Question about Matsonic MS9158E+ Motherboard
No monitor power
The monitor does not power up and when it is plugged into the onboard port it gives 3 long beeps, and when I put in a VGA card it gives 3 long beeps.
  • 193 Answers
Re: no monitor power
Check with ur RAM might be issue with the RAM>and also check with VGA card>and power cord>rate me solved if its help thx
Posted on Nov 08, 2007
0 characters
3 Points
Dh55tc warranty check
do the following steps to rectify your problem.
1.if there are any beeps. clean your ram and reinsert it.
2.check the power cord of your monitor and make sure you have a working monitor.
3. else buy a vga card if the onboard vga slot is malfunctioning
Jul 22, 2013 | Intel DH55TC Motherboard
G31t-m7 no beeps no display
If your getting no beeps, its usually a video card issue. G31T-M7 has an onboard video card. Can you try plugging you montor to the VGA port and see if anything comes up. If still no picture, are fans turning? Might be a power supply failure.
Nov 28, 2011 | EliteGroup G31T-M7 Motherboard
Following a recent crash my computer cannot display a picture on the monitor. I've checked the monitor with my girlfriends laptop and it works. i've also checked the VGA cable. Both work fine. How ever the...
Try to remove the graphics card and then plug the monitor into the onboard VGA port. Also, when you say you tried the RAM, did you switch RAM slots or put in a known working one?
Feb 28, 2011 | ASUS Motherboard P5n-mx
No display assus motherboard PSN73-AM ASUS MOTHERBOARD
When the PC starts up, do you get a BIOS display at all? Try fitting a graphics card into the board instead of using the built in port, if that works check the BIOS settings to see if the built in adapter has been disabled,
Mar 26, 2010 | ASUS P5N73-AM Motherboard
Chaintech P35-121-16B9 need the manual or video jumper setting
Thank you for your query
Generally you dont need to disable the onboard VGA to AGP, all you need to do is to ensure that you plug the monitor lead into the AGP VGA card.
However if you wish to disable the onbaord VGA then please do the following
1) Ensure that the monitor lead is plugged into the onboard VGA card/port
2) Siwitch on PC then press F12, esc or del key to enter detup (When switching on there will be a message that says press X to enter setup)
3) This will present you with a blue BIOS screen, if yuo go through the menu there will be a option that says 'onboard/integrated peripherals'
4) choose that option and there will be a further option 'onboard VGA' this will be set to enabled. Set this to disabled and then save and exit
5) Note at this point you will have to move the VGA cable from the monitor from the back of the VGA prot to the AGP VGA card
I hope this has been helpful
Feb 28, 2010 | Motherboards
P4vm800 not working how to solve this probelom
Good day sir, hi, lets make sure first that your motherboard is good, so we need to test it, just prepare the folowing items.
  1. A good working power supply, to test: place a jumper wire across the green wire and any black(or sometimes the red with work) wire on the 20/24 pin power connector. Plug it and see if the exhaust fan run.
  2. A good set of Ram, just make sure its good. if not or in doubt buy new one (only one module) if you want. (you can keep the doubtful ones and test it later)
  3. A keyboard.
  4. If your motherboard has no VGA onboard, A good VGA card.
  5. A thumb speaker, or you can use your PC case speaker.
Okay lets assemble, on a table:
  1. Place your motherboard, (make sure no metals underneath) connect the Power Supply 20(or 24) pin to your motherboard and the 4 pin 12v connector. (if your motherboard has one).
  2. Connect the pc thumb speaker or your case speaker.
  3. connect the keyboard.
  4. connect the RAM, make sure it clicks as you install it.
  5. Optional VGA card. Onboard vga will do. Connect a monitor. plug in the monitor.
Okay, plug in your power supply, (exhaust fan is off at the moment) locate the power button pins, short them with a screwdriver. (fan is now on)
Now check your Keyboard. you will see two sets of lights, first set is Num Lock + Scroll Lock + Caps Lock, then a few seconds the second set: Num Lock only. at this point your motherboard is good.
Also check out the PC speaker beeps.
  • 1 beep mean good.
  • 1 long and 3 short beeps VGA is bad. (it may help if the VGA is snug and fit on the slot). If on board VGA, use a new AGP/PCIe card.
  • Continous long beeps. cannot detect memory
  • Continous short beeps, motherboard. (or memory sometimes).
  • No beep, fan is this point do everything again. (do it several times until the board responds)
Hope this helps you. feel free to ask again.
Oct 14, 2009 | Asrock P4VM800 Motherboard
My vga port will not work ?
IF the vga port is onboard on the motherboard you have the option to add a vga device to one of the 32 bit add in card slots. Once the add on vga card comes up you can see if the operating system sees the onboard card that is not seemingly working. Then post here what you see afterwards
Jul 26, 2009 | EliteGroup Goal 3 Plus/Sempron 3000+...
Monitor is not on
Im gonna take it that "yup i'm hear the any beep" means you do hear a beep.
So first If it has an onboard vga card. remove the second vga and hook the monitor up to the onboard and try to boot.
Second try the Power Supply, make sure whatever power supply you use has enough to handle all the equipment in the unit.
If those two don't solve the problem, then you have a bad motherboard.
Mar 17, 2009 | Gigabyte GA-8I848P-G Motherboard
Motherboard startup problem!!
If your video is running off the card then remove the cable and plug it into onboard vga. Then remove the card from the slot. That should solve it then you will need to reinstall drivers for video card. If your monitor is running from onboard video then you will need to remove the card then try turning it on.
Dec 25, 2008 | Compaq Evo D310M 845G P4 Motherboard
No video input signal No power to disk drives
If you mean the PSU, have you checked the cables from the PSU are actually plugged in correctly to the drives? (it's been known for folk to plug them in the wrong way). With regard to the monitor, check your graphics card (if not onboard) is still correctly plugged into the board (remove and re-seat it), and that the monitors cable is correctly and securely plugged into the VGA port.
May 29, 2008 | ASUS A7S333 Motherboard
Matsonic MS9158E+ Motherboard Logo
63 people viewed this question
Top Matsonic Motherboards Experts
Brian Sullivan
Brian Sullivan
Alan Hohenbrink
Alan Hohenbrink
Are you a Matsonic Motherboard Expert? Answer questions, earn points and help others
