Realistic LAB-500 turntable at 33 1/3 jumps to 45 rpm
I have a Realistic LAB-500 direct drive turntable from Radio Shack purchased in 1979 that now when I play vinyl at 33 1/3, at random, the platter jumps to 45 rpm.  I am looking to find out who can repair it, has parts etc or how I can go about doing this myself if possible - thank you!
  • 69 Answers
Go to this site?
http://www.needledoctor.com/Online-Store/Turntable
possibly your capstan needs cleaning? remove the platter and locate the capstan which is usually made of brass? if it is dirty, ie; black use cotton balls and neat alcohol (spirits ) to clean it. also, consider changing the belt as it may have stretched?
Posted on Sep 15, 2009
  • mtramp Jan 24, 2011
    I have one that did the same thing. Turned out to be dirty contacts in the speed switch. A little contact cleaner works wonders.
Record player turntable runs too slow. How to troubleshoot?
If this is a belt drive turntable the belt might be in the wrong position or is slack due to wear.
Jun 12, 2017 | Audio Players & Recorders
Trying to remove the platter on my Realistic Clarinette 123 Record player with radio and casette deck.
You need to prise that black 45 adapter off. The turntable matt should also peel off.
Dec 15, 2013 | Radio Shack Audio Players & Recorders
What's the correct way to use the strobe light to set turntable speed?
The turntable may have a pattern on the edge of the turntable. If not you need a turntable strobe disk that you place on the turntable like a record. The pattern on the disk or on the edge of the turntable will be marked for 50 Hz or 60 Hz frequency.
The strobe marks on the disk or on the turntable are for 33 RPM and 45 RPM and for both 50 & 60 Hz mains frequency.
To adjust the turntable for the correct RPM, turn on the strobe light and the turntable set it to 33 RPM and shine the strobe light on these marks and adjust the speed setting until the 33 RPM marks appear steady and not moving. You may want to check it for 45 RPM as well.
Make sure you use the correct mains frequency marks ie. the 50 or 60 Hz that your electricity system uses.
Feb 25, 2011 | Audio Players & Recorders
PL-L50 Pioneer direct drive turntable playing records as if it had a bad belt speed variations in playback, but direct drive has no belts of course. What could be making my records playback speed...
If there is a speed adjustment for 45 and 33 rpm records the contacts or pots need to be sprayed with some electronic cleaner to remove any dust. This is done by removing the bottom of the player and finding the control knobs inside. Electronic cleaner can be found at Radio Shack for around $10 for a large can. It does not take much. Just spay inside the control knobs inside the unit. You will find a small hole where you can put the spray tube that comes with the cleaner. Work the "pots" or knobs back and forth several times to loosen any residue inside the knob casing. Be careful not to shock yourself by removing the bottom. If you are not use to working on electronics it may be better to let someone else with more knowledge tackle the job.
Dec 02, 2010 | Pioneer Audio Players & Recorders
My turntable speed is too slow. I have the optimus lab 1000 and there are speed adjustments on the bottom side of the unit but turning these either for 45 or 33 rpm did not change results. I have already...
Look under the platter or on the bottom of the turntable. There should be two adjustment holes for 45 and 33. You will need a small screwdriver for adjusting these. If this does not work clean the control pots with spray cleaner.
Dec 01, 2010 | Radio Shack Audio Players & Recorders
What is required to convert 78rpm records to mp3 format?
The cartridge must have a stylus for 78rpm records. If the turntable does not have a 78 speed play it back at 45rpm. Record it and using the software you have or get one such as Audio Cleaning Lab, just select the option to convert from 45 to 78. You can then carry out any audio modifications to clean it up, then save it as an MP3.
Never use a 45/33 stylus to play a 78 and never use a 78 to play a 45/33 record.
Nov 07, 2010 | ION Audio TTUSB10 Turntable
1200 problem spins wildly no speed control
Sounds like the drive I.C has failed. They cost about £30 each - email me for details.
mail@technicsdjuk.com
Apr 08, 2010 | Technics SL-1200MK2 Turntable
Ion turntable speed problems
Turn the tturntable over, there is a speed control pot on the bottom
Nov 07, 2008 | ION Audio iTTUSB Turntable
563 people viewed this question
 Grubhead
Grubhead
