Home | Linksys | WUSB300N Wireless Adapter | Support file isr...
Linksys WUSB300N Wireless Adapter
Problem for Linksys WUSB300N Wireless Adapter
Support file isrt.dll not installed during loading
By nano269 on Jun 30, 2009
support file isrt.dll not installed during loading of wusb300n
I unloaded device and reran. I get "Cannot install this hardware. There was a problem installing this hardware."
I followed Microsofts directions to allow more permissions on reg key. no luck.
My computer sees this as a PCI device not usb. Is that why I am getting this error? This is a USB device.
Solution #1
posted on Jun 30, 2009
Somewhat Helpful)
Joed911
Rank: Guru  Linksys Expert
Rating: 88%, 1568 votes
Try this: first uninstall the Linksys software, then refresh your USB ports. Afterwards, reinstall the Linksys USB adapter per thw instructions on the cd. How To Refresh and reinstall USB Ports Of Your Computer Hello there, the other day i tried refreshing and reinstalling the USB ports on my PC, as some of my connecting devices are not recognized. I present the detailed procedure on refreshing the USB ports.
Let’s go!!
Here are the steps to refresh/reinstall/uninstalling the USB ports on the computer.
The USB port needs to be refreshed to make sure that no other device has captured the USB port of the computer. The Mouse, video camera, your external USB hard disk; what ever it may be.
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager Button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external USB hard disk...USB hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main USB devices at the rear end USB port. As they require more power to initiate.
The above steps are for XP operating system. When coming to the matter of Vista, please note the changes below:
1) Right-click Computer icon from the desktop , and then click Properties to open the System Properties window, and then select the Device Manager tab.
2) Click the Plus (+) sign next to Universal Serial Bus Controllers/Root hub.
3) Click the USB Composite Device entry to highlight it, and then click Remove. If a screen appears to confirm the deletion, confirm the deletion.
4) Disconnect the USB cable to the all-in-one, wait a couple seconds, and then reconnect the cable. This should restart Windows device detection (Plug and Play).
5) A New Hardware found screen may appear, click next through all of the screens that appear for the Wizard to install the USB Composite Device. Click Finish once the wizard completes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
MNfisherman
Rank: Wiz
Rating: 85%, 2436 votes
That would be correct. If it is USB attached and not PCI (internet/ethernet card)
I would try updating drivers for the linksys and then reinstall the software and manually set configuration
Was this helpful?
Yes
No
Popular Solutions for Linksys WUSB300N Wireless
Questions and Unsolved Problems for Linksys WUSB300N Wireless
Do you recommend Linksys WUSB300N Wireless Adapter?
Answer
Answer
my mostly-reliable Hawking wireless device recently died on me, so i bought a cert. refurb WUSB300N... (More)
Answer
i want to link my gameboy advance with my ds can that happen i have this this game but i have 2 of... (More)
Answer
I am only able to use one at a time. When I plug in the webcam my wireless adapter stops working and... (More)
Answer
Sir, what are the requirements to make a wireless network using a bsnl broadband connection with... (More)
Answer
unable to connect to a belkin router using the linksys USB Extension Base
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Linksys WUSB300N Wireless...:
Top Wireless Adapter Experts
Rank: Guru Guru
Solutions: 1505
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Wireless Adapter Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
