Question about Logitech V10 Computer Speakers
Cable doesn't work - sound out of one speaker
Our health education dept bought a pair of Logitech v10 2.0 USB laptop speakers and all of a sudden the cable doesn't work. I connected a mini-phone stereo male to male cord I use for something elese and it did work. Has there been a problem with the cable in the past? Do I have to find a replacement cable at a Radio Shack or other electronic store?
Andre
  • Logitech Master
  • 3,498 Answers
If you need to replace the cable.
try one of these;; I use (and trust!) Monoprice often and Newegg for more specific computer internals..
Never Miss Deal
Computer Parts Laptops Electronics and More Newegg com
Posted on Sep 10, 2017
SOURCE: No sound
Make sure you've got your V20's set as the default sound playback device.
Control Panel -->
Sounds and Audio Devices -->
Tab 'Audio'; select 'Logitech USB Speaker' in the dropdown list in the first item on the tab.
just a thought...
Posted on Jan 01, 2008
  • 84 Answers
SOURCE: Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Posted on Feb 11, 2008
SOURCE: How does Logitech X-540 speakers connect to a laptop?
can i just cut all the wires into one?
Posted on Jul 26, 2008
SOURCE: Logitech X-240 Sound Problem
I live in the Netherlands and i hear radio from UK, Russia and other languages. It's true it's in evening. Weather here now are rain in thunderstorm, i thought thunderstorms maybe could be the problem. Yesterday evening i heard nothing of the radio station. Hearing that radio staions is against FCC rulles. So it's possible to complain about it to radio stations. Im going to contact Logitecht tmorrow about this problem. I keep you updated.
Posted on Oct 28, 2008
SOURCE: Right speaker doesn't work
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
HOPE THIS HELPS
Posted on Feb 18, 2009
How to charge ematic esb112x speaker
It's a relatively cheap speaker. If it doesn't charge via usb the speaker is defective. No repairs are available.
Mar 27, 2014 | Audio Players & Recorders
Volume stuck on mute for wireless speakers
After pairing it, have you tried to go to your sound settings in Control Panel and selecting the bluetooth device as your standard sound device?
Oct 25, 2012 | Computers & Internet
I have actually lost my satellite speakers that came with the Logitech Z-2300. I am wondering what my best option is. I can't seem to find anyplace that sells these kind of speakers separately. I...
Hi
http://www.livedigitally.com/2005/09/05/logitech-z-2300-speaker-system/
It would appear you need 2 x 1/4 inch (3.5mm) jack to RCA cables, one for each channel and each speaker, left and right, rather than just the 1 cable ("..and a mini to RCA cord...") you seem to have bought.
The Yellow and Black RCA ports appear to be the Left and Right speaker channels respectively.
The output cable with a green jack that connects to the green jack on the computer's sound card seems to be tied in with the wired Remote Control.
I would have recommended getting a pair of passive 40W RMS Logitech Stereo Speakers.
As long as the speakers you have match in terms of Wattage and Impedance, you should be okay.
I hope this helps.
Aug 26, 2011 | Logitech Z-2300 Computer Speakers
I bought some surround sound speakers 3-5 years ago and they recently have not been working properly. First I have to make sure the external sound card is plugged into the computer so it will register it,...
first did all of these speakers work together at any stage
if not you will have to get yourself an external sound card possibly a usb portable/removable sound card
Dec 07, 2010 | Logitech X-530 Computer Speakers
Headphone jack of my laptop does not work properly. I get sound from both the laptop speakers and in the headset. So i bought a USB audio device. Still the sound comes from laptop speakers and there is no...
You have to set the software in order to connect the wright way. with a USB device it will never work.
go to the properties of your audiocard and theire select what you want
Feb 13, 2010 | Logitech 250 Headset
No sound on Logitech Z Cinema 2.1 speakers.
1. Check Output cable properly connected to the computer in Green socket.
2. Check computer Volume Balance.
- go to start- control panel-sound & game controller
- check ur volume mute/unmute, volume all balance
3. check sound drivers/update driver
- go to - My Computyer - right click - properties - hardware - device manager - check sound hardware - Uninsall all sound driver
- Then Scan in device manager. it will automatically install again.
4.Then check output volume.
Feb 01, 2010 | Logitech Z Cinema 2.1 2.1 Speakers
I have just bought the logitech x-540 speakers and have found that they have 3 input cables (one for each of the left, right and centre speakers). However my laptop only has 2 input 'holes'. The...
Hi bud , What your laptop has is a 2.1 Channel Sound card , and your speakers are a 5.1 Channel Surround Sound system ...So in order to get the Real pure surround sound , Sound out of the speakers you will need to buy a 5.1 Channel Sound card...
Hope you come right bud
happy new year :)
Jan 06, 2010 | Logitech X-540 Computer Speakers
Logitech x-540 speakers wont work??
unplugg your hdmi cable and use a regular monitor cable then plug your speakers in to your sound card
Feb 27, 2009 | Logitech X-540 Computer Speakers
No sound from logitech speakers, they worked 2 songs and then stop working i ve got control whit buttons on top of speaker but no sound please help
FOR MACS... Last February(08) I bought the V20 Logitech speakers for my Apple iBook laptop. I got them to work. Hadn't used them for about a year and had forgotten how to get the sound to emerge. I went to System Preferences. Clicked on Sound. I had plugged in the USB. Didn't show up. Unplugged it and plugged in again and there it was! I clicked on it and the sound came through immediately. So wait to plug in the speakers until you have opened Sound. (And Pandora (superb Internet radio station) is playing flawlessly.) I am not familiar with PCs. Sorry.
Jun 14, 2008 | Logitech V20 Computer Speakers
Logitech V10 Computer Speakers Logo
74 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
