Question about Philips GOGEAR SA6045 MP3 Player
I downloaded the philips media converter but it does not recognize my gogear vibe.it says to connect a philips device to the system which i did.my device is SA1VBEO4K/17
I had the same problem. I finally discovered what to do, as nobody seemed to know what to do, even Philips. Here is what I did to get the program going, even though it didn't see the connected GoGear Vibe (which Songbird did see as connected.)
1) Find where your Media Converter is installed. Mine was located at C:\Program Files (x86)\ArcSoft\Media Converter for Philips2) Locate the file named "MediaConverter.SET", which is in the folder mentioned in step 1.3) Use a text editing program, like notepad, to open the file you found in step 2.4) Within the file, locate the line that says "ProfileNeedActivation=1". In my file, it was on the 31st line.5) Change the line from "ProfileNeedActivation=1" to "ProfileNeedActivation=0" That is, change the number 1 to the number 0 (zero, no the letter O)6) Save the file.7) Run the program & enjoy.
A couple of notes: You may not be able to save the file once you're done editing. On my system, there were permission issues preventing me from saving the file directly. When I tried to save, notepad informed me that I couldn't save in the folder, and offered to allow me to save to my Documents folder. I did that, then copied the file from my Documents folder into the correct folder, as found in step 1. When copying, I chose to copy and replace the file. When I did so, the system required Administrative rights, which I allowed. That worked.Another point to pay attention to, if you use notepad to do the editing... When you go to save the file, it will default to saving as a .txt file. That is, it will take your file named "MediaConverter.SET" and try to save it as "MediaConverter.SET.txt". Make sure you either rename the file properly when you're done, or select the file type of *.* (as opposed to *.txt) when you save.
Ok, hope that helps save someone else the frusteration.
Posted on Apr 20, 2012
Use arcsoft media converter or visit philips website and look for your device model, download "media converter for philips"
Posted on Jan 14, 2012
  • 32 Answers
Hi, friend, the aHisoft Video Converter is just prepared for you, It is a Total Video Converter that can convert video to MP4/MKV/WMV/AVI and other popular formats such as: AVC, FLV, MP-1, MP-2, 3GP, 3GPP, Mov, M4V, ASF, SWF, VOB, DV, Super VCD, VCD, DVD and HD video.
so i think it will be helpful, you can search it on google
or visit http://www.downloadvideos-convert.com
Have a nice day, my friend
Posted on Aug 24, 2010
  • Tyler Shults Nov 28, 2011
    no, these will not work, the GoGear Uses a Special Format Designed for it, SMV. it is a variant of mpeg, but it will not play mpeg. you will need to contact Philips Support.
How can i transfer pictures from facebook to to a philips gogear vibe 8g without it coming as a unsupported image
Use the synchronization software that came with the device, Philips Songbird. It will automatically convert most media to the proper GoGear friendly format during synchronization.
If you do not have Songbird, download it for Windows or Mac here:http://www.usa.philips.com/c/mp3-media-player/22126/cat/en/#/difference/philipssongbird.
If you've found this information helpful, please indicate as such.
Apr 01, 2013 | Philips GoGear ViBE Digital Media Player
Just purchased Philips GoGear Vibe mp3 video player 8 computer does not reconize it is connected
Your GoGear is likely in MTP connection mode, which requires proprietary drivers to connect. If you are trying to connect it as a standard mass storage device, switch the player to MSC connection mode. To do this, select "PC connection preference" in the Settings menu.
As an alternative, I recommend using the the Philips Songbird software that came with the device. This software is useful for automatically converting most media files to GoGear friendly format during synchronization. And, installing this software will also install drivers necessary for connecting the device in MTP connection mode. More importantly, when your corruption prone GoGear gets the familiar "file system error" screen, the software can be used to repair it.
Feb 28, 2013 | Audio Players & Recorders
Can i use itunes to download music to my philips gogear vibe 4gb device?
itunes uses an M4A file format. You will have to download a file converter, then convert it to mp3. try www.cnet.com and search for audio converter. Lots of free software to choose from.
Jan 11, 2012 | Philips GoGear ViBE Digital Media Player
Gogear vibe will not connect to either of my computers?
Uninstall the gogear driver- the media convertor- from the PC, then install once again the driver into the PC and then convert the media to be converted and copied into the player.If the driver is not installing then you will need to download the driver;
http://www.userdrivers.com/MP3-Player/Philips-GoGear-SA3104-SA3105-SA3114-SA3115-SA3124-SA3125-MP4-Player-Media-Converter-Software-1-0/
Oct 11, 2011 | Philips GoGear ViBE Digital Media Player
How do I download songs onto my phillips gogear cam
  • Charge your Philips GoGear ViBE for at least three hours before turning it on.
  • 2 Insert the small end of your mini USB cable into your GoGear ViBE. Insert the other end of this cable into one of your computer's USB ports. Turn your GoGear ViBE on by pressing and holding the "Power" button for two seconds.
  • 3 Insert the Philips GoGear ViBE software disc into your computer's CD-ROM drive. Follow the onscreen prompts to install it.
  • 4 Open "Computer" from the "Start" menu and locate the GoViBE icon to make sure it has been successfully connected to your computer.
  • 5 Navigate to your music files. If you're unsure about their location, start by looking in the "Music" folder under the "Start" menu.
  • 6 Drag and drop your music files from their folder onto the GoViBE icon in your "Computer" window.
  • 7 Right-click the USB icon with the green arrow, located in your taskbar, to disconnect your device. Click "Safely Remove hardware," then wait until your computer confirms that it's safe to remove the device. Disconnect the USB cable from both your computer and your GoGear ViBE.
  • 8 Select the musical note icon from the main menu of your GoGear ViBE to open your music files. Navigate to the sub-folders section, and select a song from either the artist, album, track list or genre. Press the "Play/Pause" button to begin playing a song
Oct 07, 2011 | Philips GOGEAR SA6045 MP3 Player
There was no cd in the package, can i download what i need online or do i need to return the player to walmart
Hi kriddle1...
No you do not have to return the palyer to Walmart...you can download theUser Manual, Device/Firmware manager,Media Converter softwear and others at this website.
Please take time to rate me
http://www.usa.philips.com/c/mp3-media-player/gogear-vibe-4gb-sa1vbe04k_17/prd/en/?t=support
Jul 31, 2011 | Philips GoGear ViBE Digital Media Player
I cant seem to be able to use my media converter for philips.I instaled it from my philips GoGear VIBE disk and it says I have to download alot of other stuf with it.
Ok, firstly, media converter is for video files only. For music use Windows media player or you can simply drag and drop files to your music folder under your gogear device.
Also videos downloaded directly from the internet may not work properly on the player. You have to first convert them into a format that is suitable to the player using Philips media converter.
Download the Philips Media Converter software. Make sure corresponding Codec for playing videos is installed before downloading. The codecs are required to play videos on your player. To download Codec, you can:
1. Go to www.download.com/windows
2. Search for "directshow codec pack"
3. Download and install one of the codec packs from the list of results
Now to download video (suppose from youtube), connect your player to the PC and click the icon "Internet video downloader" at your desktop.
Open the website where your desired video clip locates. Move the cursor over the video you want to download until you see the Download icon. Double click on the icon to enable download.
After downloading, the Media Converter for Philips will then start to convert the video to the format that suits your player. If your player is connected to the PC, the video will be transferred to the player automatically.
Feb 19, 2011 | Philips GoGear ViBE Digital Media Player
Philips GoGear Vibe 8gb purchased today. Is it supposed to have an installation CD with it?
No. there s no CD by pack.
if you want to install the device manager (for repair and performing firmware upgrade) and media converter (for downloading media on the website and converting formats). you will have to go to the official support website.
if your vibe is of 2nd generation, you need Songbird, get it also by going to support website,
Nov 08, 2010 | Philips GoGear ViBE Digital Media Player
I have a Go Gear vibe. If I am connecting to the usb of my laptop it doesnot recognizes. I have installed the CD as well. Please help
Here is the Phillips site download the converter and the Device/Firmware manager
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA1VBE16K/17&scy=us&slg=en&mid=Link_Software....Open in another window....Rate please
Apr 07, 2010 | Philips GOGEAR SA6045 MP3 Player
I connect my device(philips gogear Vibe 4g.)The device shows as "connected device"on "Media Converter for Philips" program , and when converting VIDEO files is "done" , report screen shows "NO DEVICE...
Hello :
1: Unplug your Mp3 player . 2: Restart system .
3: Plug the Mp3 player again . If the system didn't recognize Mp3 player this time , then :
1: Go to [ my computer ] icon on desktop .
2 : Mouse right click .
3 : Scroll down to properties .
4 : On properties click [ Hardware] .
5 : Click [ device manager ] .
6 : On device manager check if all [ USB ports ] are properly installed and working fine .
7: If there are [ question marks or wrong marks ] on the ports then they don't work properly .
This is what you need to do , if they don't work properly ;
1 : Right click on the none working ports .
2 : Scroll down to properties .
3 : On general click [ reinstall the previous program ] .
8f47b2d.png My computer icon .
Device manager
USB mass storage device problem [ not working properly ] . Here you should right click on the none working device then go to properties and then ,
f4d6255.jpg\
Troubleshoot .
I hope this will help .
rate please !
Mar 27, 2010 | Philips GoGear Flash MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
478 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
