Use a sturdy pin or thumbtack to push out the pin from the little hole on the link.
Make sure to examine the watch and which links have pins.
Some watches are designed to have a row of removable links with pins.
Remove one end of the band from the actual watch itself. Then remove links as you see necessary.
You may need to use something a little stout like a butterknife to tap the pins out from the links.
The pin on the watch itself has spring loaded tips, push them in and it should release the watch from the band.
TAG HEUER watch bands are costly. Over here in England they cost from £60 to £250 (depends on type, model, e.t.c.), but can rocket sky high if you have one of expensive models. I would suggest to add a few links to your existing band. This will be cheaper than to buy completely new band. Visit your nearest watch repair store and ask how to do that. Watchmaker should be able to order extra links and fit them for you. If you insist on a new band - ask watchmaker to order it and fit to your watch.
It's very difficult. You have to take the decorative link covering off first, then continue with the actual stretch band by following these directions.
