Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Ultimate Care II Washing Machine Rinse cycle not workin
We have a whirlpool Ultimate Care II washer and it seems to wash the cloths fine but just stops at the rinse cycle. For example my wife put it on 9 cycle and it filled up and washed fine, so it went through cycle 9,8,7, 6 but when then it stops at cycle 6. No noise or anything just stops. We tried other cycle's as well and they are all the same. They just stop at the rinse cycle and just sits ? ? Thanks for any help !
  • 5,911 Answers
Most of these spin related problems are attributed to a lid switch malfunction. A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Let me know if you need further assistance. I hope this helps you.
Posted on Jun 30, 2009
Washing machine starts by itself
going through to the next wash not na normal function, perhaps the machine is advancing to an extra rinse cycle?? this EXTRA RINSE will start after the normal wash is complete, i would check your dial settings perhaps some one has mistaknely switched extra rinse "ON". if htis os not tyhe case the n i would jave to blame a faulty timer mechanism and you would need to replace the timer
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Clothes covered in lint
You need a new timer. Reducing the cycle time will help the lint and not having a timer stuck on wash will help too.
Oct 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Ultimate Care II - Rinse Cycle does not start
sounds like a lid switch problem. is there a clicking noise when you open and close the lid?
if not then the lid switch may need to be replaced; inexpensive.
this could also be caused by a bad timer.
also try a different speed for the rinse cycle, it may be a bad motor and it is not going into a certain speed. instead of gentle or slow speed try fast or normal, something like that.
Jun 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine
IS THIS HAPPENING ON COLD AND HOT WATER RINSE ??? THERE IS AN ELECTRIC SOLENOID VALVE FOR HOT AND COLD WATER SUPPLY. THESE SOLENOIDS HAVE STRAINERS AND ORFICES THAT CAN CLOG UP WITH SEDIMENT IN THE WATER SUPPLY ... MOST ALL OF THEM ARE CLEANABLE. THIS IS NOT AN EXPENSIVE REPAIR ... BEWARE!!!
Apr 28, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
416 people viewed this question
Dan Webster
Dan Webster
Sal De
