Question about Black & Decker BDTF1010B Tower Fan
My oscillating fan has stopped oscillating how can i fix this
Pls check first if the mode was properly set, or if not follow the manual you own from the first you bought the item. or try to unplug the item and open the back panel look if the gears is loose or broken.
Posted on Jun 30, 2009
  • 3 Answers
This is my 3rd fan in the last two years I have bought. This time I thought by buying an expensive fan won't give any problems, but it is the same story.
Fan worked for couple of days, then it won't start again. I figured out from the noise it was making that it is due to friction. So I put some oil, then it started working, but it worked for a day only.
It is the regular fan, not the tower. Hope someone knows the answer for this.
Posted on Aug 02, 2009
I have this fan and unfortunately don't have a legend for the 5 buttons on top and what they do. is there a manual somewhere that tells me what each button does?
Hello, Chris -
I believe the Hawaiian Breeze tower oscillating fan operates much like the Aloha Breeze oscillating tower fan. I found an image for Aloha Breeze oscillating tower fan buttons, along with descriptions of what each button does.
I am not sure if the buttons on your fan are in a horizontal curve or a vertical alignment. However the attached image should help you figure out what the buttons on your fan represent.
Tower Oscillating Fan Buttons
1. Power - On / Off
2. Speed: slow, medium, fast
3. Timer: May be 15 levels; 1 / 2 hour setting for each timer level; Each touch of the button adds 1 / 2 hour of running time
4. Oscillation: Stop / Start fan oscillation
5. "Wind": Normal, Natural, Sleeping
http://www.fixya.com/support/t10019057-fan_will_not_start_lost
May 01, 2018 | Tower Dryers
I have a Holmes HAS1650 stand up fan and I need to know how to get it to quit rotating.
Not sure what you mean by "stop rotating"
I assume you mean to stop oscillating. There should be a knob on top of the motor housing that you push down to oscillate and pull up to stop oscillating.
If you mean to stop the blades from spinning there should be a fan speed control knob on the top of the motor housing that you turn to "O" to stop the fan.
Here is an instruction manual for a similar fan...
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-holmes-products-Site/Sites-holmes-products-Library/default/v1405596036669/documents/instruction-manuals/HASF1515R_HASF1516R-UC_11EM1.pdf
Jul 18, 2014 | Dryers
Can an oscillating fan be stopped from turning? It is made by Dayton and is 24"..................
I have a large shop/garage fan on a 4-foot stand. It has oscillation connection that can be loosened using a knurled thumb nut.
Dec 12, 2009 | Dayton Dryers
Lasko fan will not ocillate
check the oscillating gears usually made of plastic
Aug 28, 2009 | Lasko High Velocity Space-Saving Blower...
Internal Part's Guide for Model A0J-1201 fan
there will be a oscillation driving counter wheel present inside it which is made of plastic tat would have got damaged or broken so replace the wheel then ur fan will start oscillating
Jul 28, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
1VCF2 Dayton Oscillating Wall Fan
The speed control switch which is what the cord is attached to has gone bad. You can get these from grainger.com for the dayton line of fans.
Hope this helps
Jun 20, 2008 | Dayton (1UM39) Floor / Box Fan
LASKO fan problem
Check for a loose wire in the wiring harness
Sep 01, 2007 | Lasko 2530 Elite WindTower Fan
Fan makes clicking noise when oscillating
inside the motor there is a nylon gear that is broken. the oscillation operates off a gear connected to the motor drive.
Aug 27, 2007 | WeatherWorks CH-1850SFW Riviera Stand...
Black & Decker BDTF1010B Tower Fan Logo
1,225 people viewed this question
Top Black & Decker Dryers Experts
Are you a Black & Decker Dryer Expert? Answer questions, earn points and help others
