Sony RDR-HX820. Just replaced Harddrive 160 Gb with new. Does not recognise the HD. Formatted to NTFS.
  • 2 more comments
  • dsl610185 Jun 30, 2009
    Hi Guru.
    This is an almost brandnew player/recorder. I believe there might be a problem in the formatting of the new HD. Is there a better option than NTFS ?
    Am I able to install a larger HD - like 500 Gb ? I bought a new one just for the purpose.
    I am sorry, but I am no expert in the field. My field is computers.
    Gunnar
    Hi again Guru.
    Well, I swapped the cables as u said. CD works either way, and the HD doesn't - either way.
    I get "HD error". So, I tested the HD on my computer again, formatted it again. It's perfect.
    I can see nothing wrong with neither the power cables nor the other cables. They are all like new, and in the light of the above, the cables must be OK anyway. Yes ?
    Gunnar
    I have tested everything as suggested. Perhaps someone else will answer the questions I asked.
    Like: I formatted the GD with NTFS. Is that correct, or is the FAT format better ?
    Will the recorder/player accept a larger HD ? Like for instance a 500Gb drive that I bought ?
    Gunnar
  • dsl610185 Jul 01, 2009
    Hi Greenspan.
    Many thanks for your email. I will try your suggestion, and come back.
    It makes a lot of sense. Perhaps there is an update of the firmware out there too, do you know ?
    Gunnar
  • 5,807 Answers
Can you try other format option? not using ntfs
try FAT or FAT 32
Posted on Jul 01, 2009
    President:
  • 1,734 Answers
Try to use the old HD, you can not use any optional HD as they are recognized by the player. Sony uses a proprietary HD format and NTFS will not be recognized.
Insert the old HD and do a factory setup in the menu "others". Select the "basic" settings, then "start". Press "Enter" when "finish" appears.
Posted on Jun 30, 2009
    Brigadier General:
  • 3,917 Answers
The Hard Drive and the CD are both connected to IDE controller on Motherboard
HDD is usually on "Port #1",,,and CD is on #2
They're the SAME,but different Channels.
If Your CD is working,,,like when trying to Install SE,
Try plugging the Hard Drive into the Cable that the CD is using.
Unplug it from CD,,and stick it in HDD.
That's a different channel on the drive controller.
You are Testing the HDD >>>on a Known Good
CD's #2 IDE Channel & CD Cable
If that happens to work,,,
then swap the Motherboard end of the "CD's" cable( which now has the HDD on it),,,plug it into Original HDD port on Motherboard.
If it continues working,,that indicates the original HDD CABLE is bad.
That is "Working HDD" + Working CD CABLE + #1IDE HDD channel.
Baically the Original Configuration,,but using a Proven Good CD CABLE
If it quits working when switched to IDE #1 connector on the motherboard,,,
then IDE#1 Port/Connector on the Board is dead.
Cu we now know HDD works & CD Cable is Good---so it's Gotta be a bad #1 IDE HDD Channel.
You CAN use Both HDD and CD on Same Channel/Same Cable.
But it makes HDD run VERY Slow.
If it's Cable,,Cables are Cheap.
(Good Possibility it's only the cable)
If #1 IDE Channel on Motherboard is bad...
You can get a separate IDE Controller Card for $10~20 which plugs into any available PCI Slot.
If it IS just a Bad cable,,,
chances are you have an "Old Style" 40wire ATA33 cable.
New Style 80wire ATA 66/100/133 Cable is an ideal replacement and recommended.
The Connectors are the same,,,just the ribbon cable/actual wire is different.
You can also go into Bios Setup Screen,,,and to Drive Setup section---and See if You can get it to "Auto-Detect CD"
--Before doing any mechanic work swapping cables around.
If it Does find CD,,,go ahead and plug HDD into CD Cable
You also might wanna FEEL the HDD,,to see if it's actually Running.
It's RARE,,but it could also be a power Supply Connector problem.
HDD may not be getting any power??
Rare,,but it happens.
Thanks for contacting Fixya.
HARDDRIVE ERROR ON SONY RDRHXD860 DVD RECORDER
http://www.avforums.com/forums/attachments/blu-ray-dvd-recorders-media/68631d1198812029-succesful-upgrade-hdd-rdr-hxd970-how-upgrade-hdd-sony-x70-series-dvd-recorders.pdf You shouldn't use a computer to format the drive as the dvd recorder will do that for you.
Oct 25, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
I have just acquired a 500 GB USB HDD and its NTFS formatted, it doesn't show when I plug in SONY BRAVIA USB port
I think it should also come with a power supply also.Does it have lights on it. Try a different port.
Mar 05, 2012 | Computers & Internet
Hi, guys. Just received your Iomega eGo Helium 500 GB external hard drive and successfully backed up the HD on my MacBook Pro. My question is whether your HD can be formatted/configured so I can also...
Yes all external drives can be formatted but formatting will always wipe off everything on it. If you want to format it you can right click on it when it appears in Windows Explorer. You are usually offered the choice of file system FAT or NTFS. FAT is limited to a file size of about 4 GB, so usually choose NTFS, I am presuming you are talking Windows system. Then you would have to copy your files to it once again.
Nov 02, 2017 | Iomega 500GB eGo Helium Portable 500 GB...
I have a new 500GB Iomega external harddrive. It is now loaded to near capacity with films etc. When I plug it into my USB port on my Sony TV it does not seem to be recognized. When I plug it into my...
1. The TV and drive may not be compatible with each other. 2. The formatting of the drive could be the problem. The USB memory stick would be formatted as FAT32, but the Iomega drive would have been formatted as NTFS. Maybe the TV can only read drives formatted as FAT32 and not NTFS.
Jun 28, 2010 | Iomega 34512 eGo USB 20 500GB Portable...
Formatted and installed a WD 60gb hd as slave and is not detected
Did you format this drive to NTFS or FAT32. It may not rcognise it as a slave drive on a format other than NTFS
Apr 11, 2010 | Western Digital Caviar WD600BB 60 GB Hard...
I Transferred a hd into this pc from another pc. This hd is ntfs format.The second hd in this pc is the fat format. In explorer it shows the second hd as the d drive. When i click on it it says this hd is...
First of all, I hope the harddisk which has the operating system on it, and which the system is booting from is NTFS formatted. Try and crosscheck this first. Then after doing this, try and assign a new drive letter to the harddrive that is showing error from the Systems Management Page.
This is how you do that : Right-Click on My Computer Icon, Go to Manage, Click on Disk Management, Then when you get to this place, You should see ALL the HardDrives installed on your system including the one singing for "format me"...lol.
Then locate and right-click on the harddrive, and select "Change Drive letter and Paths", and select any new, unique letter for your HDDrive. then click on OK.
Hope this helps.
Goodluck.
Jul 13, 2009 | Computers & Internet
Partitioning ext. "MY BOOK"
You don't need to format it. You can also just convert it to NTFS and keep the current data.
There is also no requirement to create more than one partition.
In the command prompt window, type
convert drive_letter: /fs:ntfs
You'll find this in Windows Help. Just search for convert ntfs.
Jun 09, 2008 | Symantec Norton Partition Magic-8.0...
Televison & Video Logo
481 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
