Question about Epson Stylus Photo R200 InkJet Printer
Ink pads require replacing or cleaning - Epson Stylus Photo R200 InkJet Printer
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
Get yourself a Waste Ink Container. You may have to reset the WI. It's a simple installation and you can get one at: http://www.inkproducts.com/ink-store/
While you're at it look at the CISS
Posted on Jun 30, 2009
Epson l200 servce required problem
Never had one of this series, but I have went through about 25 Epson printers and the message you refer to means your waste ink pad needs to be cleaned or replaced.
To get rid of the message do a search on "how to reset waste ink pad counter for Epson l200" and you will find a utility that does what you want.
Feb 25, 2014 | Epson L200 Original Continuous Ink Tank...
Service required software
Service required mean waste pad full/almost full. You have to reset waste ink counter. But, you have to replace the pad. or just extend the outlet pipe from head cleaning mechanic to outside of printer.
Browse/googling for R230 resetter/adjusment program. Reset waste ink counter. indoreset.blogspot.com
Sep 30, 2013 | Epson STYLUS R230 InkJet Photo Printer
How can I change the foam pad that absorbes ink? What part is that called?
Hello
Its better to just remove them clean them up and replace it in the printer, because usually some printers require a reset code to re-set the waste ink counter. If the counter is not re-set there will come a time when then printer will refuse to print.
Here is how to clean your waste ink absorber;
Open the printer and locate the waste ink absorber near the ink cartridge.
Remove the absorber pad and hold it in cold water while squeezing the ink out. It would be wise to wear gloves while doing this, because the ink in the pad will leave stains.
Use paper towels to dry the waste ink absorber pad. Let it dry completely before installing it back in the printer.
Reinstall the ink pad into the printer and run a test page to make sure it works.
Apr 20, 2011 | Epson Stylus Photo R300 InkJet Printer
Same problem for my printer pls kindly help my printer is always says ink observer is full...contact service center
The printer requires a service and reset.
The waste ink absorber pads need replacing / cleaning.
The printer will need to be reset once the pads are been replaced.
Feb 14, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Parts inside your printer are at the end of their service life. what can I do
The likely cause is that the waste ink absorber pad is full.
Remove the pad (dis-assembly required) and rinse the waste ink out till the pad is very light grey. This takes a lot of rinsing and squeezing. Finding a replacement pad is often more work though. After cleaning, let dry thouroughly.
Then re-assemble and find the service/maintenance software to run to reset the waste ink counter in the printer.
Apr 13, 2010 | Epson Stylus R290 InkJet Printer
Dirty Waste Ink Pads (Epson Stylus R285)
Remove to top cover and replace the ink pad with a new one. You can get these pads from a place called pudsey computers www.pudseycomputers.co.uk
Nov 17, 2009 | Epson Office Equipment & Supplies
Ink absorber replacement options - MP130 or how do I clean it? It is almost full according to error message
Removing & Cleaning the Absorbent pads.
The printer has 2 ink absorber pads that are located under the ink cartridges.
1. With power off the head assembly / cartridges can be moved into the middle for access.
2. Each of the 2 ink absorber pads are seated in a rubber retainer. The pads can be easily removed cleaned or replaced.
3. Carefully remove the pads using long nose pliers or tweezers.
4. Clean the using with running warm water, or use an isopropyl alcohol bath, or an isopropyl alcohol based aerosol if they are really dirty. DO NOT USE ANY SURGICAL SPIRIT OR ANY OIL BASED CLEANERS. At a push you can use a warm water mild washing up liquid bath but be sure to thoroughly rinse out the solution after cleaning. The pads should be white when they are clean.
5. Dry the pads – it may take some time and placing them in a warm environment or near a warm radiator will speed this up.
6. Clean away any ink on the retaining rubbers using a cotton bud or clean and soft lint free cloth.
7. Replace the DRY pads in the rubber retainers.
8. Replace the Ink cartridges.
9. Power on the printer and print a test page and clean and realign the heads as required.
10. If the E27 error message reappears then you will need to reset this.
Clearing procedures for E27 or Error 27 Code.
1. Power on the printer by pressing the Power button while pressing and holding the Stop/ Reset button.
2. When the Power led is green press the Stop/Reset button two times while pressing and holding the Power button.
3. When releasing the Power and the Stop / Reset buttons the printer will move into a service mode and will be Waiting for a menu selection.
4. When the Power led is green, press the Stop/Reset button 4 times for waste ink counter reset.
5. Power off the printer and Power it back on again to complete the reset.
Oct 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Hi, Waste Ink asorber is full on my Canon PIXMA IP2000, can I find a replacement??
Oct 21, 2009 | Canon Office Equipment & Supplies
My cannon printer/copy machine says my ink absorber is full. What does that mean? what do I do?
The printer has 2 ink absorber pads that are located under the ink cartridges that collect the waste ink.
Oct 07, 2009 | Canon Office Equipment & Supplies
How to replace ink absorber
I suggest that instead of replacing , first try cleaning the ink absorber unless of course they are completely worn out.
Most Canon ip printers have similar construction there :Try as below:
Two absorber pads are located on the right side of the printer, under the ink cartridges. With the printer on, lift the top to expose the cartridges. They will automatically move out of the way. You can move them to the left side by hand if the printer is not on. They each sit in a rubber socket. The pads can be removed and cleaned.
Take the pads out of the socket with tweezers. Clean them with warm water. It is best to use a spray bottle (on stream) and blast it through the pad until it is white. Sometimes just putting it under a running tap will be sufficient. If there is ink in the socket after taking the pad out, it can be cleaned up with a paper towel. Put the pads back into the socket and you have successfully cleaned the ink absorbers.
Please also check the link below on tips on FixYa itself
http://www.fixya.com/support/r883355-ink_absorber_pads_cleaning
All the best... let me know if you require any further help.
Please do rate and thank for using FixYa!
Mar 05, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Epson Stylus Photo R200 InkJet Printer Logo
169 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
