Question about Dorman Auto Parts Dorman Cv Joint Boot Installation Tool Air Compressor Required; Tool Fits A + Npt Air Hose Nipple
Installing my CV Joint in my Suz
I need the schematics for installing the drivers side CV Joint in my 1991 four wheel drive Suzuki Sidekick. Can you get me them or can you tell me where i can find them? If you can that would be great. Thank You
  • 24 Answers
Buy a manual.  If you don't invest in that at a cost of $20 and some tools how can you be taken seriously.
Posted on Jul 07, 2009
I need to find starter diagrams 1991 suzuki sidekick
hello lisa
the a/t and m/t are different (auto and stick shifted)
but its here, posted vast time.s
see 91 full set, (sold my 91 back in 2010)'
http://www.fixkick.com/schematics-run.html
the starter failure page is here, fully covered
all tests
http://www.fixkick.com/nocrank.html
see diagram at bottom of page. link2
Jun 03, 2016 | 1991 Suzuki Sidekick
Tip
Front End Noise, Steering and Suspension
Noise in the front end of any make, model vehicle. Put a jack under the lower control arm and jack the left wheel off the ground, the trick is to try to get it at normal ride hight, grab the tire at the top and bottom and try to push and pull the top in and out inline with the ball joint. have a helper eye the ball joint and see if there is any motion(play) at the joint. If not, check the bottom the same way. if they are both good, try it side to side to check the tie rods for play, make sure the steering wheel is locked. Then do the same for the right side. If all checks good than it is probably the cv joint if the truck is four wheel drive, if it is not four wheel drive it's definately is not a cv joint because you don't have them. This Applies if your car is front wheel drive or your truck is four wheel drive model, go to a large parking lot, put the truck in a tight left turn, this will stress the cv joint, making it click, you will hear the noise from the side with the bad joint. Then make a hard right turn, then do the same things again, this time driving in reverse. That should allow you to isolate the noise, Please rate this four thumbs up if it helped, i appreciate your feedback. Thanks, Bob
on Feb 01, 2010 | GMC Sonoma Cars & Trucks
Exposed inner wheel well
old post but here goes....
the suzuki dealer (shut down here ,usa) theirparts counter is open.
and you can look at what is missing.
or buy an EPC and look yourself or the shop manual.
or mitchels or alldata dot com
but you never said the year? or car make? suz, what?
what year.?
older years they dont even sell parts like this.. so......
and if true that, only off wrecked cars can you get older parts.
no photos , no guessing. sorry. this is a hands on eyes on fix.
either ask a live person or post photos.
89 and up mostly ( i have a 96 that some body parts are not sold new by anyone on earth)
parts and photos. too.
http://www.oemsuzukiparts.com/parts/1995/Suzuki/Sidekick/JLX/?siteid=214330&vehicleid=9158&section=BODY%20HARDWARE
here is a random , view , of one section.
http://www.oemsuzukiparts.com/parts/1995/Suzuki/Sidekick/JLX/?siteid=214330&vehicleid=9158&diagram=1410080&diagramCallOut=3
Jan 28, 2013 | Suzuki Cars & Trucks
Just installed new rotors,brake pads, bearings and tie rods to front of 2000 montana. have a whopping sound when driving , this goes away when wheels turned slightly right. when turning right corner hear a...
One of your CV joints are bad, inspect which CV joint needs to be replaced. Roll your windows down and make tight right and left corners in an empty parking lot slowly and listen for the clicking noise. If it's coming from the passenger side window or the drivers side window, which ever side the noise is coming from is the side that the CV joint has failed and will need to be replaced.
Thank you for using FIxya and replacing the front wheel bearing improperly buy hammering the CV joint out instead of using a wheel bearing puller will cause damage to the CV joint as to what you have described. Good luck and keep us posted.
Jul 20, 2010 | 2000 Pontiac Montana
Left turns sometimes makes knockin noise seems left front, i see that the outside of that tire is worn too. I had front brakes/rotors replaced and seems since then it was happenin but not always
Could also be the upper ball joint, put a jack under the lower control arm and jack the left wheel off the ground, the trick is to try to get it at normal ride hight, grab the tire at the top and bottom and try to push and pull the top in and out inline with the ball joint. have a helper eye the ball joint and see if there is any motion(play) at the joint. If not, check the bottom the same way. if they are both good, try it side to side to check the tie rods for play, make sure the steering wheel is locked. if all checks good than it is probably the cv joint if the truck is four wheel drive, if it is not four wheel drive it's definately is not a cv joint because you don't have them. For the four wheel drive model, go to a large parking lot, put the truck in a tight left turn, this will stress the cv joint, making it click, you will hear the noise from the side with the bad joint. Then tru a hard right turn, then do the same things again, this time driving in reverse. That should allow you to isolate the noise, Please rate this four thumbs up if it helped, i appreciate your feedback. Thanks, Bob
Jan 20, 2010 | 1993 Dodge Dakota
2002 ford f250 v10 when making turns in four wheel drive the front end starts poping as you turn. you can feel it in the steering wheel and hear it.
Four wheel drive is designed to drive on grave or mud. You will always have a feeling within the steering wheel and the truck will feel as though it is hopping , this is normal on dry pavement. How ever you shouldn't hear noise this is an indication that your universal joint on your front differential shaft is worn. You should have both changed if you are considering driving it in four wheel drive a lot in the conditions that the vehicle was designed to drive in, slippery, muddy,ect.
Sep 09, 2009 | 2002 Ford F250 Super Duty SuperCab
1991 toyota camry front drivers side makes noise while driving
It's the left front wheel bearing. Take it to your favorite mechanic if you have one, any good tech can do it, but he/she could run into complications with a car of that age. (The hip bone's connected to the thigh bone, the thigh bone's connected to the knee bone, etc, and there's probably a good share of corrosion down there).
Jul 04, 2009 | 1991 Toyota Camry
Rear end thumping noise
Depending on the year of your gto it could be a buggered CV joint on one of your back wheels. All GTO/3000GT are four wheel drive but up to the mid to late 90's they had four wheel steering. The usual symptoms of a buggered CV joint are loud rattling and/or vibrating from the affected wheel at around 30 - 40 mph and often a loud clunk when cornering at low speed
Aug 12, 2008 | 1991 Mitsubishi 3000GT
Dorman Auto Parts Dorman Cv Joint Boot Installation Tool Air Compressor Required; Tool Fits A + Npt Air Hose Nipple Logo
134 people viewed this question
Top Dorman Auto Parts Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Dorman Auto Parts Air Tool and Compressor Expert? Answer questions, earn points and help others
