Question about Dometic RM2652 Refrigerator
What's a safe temp. for the refer in a Dometic 1402 side by side? Thanks Ted
  • 11,896 Answers
Anything under 40 degrees
Posted on Jun 30, 2009
Dometic nda 1402 will not cool, just replaced code 13 heater..hi hi comes up on display panel
the 13 code was the heater element in freezer check fusible links and heater elements
Jan 26, 2017 | Dometic Refrigerators
Waht makes a Dometic 1402 work normal on electric but the refridgerator warms up when on gas? Freezer warms up slightly but refridgerator 10 to 15 degrees?
Dometic had several recalls for that problem, faulty thermostat I believe. Mine does the same thing, but I haven't taken it out to replace the thermostat / thermocoupler.
Aug 20, 2014 | Dometic Refrigerators
Dometic model number NDA-1402 freezer will not get below 21 degrees
check door seals if ok unplug thermistor from back let run if ok replace thermistor if not bad board or cooling unit
Jul 20, 2014 | Dometic Refrigerators
Sounds like you need coolest top up. Local freezer expert should viable to top out your system
Jul 20, 2014 | camperpartsworld.com Dometic NDA1402...
Dometic 1402 won't self defrost
Verify that you have at least 11.5vdc, you will typically have around 13.6 but sometimes power loss will cause the unit to not function properly. If you do have good voltage and the refrigerator is going into defrost mode but not defrosting the culprit more than likely will be a bad defrost heater.
Oct 06, 2013 | Dometic RM2620 Refrigerator
Need a door gasket for a dometic model 1402
Although you might be able to match it up with other manufacturer door gaskets and it work. Dometic door gaskets are available from most RV places or direct from Dometic.
Feb 04, 2012 | Dometic Refrigerators
Dometic rm2611 not restart after cooling box normally, then warmi
I would replace the thermister and also check the gas soleniod. Don't those get weak once they get hot or warm. Hope this helps.
May 10, 2009 | Refrigerators
Dometic RM2652 Refrigerator Logo
160 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
