Question about Philips 55PL9773 55" Rear Projection Television
55pl9774 Lamp will light and there will not be apicture and then tv shuts down
  • Anonymous Jan 14, 2008
    replced lamp tv worked 2 day then stopped workin repair man thinks it might be lamp balast
    Problem Solver:
Mine did this and I also tried to replace the lamp. However, it is probably simply your filters are clogged. Try pulling them out, cleaning them and putting them back.
Posted on Apr 03, 2008
I have this same problem. I replaced the lamp but the problem still exists. I had a repair place come out. They told me it was a bad new lamp. I tried another lamp but had the same problem. Now they told me it is the lamp driver/balast. I am not sure if I will have them repair it for $350+-. When they did the diagnosis, they didn't even bother to turn on the tv.
Posted on Jan 11, 2008
Philips 55PL9774 no video but have audio
There is a protection switch on the inside where the replacement bulb slides out, check to see if it is either tripped or not making connection, If that doesn't fix your problem, check and make sure that there is absolutely nothing on the bulb and/or the glass shield, also visually inspect the bulb for bulges or defects, if found replace the lamp or entire color engine.
May 20, 2013 | Televison & Video
Hi, I have a Mitsubishi wd-57733 dlp tv that shuts down
Ballast is possible if repeated lamp failure but I have a solution I posted several times for this type of problem that works and is simple to try:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Apr 30, 2012 | Mitsubishi WD-57733 57" HDTV
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tv is shutting down then restarting.
How old is this TV, if its more then 2 years old and have not replaced lamp yet then its problem of weak lamp. Please replace its lamp and always purchase Sony original lamp for smooth TV function.
Mar 25, 2009 | Sony KDF46E2000 46" Projection HDTV
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
Tv not working after lamp replacement
CK Fan if it is going bad set will shut down.
Feb 06, 2009 | Televison & Video
Lamp light blinks 3 times shuts down
The CLS problem. Im thinking that at least you made a visual inspection of the power suply and the capacitors around it. Then if everything normal in the area then the microdisplay (inside the ligth engine) can be damaged. (when the tv is working normally the microdisplay sends a pulse to turn on ballast and lamp finally.
The sweetkyman: when the fan is bad th tv shuts down imm. (if you unplug the fan when the tv is working normal the computer detects the overcurrent system works and shuts down the set) when a fan is all dirty and tons of dust on it the tv tends to work but after some hours the tv shuts down.
Dec 20, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Philips 55PL9773 55" Rear Projection Television Logo
372 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
