Question about Motorola Mobility W375 Cellular Phone
Unable to receive pictures
I used to be able to receive pictures on my Motorola W375 but over the last couple of days when they come in, instead of an option to "read" the message it has now changed to "download". Every time I select "download" the egg timers comes up for a while and then it comes back and says "fail". Why?
  • 51 Answers
Re: Unable to receive pictures
There could be several reasons for this......have you checked the signal you are getting when attempting to recieve?....if you have a good signal at the time then i would suggest contacting your wireless provider for assistance since im sure you pay hard earned money for this feature
Posted on Dec 09, 2007
0 characters
3 Points
I lost my drivers. it s not getting connected to pc
HOWTO_Connect How to connect Motorola W375 to a Windows computer Introduction¶ This document describes how to connect your Motorola W375 to your computer in order to use it as a modem, or to administer it with Motorola W375 Manager software.
Connecting¶ To connect your motorola W375, follow the next steps:
  • Download and uncompress Motorola W375 Driver from this site.
  • Connect your W375 to your computer with its lid closed.
(You can also connect the device with its lid open, and choose "not" when it asks for permission to connect as an storage device)
  • When Windows asks you for a driver, select Motorola W375 driver folder.
This way, the next time you connect your mobile phone closed, your computer will recognize it as a new communications port and you are ready to use it with Motorola W375 Manager. If you open this "COM" port with a terminal emulation software (i.e Windows Hiperterminal) and type "AT", the mobile phone will respond you with an "OK" string.
Using it with Motorola W375 Manager¶ To use your mobile with Motorola W375 Manager, simply connect your mobile phone closed and then, start Motorola W375 Manager software.
Using it as a modem¶ To use your mobile phone as a modem, install "Standard 19200 Modem" driver and select the communications port associated to your motorola W375.
About Motorola W375 driver¶ Motorola W375 driver is basically the same driver known as Motorola USB Charging Driver. You can download Motorola USB Charging driver from motorola US support web site for Motorola W375. If you try to use Motorola USB Charging driver directly with your Motorola W375, device type will not be recognized, but if you change device ID from "USB\VID_2811&PID_0702" to "USB\VID_22b8&PID_4061", this usb charging driver will become completely compatible with wour Motorola W375 mobile phone. The driver you can download from this site, is exactly a Motorola USB Charging driver with the mentioned modification.
Dec 07, 2010 | Motorola Mobility W375 Cellular Phone
Unable to charge motorola w375,need a solution
Check the contacts between phone and battery, if necessary align or clean. Are you using original Motorola charger? This solved my problem; I was trying to charge it with one of those "universal" chargers.
Hope this helps!
Feb 18, 2010 | Motorola Mobility W375 Cellular Phone
The motorola battary will not charge. the brand is BQ50 it said (unable to charge) how much will it be?
Clean the charging port, remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.
Oct 19, 2009 | Motorola Mobility W375 Cellular Phone
Need free unlock codes for Motorola W375 Net 10 cell
wanna unlock ur mobile, here i found a site this is not free of cost but reliable , and i found this last week i used this unlock
May 15, 2009 | Motorola Mobility W375 Cellular Phone
Motorola W375 won't charge online!
You'll need pc charging drivers to charge your phone with a pc and a USB cable, you can get the driver at the motorola website.
hope this helps.
Mar 31, 2009 | Motorola Mobility W375 Cellular Phone
How to download pictures from motorola W375 to PC ?
Use the program motorola phone tool for that, you can download it from here:
YOu can use it to download or upload to your phone
Good luck
Mar 23, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Can't receive mms pictures Motorola w377
T Mobile eventually sorted it out. I think my sim card needed updated as it was from another phone held by me.
Nov 12, 2008 | Motorola Mobility W375 Cellular Phone
Motorola w375
Use a cotton bud, damp, if it very dirty. Then, use a food cocktail stick to go round the circumference of the camera a couple of times. Do this as many times as needed, it will help with the outside of the lens. Hope this helps, even if just a little bit.
Mar 16, 2008 | Motorola Mobility W375 Cellular Phone
Unable to download photos from motorola w375
you will need motorola phone tools in order to transfer photos and music to your phone. and for information, your phone can only have 1.5mb memory therefore it wont hold much pictures
Dec 27, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Alltel motorola razr vc3 wont download pictures.
Call ALLTEL for the SERVICE Number. You accidentally erase it. This uses to send/receive msg maybe the Picture/Video too. Try boot-up ur Phone. Goodluck
Aug 11, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility W375 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
