Question about Acer Aspire L100 PC Desktop
When I switch machine on - fan wirring but machine does not start up. Blue light comes on front - then all lights go off and nothing happens - but fan still wirring
One of the voltage rails in the power supply could be faulty. Can you get hold of a similar unit? It does not need to be an exact physical match provided that the electrical plugs match the sockets on the motherboard. If the computer boots, you can then purchase the correct replacement.
If that does not work, try removing the memory chips from their slots. Using an old toothbrush or similar, scrub the slots using methylated spirits. Then carefully clean the gold contacts on the memory chips with an ink eraser, making sure that your body is earthed to prevent a static discharge.
This sounds a bit drastic, but it has worked for me on a number of occasions. check that the chips and the slots match exactly, and that the chips click into place.
Good luck.
lyallp01
Posted on Jul 01, 2009
Emerson ceiling fan remote won't work
Check the remote control for its infrared emission. Check its battery contacts for any rust or dust. Check it with fresh batteries.
Nov 05, 2012 | Emerson 44 Curva Sky Ceiling Fan In...
EMachine 2862 Desktop Dead On Power-Up
check all the leads to the hard drive and check that the fan starts spinning when you switch it on if it dont start then the problem is the switch these do often go and can be easily replaced and they are not expensive i had the same problem and found that it was just the switch hope this solves your problem for you you can bypass the swith so that the computer comes on when you turn the plug on but when you shut down the computer this shuts everything down but the switches are cheap enough to buy if you have changed the power pack then the only thing it can be is switch .................................
Oct 31, 2007 | E-Machines T2682 (000002965) PC Desktop
On emerson casablanca ceiling fan, there is no voltage between blue and white wires for lighting kit power.
Check blue wire to bare ground.
Then check each wire to bare ground, with switch on and off.
Add a comment with result.
Sep 16, 2012 | Dryers
Washing machine will not start
we had a very similar problem, our machine is only 12 months old and the filter at the bottom front of the machine has a small fan in it the filter was blocked with a coin blocking the fan from turning after reomoving the coin the fan was able to turn and the machine functioned correctly. hope this helps. tony
Jul 19, 2012 | Tricity Bendix AW1000W Front Load Washer
My kenmore front load washer doesn't want to start all lights are working but nothing happens even the door won't lock
your door switch is the problem,where the door latch goes into the machine a little switch sites behind this a safety feature and if this is broke the machine will still switch on but will not work it will need replaced they are cheap.adrianxxx
Jun 02, 2012 | Kenmore 44072 Front Load Washer
I have an E4210 desktop malfunction
listen carefully dude... unplug all the cabels..... open the cabinet remove the ram ...clean the board....there is a panel where u can eject the fan . do it. and again place it.. check all slots (optional). assemble back ur pc..if u forget then draw the cables and the ports u unplugged from..
Apr 15, 2010 | E-Machines eMachines Desktop PC
Switch mine on, only the on light comes on.
Sounds like either loose connections or possibly a hard drive gone bad. Try to look for the hard drive light. It will usually blink on start up.
For starters, try looking for your Install cd and see if you can boot from it.
Aug 01, 2009 | E-Machines eMachines Desktop PC
Burners go out before the fan starts
that makes no sense? the door on does exactly the same thing as you holding the switch closed and neither has anything to do with the problem you are describing. if door were off nothing would happen. if door was on ,nothing would happen unless the switch was closed. it may be coincidence, but sounds like the unit is not proofing the flame. look for a little needle like sensor that protrudes into the flame path in front of a burner. when the burners light it senses flame and tells gas valve burners lit and its ok to stay on. then heat builds and the fan is briught on. once in a blue moon the overtemp sensor trips open prematurely as soon as the burners start to heat up. it is a little wire in , wire out sensor above the burners that protreudes into the bulkhead above the burners. if it is cold and open its bad. if you jump it and burners light and stay lit and fan comes on its bad. fairly cheap and easy to replace. you may have an old fan limit switch the rotates like a spring to bring the fan on as it heats up, then turns off burner if its gets to hot or is set to low. it also turns fan of as burners cool down.
Dec 05, 2008 | Heating & Cooling
Ac led blue battery led amber will not power on
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
sosec
Mar 19, 2008 | Toshiba Satellite A105 Notebook
ZD7000 Lights, no fans, power switch not working.............
Dismantled notebook thinking compressed air removed component or connection. Nothing. Reassembled most of notebook. Left battery and power disconnected for 6.5 hours, I later plugged only AC power into unit. Fans started spinning. Completed assemble of notebook and installed the battery. Blue lights returned. Problem seems to be the battery. Shorts out something and needs about 6 hours drain out. Works great now without battery, using AC power only. Ordered new battery.....
Feb 06, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Acer Aspire L100 PC Desktop Logo
159 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
