Question about Belkin (F5D7230-4) Router (587009)
Laptop gets message'cannot connect' to belkin wireless g router when wireless connection is attempted. Hard wired connection no problem.
  • 135 Answers
There could be a security key required by the router to establish connection with the laptop. Check that & fix it.
Posted on Jul 24, 2009
My Belkin Wireless Adapter connects to the router but says there is no internet connection on my laptop even though there is when I connect to a hard line. All wires have been checked and other items are...
check what encryption your laptop will work with, if its an older laptop then its probably only 64 bit and your router is running on 128 bit encryption, and this will give what you have connected to router but no internet connection
Jan 04, 2011 | Belkin F5D7050TT Wireless Adapter
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
Cannot connect to belkin N1 wireless router
It seems like your router is configured once without any issues. Ignore that error message if you are connected with the internet. The setup couldnt find the Network adapter or the router because it is know more a factory default settings. It is been configured already
Apr 03, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin Wireless connection speed at 11mpbs. Why not 54mpbs?
this is from the d-link support page:
"Question :Why can't I get the advertised speed and performance when in Ad-Hoc mode?
Answer :
This FAQ applies to 802.11b, 802.11g, and Super G™products.
D-Link wireless products follow the IEEE 802.11 standards. The802.11b and 802.11g standards specify that Ad-Hoc mode only needsto support up to 11Mbps. For best results, use an access point orwireless router and set your adapters to Infrastructure (station)mode."
Feb 03, 2009 | Belkin (F5D7000) 802.11g/b Wireless...
Belkin wireless G router not connecting PS3
The PS3 should find the SSID of the network, or you could enter it. And then enter the encryption key, be it WEP or WPA. Everything else should be automatic.
Nov 20, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin router54g 75d7230-4
As long as the computer you are connecting has the capability to connect in some form, wireless or wired, you will not have to run the web utility again. However, if you are currently connecting your laptop wirelessly, and you are connecting your other computer with a wired connection, you must make sure that the wired network is not disabled.
May 01, 2008 | Belkin (F5D7230-4) Router (587009)
I'm having problems going wireless
What process have you followed to try to connect to the network and access the Internet? Where does this process fail?
Apr 13, 2008 | Belkin (F5D7230-4) Router (587009)
I have purchased a Belkin Wireless G Router for a cable modem. I have installed however i am unable to see the wireless network. What have i done wrong ??
Hello experts....
My problem is not being able to work wirelessly with my laptop. My answers to your questions are underlined(I've used your questions to someone elses problem)
One possible issue is your router's wireless radio is not enabled- the light on the router is lite on the symbol for wireless
or the wireless radio is not enabled on the computer you are attempting to connect to the router with - there is a switch on the front of this machine which is switched to wireless.
There are many other possibilities as well. That is why we need you to carefully answer EACH ONE of the following questions.
(01) Which of the following is your router?
-->> F5D7230-4 (Wireless G Router)
(03) Are ANY of the computers connected to your Belkin router able to access the Internet?
YES
(04) If there are other computers connected to the router that are able to access the Internet, how are they connected? (in each case, please)
only this machine is connected but it is by....
(b) wired (using an Ethernet patch cable connected between the router and the computer)
(05) What is the manufacturer and model number of the computer you are attempting to access the Internet via the router on?
HP Pavilion dv2500
(06) What operating system is installed on the computer you are attempting to access the Internet via the router on?
This machine is operating on Vista but the internet access I have is with talktalk
(07) Have you ever successfully connected (wirelessly) to the Internet from the computer you are attempting to wirelessly access the Internet through your Belkin router on?
NO
I hope you don't mind me using your questions to someone else, I thought you might be able to figure out what I'm doing wrong. I am connected to the internet but don't seem to be able to work wirelessly. Lorraine
Apr 09, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7230-4) Router (587009) Logo
172 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
