SOURCE: When I log on to my home page msn.com it wont let
plz check ur userid & password, is tht may be wrong.
SOURCE: When I try to go to my home page that is msn.com
I’ve been wrestling with this same problem for several days and finally found a solution that works for me. The redirect can be repaired by going to http://dell.my.msn.com. Just going to this page seems to reset the redirect of the msn.com home page to http://dell.msn.com.
I still have no answer to how to get rid of the redirect altogether, but at least I don’t get the broken links page anymore.
SOURCE: Brand new Dell Vostro 220S won't power up
Depending where you are check that the voltage is correct , it should show 110 for US and 220 for EU and other countries
Ensure that the processor power cable is securely connected to the system
board power connector (see your Service Manual at support.dell.com).
•Ensure that the main power cable and the front panel cable are securely
connected to the system board connector (see your Service Manual at
support.dell.com).
SOURCE: veI have a DELL VOSTRO
The video chip , which is part of the motherboard , has failed. You can't fix that, the motherboard will have to be replaced. If the pc is still in the warranty take it to where you bought it.
SOURCE: I can't open the cd
there could be a little hole above the open switch in ur cd drive,push a pin on it.carfully..
