Question about Panasonic Televison & Video
PT-61HX42F turns off and red light flashes 4 times
Panasonic PT-61HX42F turns off and the red light flashes 4 times. If you unplug it from the wall and, some minutes after, replug it and turn it on. It will play for around an hour and do the same thing again. But If you unplug it from the wall, put a fan on behind it and, some minutes after, replug it and turn it on. It will play all day long. Can I have the service code setup to replace the defected part?
  • merara01 Jun 30, 2009
    Muzzi. the unit is 7 years old. Loss of money to ship it to manufacturer repair center. It will be a life savior if I get the service code setup for red light flashing and do it myself.
  • merara01 Jul 01, 2009
  • 744 Answers
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
Posted on Jul 01, 2009
  • 749 Answers
You will need to send it to the manufacturers repair facility.
Posted on Jun 30, 2009
  • Muzzammil Ishfaq
    Muzzammil Ishfaq Jun 30, 2009
    Using the remote control:
  • Press the {MENU} button.
  • Press "Setup" menu.
  • On "Mode" menu, select "Cable"
  • Select "Timer" menu and set sleep timer to 30 min.
  • Press {ACTION} twice to exit menus.
  • Tune to channel 124.
  • Press and hold {VOL -} button ON THE TV.
    "CHK" appears in on top-left corner followed by 5 letter/numbers
    (which are the cumulative hours in hex numbers)
  • While the "CHK" is displayed, press the {ACTION} & {VOL+} buttons
    ON THE TV simultaneously to toggle between Modes:
    — Red "CHK" for Serviceman — Yellow "CHK" for Aging —
  • Press the {POWER} button on the remote to select one of the six
    Serviceman Adjustments Modes.
    A. MTS ADJUSTMENT
    B. CLOCK ADJUSTMENT
    C. VIDEO ADJUSTMENT
    D. HDEF ADJUSTMENT
    E. VDEF ADJUSTMENT
    F. DAF ADJUSTMENT
    G. OTHER ADJUSTMENT
  • Press {CH+} {CH -} on the remote to select the settings
    on each of Service Adjustment Modes.
    Write down the original values before modifying anything.
    It's easy to erroneously adjust the wrong item.
  • Press {VOL+} {VOL -} on the remote to change values.
  • Press the {POWER} button on the TV to exit the service menu
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
PT-56LC27 52
If the light flashes red 2x's its a problem with the lamp. That's all I know. It's happened twice to me.
Dec 18, 2009 | Panasonic Televison & Video
Panasonic PT-61HX42F shuts off automatically red light flashes, but before that happened the green color was way off
One of the convergence output IC's has died. However, when one goes the other is soon to follow so any good repair shop will insist on changing both of them. This is a common failure with all projection tv's as these amps work real hard and have a high failure rate. Average repair cost is usually between $200 and $300.
Jun 04, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Red light flashes,10 sec after turning on. after power outage
Hi, thank you for visit fixya.
Do you need replace both stk 392-110, and check any resistor (2.2 ohms) for blown or open. You can replace this IC's for stk 392-150d9f769b.jpg
May 12, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-61HX42F turns on, but wont stay on.
you need to change the stk 392-110 (2 ic ) and some resistor around the area ok
Sep 08, 2008 | Panasonic PT-61HX42 61" Rear Projection...
Panasonic model# PT-47WX547 is not working
how many times does the LED blink ? Thats a error code.
Jun 29, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
82 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
