Question about KitchenAid KEHU309SSS Electric Double Oven
Code f6 eo
Code f6 says communication problem. With touchpad????? or what.
  • 11,896 Answers
There is a system fault either in the touch-pad itself or in the main control board. This will have to be diagnosed by testing all the resistors and connection points of the pad and on the main board. You may also try to reset the system. Sometimes unplugging for a day helps but that is not always the case. Further testing will have to be completed to find out which resistor is bad or where the fault exactly is.
Posted on Jun 30, 2009
Error code F2 EO oven not working
Ledgestone Technologies has replacement keypads for NO LONGER AVAILABLE Whirlpool and Kitchenaid models. Each one comes with a new ribbon cable and 2 year warranty.
Contact FixYourBoard.com for more information!
512-355-1108 info@fixyourboard.com
Nov 16, 2015 | Ovens
What s a EO F2?
The error code E0-F2 indicates that your touchpad has a stuck key. You might try disconnecting the electricity from the range and pushing and releasing the buttons on the touchpad several times. Be aware as you push them of any button that feels different. If you notice one that is stiffer or just doesn't feel like the others, give it several more pushes. Worst case scenario, you will need to replace the touchpad.
Sep 11, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
F6 E6 error code?
This fault is a communication error at the appliance manager, could be a loose wire or a bad display transformer, either way you will need a certified technician to fix this issue, there is no simple plug and go issue to resolve. I personally found the problem to be the transformer not send voltage to the appliance manager. This is solvable but needs someone who understand electronics to correct this issue.
F6 E0 Oven user interface - lost communication E6 Oven appliance manager 1 (upper, single) - lost communication
This is directly from the tech sheet of your oven and directly from the factory web site.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dec 03, 2013 | KitchenAid KEBS179B 27" Built-in Electric...
I have a kitchenaid convection oven with microwave F6 EO code
Your tring to fix an appliance that's 10 yrs. Old ! Replace is your answer
May 14, 2012 | GE JKP85 Electric Double Oven
My double oven is flashing code F6 and E2
Error Code F6-E2 means that your oven temperature sensor has failed as well your electronic control board.
The oven temp sensor, electronic control board and the touchpad must be replaced.
Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 23, 2011 | KitchenAid Ovens
EO F2 The oven will not start or stop. I can not get the oven to work but it will beep with this EO F2 message sometimes.
Hello Sonya,
The E0-F2 error code means that the oven temperature was higher than it's supposed to be. Usually the oven overheats because of a defective oven temperature sensor and the sensor should be checked. 11_3_2011_2_07_54_pm.jpgthis is what the sensor looks like...it is located within the oven chamber(usually in the left side) to check it,it needs to unplugged and using a mulitmeter set to measure ohms,check the sensor to be between 1060-1100 ohms at room temp. if the sensor is way lower/higher that 1060-1100 at room temp the sensor is bad and needs to be replaced, if the sensor is within that range then the control board is the problem.
GENE
Nov 03, 2011 | Whirlpool RBS275PD Electric Single Oven
This message is displayed on my oven: EO - F2 - What does it mean?
E0 F2 fault code usually indicates a shorted touchpad on the oven control. Firs disconnect power to the range for 30 seconds and restore it. This will cause the electronic range control to reset and sometimes will clean errors.
If the error returns the touchpad on the control will have to be replaced. Some ranges have the touchpad made on the control and the oven control has to be replaced.
Open the drawer under the oven and look on the frame of the range around the opening the drawer slides into for a model number tag. Get the model number of the range and go to searspartsdirect and you can see a parts diagram and list for your range.
Hope this helps.
Sep 21, 2011 | Ovens
Receiving an E0 error code when trying to clean a Whirlpool Accubake oven
The EO error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The EO code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Sep 18, 2011 | Ovens
I have a new Whirlpool Built-in electric wall oven. I just installed it. The read out says EO F2. What does that mean?
EO-F2 means shorted touchpad.
Try pressing the CANCEL button to see if this clears it otherwise you will need a replacement touchpad.
Dec 13, 2010 | Ovens
My oven model # wfg361lfb series : ry1912535 i put it on - it seemed to start up. suddenly the degrees started going down ... and now no buttons work (the clock still does) and it says F2 EO
Hello-  The code indicated-  F2 E0,  is an indicated fault in the touchpad, usually in one of the switches, but sometimes in the connection between them. Onsite diagnostics are required to see which component is affected. If fault does not clear after hitting cancel, then service is required. Solution is to replace touchpad.  Please acknowledge this post if helpful.  Have more info if needed- Thanks- Ed
Mar 24, 2010 | Whirlpool Ovens
KitchenAid KEHU309SSS Electric Double Oven Logo
71 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Jim Goldsmith
Jim Goldsmith
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
