Replace Coupling, Now it's making a rapid CLICKING noise.
I have a Kenmore 90 Series 20922990 Washer. The agitator had stopped working and the machine also would not spin. I searched online and found out it was probably the motor coupling. I followed the instructions, opened it up, and replaced the coupling (it was broken). I put it back together, and it worked nicely for a few minutes, then it started making a very rapid clicking sound and stopped agitating. I opened it up and put back two more times to make sure everything was in place. Now I'm afraid there is something else wrong. Also, when I took it apart the FIRST time, there was a puddle of dark brown/black gunk under the machine.
  • umm_mahmoud0 Jun 30, 2009
    Hi, Thanks for the info!
    No, I never turned the machine on its side or tipped. I found instructions on how to open it from the front. Is the bad transmission what's causing the awful grinding/clicking sound? Also, are there any pictures somewhere online to help me along? That was really useful when I replaced the coupling.
  • 5,911 Answers
That dark brown gunk is the oil from the gearcase (transmission). If you had the washer tipped back, or laid it down, you shouldn't have. The oil will leak out. Leaking oil is also a symptom of a transmission going bad. It sounds like you need to replace the gearcase now. They aren't that expensive if you shop around. Searspartsdirect.com and appliancepartspros.com carry them. The part number is 3360629. The following link explains how to replace one if you decide to perform this repair yourself:
http://www.fixya.com/support/r699497-replacing_gearcase
If you have any questions, plese let me know. I hope this helps you.
Posted on Jun 30, 2009
  • Jeff Rockwell
    Jeff Rockwell Jun 30, 2009
    More than likely, the grinding noise is coming from the gearcase. Needless to say, a gearcase devoid of oil won't last long. You can use appliancepartspros.com or searspartsdirect.com for exploded view diagrams of your washer. Use your model number for your search criteria. The gearcase will be listed as item 9 under the "Brake/Clutch/Gearcase" heading. I do not have any other photos to show you. If you need more assistance than the step-by-step instructions I gave you, please let me know and I can guide you through the process. It's not as difficult as it seems. NOTE: If you order a new gearcase, make sure it remains in the upright postion when shipped. There are instructions on the outside of the packaging, but sometimes the delivery personnel don't follow this advice. If it is delivered laying down, the oil can leak out. I've experienced this before.
I have Kenmore 90 series Model 110 20902 990. I was washing sheets and the agitator got jammed. I removed everything and now it will not spin. There also is a clicking sound. Is the transmission blown or...
The coupling below the tub and agitator has broken. the coupling hooks the motor to the transmission. Very easy repair and parts are cheap, around 20.00 for the part. While your at it get a set of agitator dogs. These are plastic tabs that go in the agitator, they are what causes it to agitate in one direction. These are also only 10.00 and it will save you a service call later. There are many posts and instructions on this repair and the best thing is you can do it yourself with little tools!
Feb 05, 2011 | Kenmore Washing Machines
Series 70 washer make a clicking sound when
could be your motor coupling, something stuck between the agitator and drum, tranny
Feb 14, 2010 | Kenmore Washing Machines
My kenmore 90 series filled with water and went it got to the rinse cycle it quit working and just started making a grindling sound. help please
sounds like the motor coupler broke. it's a plastic piece near the motor and very easy to replace.
here'e a video you can watch to make it easier:
http://www.youtube.com/watch?v=nM4DW2bq7o0
Jan 21, 2010 | Kenmore 22422 Top Load Washer
Kenmore 90 Series fills with water but would not agitate or spin
You have a problem with the motor coupling. Top-load washers use what's called a direct-drive system, meaning it does not use a belt but what's called a "motor coupling". I probably replace 5 a week because these little guys break because of 2 reasons that i've found.
1) The break mechanism is too dry and causing the basket to stop at a holt, which puts a lot of strain on the coupler.
2) They break because of over-loading. I don't think you're over-loading though because it was find for 5 straight years.
Good luck to you. The repair is kind of hard to do on your own for the first time, so I would call an authorized technician. It will run you anywhere between $90 to $120 at most.
Best of luck!
Jul 14, 2009 | Kenmore 22422 Top Load Washer
90 series Kenmore washer won't spin
I have had this happen on a Kenmore in the past, and it was the motor coupling. It is a plastic part, and if it cracks your washer will not spin anymore. If you have the repair parts list, or can find it online, you will find the part I am referring to. Good luck.
Jun 03, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
Apr 28, 2009 | Kenmore 23822 Top Load Washer
Kenmore Series 90 washer. Will pump the water, does not spin
Replace the motor coupling between the motor and transmission its very easy if you tilt the machine back and remove the two screws holding the motor brackets.
Mar 28, 2009 | Washing Machines
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
303 people viewed this question
Top Washing Machines Experts
