam Pro 9000 will not stay online
A. Skype Setup:
B. Yahoo Setup:
Feb 03, 2009 | Logitech QuickCam Pro 9000 Web Cam
Logitech pro 9000 no video
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
B. Yahoo Setup:
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Jan 26, 2009 | Logitech QuickCam Pro 9000 Web Cam
Logitech QuickCam Pro 9000 - Movie Sound?
Normal 0 You need to go to the manufactures site and download the VISTA driver for the camera. Then follow the info below to install the program.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Jun 30, 2008 | Logitech QuickCam Pro 9000 Web Cam
Logitech QuickCam Pro 9000 Web Cam Logo
218 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
