Question about Canon imageRUNNER 400S Copier
Power requirement for the imageRUNNER 400s
What is the power requirement for this copier?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
It depends which country the IR 400 was installed ,there are two types of Power supply
110volts-50/60 hertz
220volts/240volts 50 Hertz
if you have 110v machine and you want to connect it 220v supply you can use a 1.5kw stepdown transformer
Posted on Jun 30, 2009
CANNON IMAGERUNNER 400S ERROR CODE E0005
This is the code for the cleaning web in the fuser. This will have to be replaced ( P/N FY1-1046-000 ). The error code has to be reset my going into the service mode. Press additional functions, then 2 and 8 keys at the same time, then additional functions. Press copier, then COUNTER, then MISC, then FIX-WEB, Then the Clear key on the control panel. The counter should go to all "0's. I believe you have to turn off the main power key and power up but I'm not sure.
Jun 08, 2011 | Canon imageRUNNER 400S Copier
803 error ir400s copier
it is the composite power pcb that more than likly has gone bad. you will need to get the board tested and or replaced. was there any loss of power in the area or any surge's in the building it was located in.
Jun 08, 2010 | Canon imageRUNNER 400S Copier
El mimo error 220
Scanner Lamp Or Compositive Power Supplys Problem.
Change The Lamp if the problem Continive change or repair The Compositive power supply
Sep 02, 2009 | Canon imageRUNNER 400S Copier
Switch main power off and on E677
Yes you can switch the main power on and off, what is your problem???
Aug 08, 2009 | Canon imageRUNNER 400S Copier
Can't access system settings on Canon imagerunner 400s
Turn off the main power switch, and
disconnect the power cord.
Remove the copyboard glass; then,
remove the screw, and detach the small
cover from the IP cover.
remove the remove all eprom dccon ram
& insert again & start the machine.
Jul 29, 2009 | Canon imageRUNNER 400S Copier
Setting up department ID's on Canon ImageRunner 400s
Pages 4-16 thru 4-24 of the Reference and Copying Manual cover this topic. I have the User Guides downloaded...but can't provide a link to them.
Jul 08, 2009 | Canon imageRUNNER 400S Copier
Making a Canon Imagerunner 400S a network printer
connect network cable from the machine to the switch or router, and give ur machine ip address compitable with ur network, then load the driver on ur computer and u will be fine.
Jul 06, 2009 | Canon imageRUNNER 400S Copier
Scanning with imagerunner 400s
there is a hardware upgrade that has to be made first. I highly doubt if it is still available. You might find someone witha used one. They were not very popular. The scanner option used a SCSI (pronounced "scuzzy") interface which requires a seperate connection to a nearby computer with a SCSI interface board.
Jul 09, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
76 people viewed this question
old marine
old marine
