Question about Vizio 42 in. LCD TV
Flickering white line across top of vizio 47" tv screen
  • oskrbluefan May 11, 2010
    a have the same issue on my vizio37 inch, are you able to adjust yur Vsize if you go to Menu, Setup, HV position? I can't and I think this problem is related.
I had that problem on my Vizio 37" and my new Vizio 55" and now after reading the solution of adjusting the HV position in the setup menu, the problem is fixed! Thank you!!
Posted on Jan 01, 2011
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
Why is there a white line on my tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 25, 2015 | Vizio M470SL 47 in. LCD HDTV
Vizio VO47L FHDTV10A black screen no light
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
?Check the cables, connectors and connections.
Take it to a repair shop.
Apr 11, 2014 | Vizio VO47L 47 in. LCD TV
Flickering shadows bottom 3/4 of the screen flatscreen vizio tv
Hello
To replace the CCFL lamps, you have to disassemble the LCD module. It is a very skilled work, as CCFL lamms are very brittle. and should be handled carefully. It will be best to get this set repaired by any expereinced service technician.
Mar 05, 2012 | Vizio VO47L 47 in. LCD TV
Their is a flickering line that go a cross my hole top screen how do I fix this or is it normal
Change your aspect ratio to full. You are on just scan. When on Just scan mode this is normal. They have to have that to be THX compliant. Just change your aspect to full or 16:9 and you will be fine.
May 18, 2011 | Vizio XVT3D474SV 47 in. 3D LCD TV
My vizio has to warm up before the screen turns to its regular blue no signal screen, and then when it does there are vertical lines all across the screen. Any solutions?
Hi:
This problem may be due to a faulty T-Con board, but first check the power supply for faulty Capacitors, there may be swollen of puffy tops on a couple of capacitors usually located near the connector plug going from the PS to the Main board. If all capacitors look fine then replace the T-Con board.
Dec 19, 2010 | Vizio VO47L 47 in. LCD TV
White flickering line across top of tv with non HD channels
It appears that when you go back to normal tv from hdtv you are able to see the overscan area. Change the aspect of your image with the appropriate button on your Vizio remote and or cable remote. Apparently the button that changes the aspect on the Vizio remote is the wide button. The cable remotes will usually have hd zoom (#), aspect or format.
Sep 28, 2010 | Vizio L32 32 in. LCD HDTV
White flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
Open Questions:
See all Vizio 42 in. LCD TV Questions
Vizio 42 in. LCD TV Logo
2,059 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
