Question about Garmin nuvi 250 GPS Receiver
I have agarmin nuvi & it has frozen on the where to page nothing is happening on the touch screen or the on off switch any suggestions
There is a quick, easy way to reset your Nuvi, but it will result in loss of all saved points. If at all possible, back up your data files first! To reset, do the following:
  1. Turn the unit off.
  2. Hold your finger (or eraser end of a pencil) in the lower right corner of the touch screen.
  3. Turn the unit on, keeping your finger in the lower right corner.
  4. After a few seconds, a screen will appear asking if you want to reset.
  5. [REPEAT: YOU WILL LOSE SAVED DATA.] Select Yes. The unit will reset.
Posted on Jul 22, 2009
  • baltiman Jan 13, 2011
    I have reset it but it now says it has no data/maps for navigation
    Brigadier General:
  • 4,090 Answers
Only one and you wont like it....
The chip is possibly damaged and is expensive to repair. Not generally considered a warranty job so thye bin is your cheapest way to avoid costs.
Always avoid plugging in GPS and starting engine. plu in after engine started, helps preserve the chip and the other sensitive components
See the FAQ on Marbella Australia, most of their tips pertain to all GPS units that othr companies would do well to provide, rather than making money from repairs due to no information!
Posted on Jun 30, 2009
My 650 nuvi is not functioning correctly. The screen is frozen and does not respond to touch. It was frozen in the page saying that I needed new maps. Unable to install new mapms through the internet I...
Of course it's still frozen because the touchscreen is defective. If your unit's serial # begins with a 12P, 14V or 143, then you have a style of touchscreen that can fail. Please see this link for more info.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Sep 08, 2010 | Garmin Nuvi 660 GPS Receiver
My Garmin Nuvi 1390 has frozen on the 'loading maps' page I turned the unit on holding down the bottom right hand corner clicked yes when asked do I really want to erase all user data. What if the device...
I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Take care.
Jul 04, 2010 | Garmin nuvi 1390T Car GPS Receiver
Garmin Nuvi not acquiring satellite
I am having the same problem with my nuvi 350 and its about the same age. I read on another post it may need a new battery but you need to send it to garmin. I am going to contact garmin directly.
Aug 20, 2009 | Garmin nuvi 350 GPS Receiver
Touch Screen on my Garmin doesn't work
I believe simply pushing the reset button will fix your problem. The reset is located under the frame around the screen. To remove the frame, use your finger nail to carefully lift it off the screen. Then just push the reset button and you should be back in business.
please rate my answer as a fixya! Thanks.
Feb 14, 2009 | Garmin nuvi 200W GPS Receiver
My ? Nuvi 710 GPS froze. I restarted it , now all I can get is a blank screen with a black dot in the bottom left corner and a message saying press dot. Holding the off switch over to the left makes it...
My ? Nuvi 710 GPSicon1.png froze. I restarted it , now all I can get is a blank screen with a black dot in the bottom left corner and a message saying press dot. Holding the off switch over to the left makes it restart but still goes back to the same screen Is there any way I can fix this?
Apr 22, 2008 | Garmin GPS
Screen is frozen
Are you saying that nothing at all happens every time, or sometimes you get the wrong thing i.e. you touch Prog and Rep screen comes up? Have you ever recalibrated your screen? This should be done regularly - at least every six months, but I do mine monthly. The catch is that in order to do this, you need to access the Set Menu and if your screen is not responding at all this would be impossible. In the Set Menu on the last page (I think) there is a "Color Touch Screen Adjust" button. Use this to access the calibration screen, and you must touch exactly in the centre of the two crosshairs until they turn green. Instructions are on Page 31 of my manual.
Dec 26, 2007 | Husqvarna Designer I
Garmin nuvi 250 GPS Receiver Logo
340 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
