Question about Gigabyte GA-8I945GMF Motherboard
Flashing bios i updated my MB with latest update from the official site but the configuration of auto protect bios was enable so now my mb doesn't boot any more my mb is Gigabyte GA-8I945PL-G
  • 1,601 Answers
Re: flashing bios
Pull the bios battery for a few minutes and reinsert it , see if it comes back on.
Posted on Nov 09, 2007
0 characters
3 Points
Windows 7 with Gigabyte motherboard says "ntldr is missing"
Check if UEFI is disabled after flash with newer BIOS version. If you flash BIOS the default settings gets loaded again. Check hard disk settings and boot settings.
Mar 03, 2013 | Gigabyte Motherboards
My machine has this problem. every time i switch it on it says mac address are invalid in both cmos and flash. what do i do?
configured the BIOS settings yet? Make sure your set the RAM to run as Supports DDR400/333/266 non-ECC, un-buffered memory Max. capacity of system memory: 2GB
the RAM you installed and to match the CPU bus. And there's probably several other settings that need to be tweaked as well. For example, if you're not running RAID, disable it.
If the problems continue, you may wanna try updating the BIOS. Actually, I just had a look at the ASRock site & here's what the latest BIOS fixes: "Modify MAC address function algorithm"
Nov 07, 2010 | Asrock 775VM800 Motherboard
I have bios version 1008 on the computer. Should i update the bios version to the newest one? The fans are always running, they never shut down
Actually if your MOBO are working fine as of now no need to update the BIOS version. Updating BIOS version may affect some parts of MOBO so no need to update the BIOS version.
Oct 03, 2009 | AMD Asus A8V Deluxe Socket 939 Motherboard...
Ibm think senter drives -mt-m 8434-52a
Up until now the only think we know is that the mother board is made by IBM. We need to know what is the name of the computer and model number. We also need the MB information and number. The number of the MB is usually printed between the PCI sockets (white) or around the RAM memory sockets at the right hand upper board. We will also need all the detail of the problem, with your own language. This way we can put together a duplication of your problem, which will lead to the solution of your problem.
Thank you very much for your consideration to our service...
My name is Constantin (arzconst)
May 17, 2009 | Motherboards
S-ATA Hard Disk not detect
hi Dear,
You have to update your BIOS. If you have intel mother board just go thought their website and download BIOS Flash utility of your particular Board and Update BIOS.
The above fix will surely solved your problem.I had same problem as you and it's now fixed.
May 10, 2009 | Motherboards
I had the same problem, the bios is corrupted, try a blind bios update or if it doesn't want to, you must do a hot flash update.For more details google search for award bios hot flash.Or dump it and buy a new one.A hot flash worked for me for this mb and an Epox 8rda+,i also have backup bios chips now.Your chip is a Winbond,4 mb capacity.
Hope this helps, SSVik
Mar 23, 2009 | Abit AN7 Motherboard
Download bios and flash
Try Asus update first, found here:
It should check your current BIOS and download the newest one and install it automatically. If that doesn't work for you then you will need to update the BIOS from a bootable floppy disk using the two files found below:
The BIOS is here:
You also need the BIOS update tool found here:
Jun 18, 2008 | ASUS P5GD1 Motherboard
BIOS detects only 128 MB instead of 1024 MB
Does the motherboard support 1 gig ram modules? what kkind of motherboard/video card do you have? sometimes video card onboard ram can ofset motherboard ram, especially with ati video cards.
Mar 17, 2008 | PC Chips M870 Motherboard
Gigabyte GA-8I945GMF Motherboard Logo
142 people viewed this question
Top Gigabyte Motherboards Experts
Brian Sullivan
Brian Sullivan
Are you a Gigabyte Motherboard Expert? Answer questions, earn points and help others
