Question about Pioneer DEH-P680MP CD Player
Back speakers have stopped working
My front speakers are working fine but I had to wrap my mute cable as it was grounding out and when I put it all back in both my back speakers don't work. What could this be? I've already checked all the wiring.
  • 93 Answers
Try Doing Grounding The Mute Cable To Somethign Else And MAke Sure Its Not Touching Anything And Make Sure Your Soeaker Wires Arnt Touching Each other
Posted on Jun 30, 2009
How can I get sound from my radio
If a cable speaker is shorted to ground or (in your case) the short was on the casing the radio mutes the output to save the amp. So
remove all cables and put them back to the radio & connect the speakers one by one to see if it works or mutes again
Sep 30, 2016 | Jensen Jta-475 Cd Player /turntable...
I have a 2010 cobalt lt. Today both my feont speakers quit working. And now my turn signals make no noise. Or the door chime or the seatbelt indicator does not work. What causes this and how do I fix it?...
The chimes an turn signal noise come out driver door speaker . Both front speakers not working could be a blown circuit fuse inside the radio or just blown front speaker channel . Your best bet , take it to a GM dealer or someother qualified repair shop . You have no idea of the complexity of this . The radio can set DTC'S - diagnostic trouble codes , believe it or not !
DTC B1025, B1035, B1045, or B1055
DTC B1025 01: Audio Output 1 Left Front Circuit Short to Battery
DTC B1025 02: Audio Output 1 Left Front Circuit Short to Ground
DTC B1035 01: Audio Output 2 Right Front Circuit Short to Battery
DTC B1035 02: Audio Output 2 Right Front Circuit Short to Ground
DTC B1045 01: Audio Output 3 Left Rear Circuit Short to Battery
DTC B1045 02: Audio Output 3 Left Rear Circuit Short to Ground
DTC B1055 01: Audio Output 4 Right Rear Circuit Short to Battery
DTC B1055 02: Audio Output 4 Right Rear Circuit Short to Ground
Each of the audio output channel circuits (+) and (-), at the radio and audio amplifier have a DC bias voltage that is one half of the battery voltage. When using a DMM, each of the audio output channel circuits will measure approximately 6.5V DC. The audio being played on the system is produced by a varying AC voltage that is centered around the DC bias voltage on the same circuit. The AC voltage is what causes the speaker cone to move and produce sound. This voltage will vary depending on what type of audio is being listened to, talk or music, and type of music, as well as the volume setting of the system. Low volume and talk settings will measure around 1V AC and less, where constant music may measure 3V AC and slightly higher.
DTC B1287 01: Amplifier Control Signal Circuit Short to Battery
DTC B1287 02: Amplifier Control Signal Circuit Short to Ground
DTC B1287 04: Amplifier Control Signal Circuit Open
The radio provides a remote amplifier mute output circuit to control overall muting of the remote amplifier. The amplifier receives pulse width modulated (PWM) signals on the control circuit at varying duty cycle percentages for controlling muted and unmuted functions of the amplifier. Circuitry internal to the radio monitors the remote amplifier mute circuit for faults and sets the appropriate DTC when faults are detected.
Feb 16, 2018 | 2010 Chevrolet Cobalt
I have a jvc kdavx1 trying to hook up to a 2000 buick reagal need to know how the wires hook up
Please let me know if you have questions, and thanks for using FixYa.
2000 Buick Regal Car Stereo Install Diagram jvc kdavx1
Radio Constant 12V+ Wire: Orange yellow
Radio Ignition Switched 12V+ Wire: Yellow red
Radio Ground Wire: Black/White black
Radio Illumination Wire: Gray/Black orange/white
Left Front Speaker Wire (+): Tan white
Left Front Speaker Wire (-): Gray white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Dark Green gray/black
Left Rear Speaker Wire (+): Brown green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Dark Blue purple
Right Rear Speaker Wire (-): Light Blue purple/black
parking brake: blue light green
For this last wire, access the back of the parking brake to find a switch with a blue wire. Peel some insulation from the wire and wrap the stripped end of a 3 foot piece of 16 or 18 gauge wire around the stripped section. Solder and wrap the connection with electrical tape, route the wire to the jvc, then strip and solder the other end to the pigtail of the head unit.
If you are also installing a camera seeing behind you when backing, you will need to run a wire to the back-up light on the driver side reverse light (light green) wire along with your video cable.
May 30, 2011 | JVC Car Audio & Video
Front left speaker stopped working. I use the system with my computer (full volume on computer), and usually half volume on the speaker. I've had the speaker for a few months now. I looked the wiring to...
You 'looked' at the wiring but have proven it is defective by swapping the speaker independent of the wiring. What's next? Replace the bad wiring.
What happens when you put a working speaker and wire on the front left output?
Apr 14, 2011 | Samsung HTC550 Theater System
99 Mazda Protege and Parrot CK3100 Problem
Some of the autoradio has the mute function already included to the autoradio, and when you add it, it may create troubles.
Then try without the mute cable connect and see if it is working.
Did you select the harness which the right reference of audio system?
You will have to ensure it.
Jan 24, 2010 | Alpine Type-E SWE-1042 Car Subwoofer
Dimension 4700 my headphones work fine but i cant
Are you have the headphones and speakers both pluged in? When you plug in headphones the speakers get muted. You need to change your sound settings back to your sound card if you use usb headphones. The plug on the front of the 4700 also automatically mutes the speakers.
Dec 13, 2009 | Dell Dimension 4700 PC Desktop
Audio fuzzy or cuts out
Could have a loose connection in the audio section or a problem with the output IC . Also does this happen on the RF input and your A/V inputs or just one of these. If its the A/V inputs only your having this problem check your cables .
Nov 26, 2007 | RCA HD61LPW165 61" Projection HDTV
Buzzing noise coming from my speakers....
I just did this last week, i had the same problem all you have to do is grab some speaker wire and wrap it arround the RCA's(around the metal or gold piece outside the RCA) that go to your voice AMP and then ground the speaker wire(the one you wraped the rca's with). this will work. NO Noise filter will work cus I tried it
Sep 19, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Audio feedback
this maybe was cause by a grounded connection.
Please try put a grounding wire from your stuff to the ground. this elimanate noise.
if this not work, do not rate me instead notify me for another solution im online 12 hours day.
Sep 13, 2007 | Acer TravelMate C110 Tablet PC
Logitech X-530 speakers
go to start -> control panel -> sound and audio devices. in the volume tab, speaker settings area click advance. make sure the speaker setup is 5.1 .if not, select 5.1 and click ok. now cilck advance in device volume area. u should c a volume slider for rear and front speakers. if u dont c the volube slider, click options->properties.in the show the volume controls section put tick on the rear and front boxes. clik ok. and check weather they are not mute and increase the rear and fron volume to a decent lavel. there may be also sound card specifi settings that might need to be re-configured if this does not work let me know the name and model of ur sound card. Good Luck Julian Leonardo
Jun 15, 2007 | Logitech X-530 Computer Speakers
Pioneer DEH-P680MP CD Player Logo
47 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
