Question about Sony KV-32TW67 TV
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
PLEASE HELP........ GREEN AND RED HORIZONTAL LINES ACROSS SCREEN. VERY ANNOYING. THE LINES ARE KINDA FUZZY NOT SHARP, AND GO FROM ONE SIDE TO THE OTHER. SOME TIMES THEY APPEAR TO FLICKER LIKE THEY'RE GOING AWAY, BUT THEY NEVER DO. HARD TO WATCH T.V SOMETIMES WHEN IT HAS A DARKER IMAGE(VERY NOTICEABLE) LIGHTER IMAGES ON SCREEN YOU CAN BARLEY NOTICE.
Friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Posted on Jun 30, 2009
Kv-35xbr48 turns on fine nice picture then horizontal lines form distorting picture like interference also is the back hard to take off and put on needs a good vacum thanks for any suggestion
At first the picture is ok, and then distorted with horizontal lines i thinks. If the horzontal lines are parellel acros the screen, with an inch apart across the whole screen, your tv needs screen adjustments. Screen voltage may be high. look into the crt base also. Change it first. These also not resolve the problem, LOT may be faulty, with respect to screen focus pack. May need replacement. Try first setting screen voltage to a lower settings and observe.
Oct 14, 2010 | Sony KV-35XBR48 35" TV
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
HORIZONTAL LINES
You are seeing retrace lines, Either you have a bad picture tube or your screens control ( on the flyback transformer) is set too high.
On some sets the focus and screens control is accessible without taking the cover off. If so there will be 2 small holes on the back of the set labelled "screen" and "focus"
insert a small screwdriver into the screen control and turn the control until the lines disappear.
If the set does not have the access holes you can stil perform the adjustement, but you should make sure not to touch anything else as there is high voltage present and it could be very dangerous/Lethal to touch the wrong thing
Mar 12, 2009 | Sony KV-32TW67 TV
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Sony KV-27S10
is it vertical problem or retrace lines can you tell
Aug 06, 2008 | Sony KV-27S10 27" TV
TV screen turns green
i think your color combination chip is not working. you may have to change the chip of color system.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
RED AND GREEN LINES HORIZONTALLY ACROSS TV
This sounds like you may have bad picture tubes. Most likely the green and red tubes. You would have to have them replaced and realigned. I would call a Sony ASC and get an estimate to verify this. An onsite service call could verify if this is what's causing your problem.
Jan 22, 2008 | Sony KP-51HW40 51" Rear Projection...
White horizontal, zig-zagging lines
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
330 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
