Question about Pioneer DVR-112D DVD RW Dual Layer Burner
Unable to copy dvd's using pioneer dvd-rw dvr-112d
Hi ..hope you can help me, i have been trying to no avail to copy and back-up my dvd's but when i try to copy them with this it keeps saying that there is a write error,,,,i have tried adding my files to my hard drive then copying them but the rw, still doesn't plays dvd's no problem but i can not use it to copy ?? any ideas
Sp xxxx
  • 2,427 Answers
Re: unable to copy dvd's using pioneer dvd-rw dvr-112d
Maybe the DVD have a copy protection system
you need to decrypt the original DVD's first then burn them off using shrink or nero recode or even dvd decrypter itself
Posted on Dec 30, 2007
0 characters
3 Points
Pioneer DVR-112D refuses to read CDs?
This unit has alot of issue with CD reading and writing probably its a problem with the lens of this player, so since its still new better take it to the store and have it replace..
Hope that helps........
Aug 10, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
PIONEER DVD-RW DVR-112D won't burn discs. G4, OS 10.4.11
So the driver is either 'malfunctioning' or it's you know what revision firmware the drive is using? Your disk authoring software may tell you this. The latest version is 1.22 which you can get by Googling PIONEER DVD-RW DVR-112D firmware. Or go to the Pioneer website. I do not know how to upgrade the firmware for the recorder in MAC Land, in PC Land the firmware update is a simple executable file.
If you are running this version you can try to reflash it. Have you tried another brand of DVD disc? Some discs are less compatible than others. Try another brand of DVD
Oct 13, 2009 | Pioneer DVR-112D Burner
Cannot copy files from computer to Pioneer DVD-RW DVR-112D
Try using another burner use Nero burning ROM or Roxio Creator DE.
Nov 17, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
My dvd burner is missing the drivers
hi. if you will go to...
scroll down the page to dvr 112 series firmware the last download for that section should be your driver.
hope this solves your problem. let us know.
Oct 02, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer dvr 112d power calibration error
updated firmware will not help. this is a known issue with Pioneer DVR-112D, drive needs to be replaced. Contact Pioneer for a free replacement, here is the url
The issue occurs only under limited environmental and use conditions that are not typical for most end users, so Pioneer anticipates that most users will not be affected. If you are not experiencing any issues currently, there is no need to take immediate action. The service issue does not pose any health or safety risk.
Pioneer is aware of a potential issue with the above drives’ CD (not DVD) read/write capability. Under certain environmental and heavy use conditions, the above drives may become unable to read or write to CDs. To address this issue, for any of the above model drives that become unable to read and/or write to CDs, Pioneer will provide a replacement unit (which may be a newer model number) at no extra charge, shipping prepaid, subject to the terms and conditions of Pioneer’s standard limited warranty(excluding duration).
Again, we anticipate that most drives will not be affected. However, if your DVR-1810, DVR-2810, DVR-X122, DVR-112D, DVR-112DBK, or DVR-112DSV drive becomes unable to read or write to CDs, please contact Pioneer Customer Service by one of the following methods:
Complete an online replacement request form and submit it online. Once your model and serial number are validated, you will print out the completed form to mail along with the affected drive.
This online form is for United States customers only. For Canadian residents, please contact Pioneer Electronics of Canada customer service directly at 877-283-5901.
Mar 07, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
have you tried cleaning the lens? i also had this experience with my dvd rom and what i did, was cleaned the lens.
tell us what happen after you clean it ok.
Jan 14, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer dvd-rw dvr 112d
look for the mark at the top, MA for master, SL - slave, CS - cable select, these three are main connection for IDE designation using the plastic jumper, just follow where it is in your pioneer.
Jan 13, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer dvr-112D won't read CDs anymore
There would be a problem with cd reader lens
sou need to change it from the company if its in a warrenty or get it repaired from a person who is in to Chip Level Repairing
Jan 05, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer DVR-112D DVD RW Dual Layer Burner Logo
109 people viewed this question
Top Pioneer CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Gareth Cockram
Gareth Cockram
isaac johny
isaac johny
Are you a Pioneer CD and DVD Burner Expert? Answer questions, earn points and help others
