Question about Maytag Heating & Cooling
Maytag m6x07f2a-a window ac unit wont work
I have a maytag m6x07f2a-a window ac unit. it has a remote control (that i lost) and electronic controls. i just pulled it out of storage from the winter, cleaned it, plugged it in and it worked fine. the next time i tried to turn it on, the display would light partially and dimly, and the unit would not respond otherwise.
SOURCE: Remote Problems
do you have any CFL's in the room try turning these lights off as I have seen these effect some remote control systems
Posted on Mar 18, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
Posted on Aug 30, 2007
hapndnvegas
  • 35 Answers
SOURCE: air conditioning unit remote control problem
when something is broke you can never break it worse so dig in and look for a stuck button or broken piece of plastic lodged in between the buttons or
you may want to go to: harmony web site and see if your model of a/c is supported these remotes are rather expensive us$129-$499 but much less than replacing the A/C and can control 225,000 devices made by 5000 different manufacturers just about any device under the sun. on the website under device choose home automation then climate control your brand then model number to see if your A/C is there. If you decide to go this route I would reccomend to check all the other devices you have also.
Posted on Apr 14, 2008
  • 158 Answers
SOURCE: fan and remote not working
If you haven't already done so, replace the remote's battery with a brand new one . Make sure the replacement battery is NEW AND UNUSED, AND WAS PURCHASED RECENTLY, SO IT IS FRESH. Make sure it is installed properly, making good electrical contact, and the proper polarity is observed. Was the remote dropped, sat on or stepped on? Was a liquid spilled on it? Did your pet chew on it? Are any of the buttons loose or stuck? If the remote seems ok, try removing 120 volt power from the fan by turning off the circuit breaker or fuse an your homes main electrical service box. Wait 30 seconds, then turn 120 volt power for the fan back on. This may reset the speed control in the fan unit. If it does not cure the problem, consult a professional electrician, or replace the fan, whichever is more cost-effective.
wait 30 seconds and turn 120
Posted on Aug 06, 2008
SOURCE: My Logik L22LID628 tv has
We have had two of these tvs break within 2 days of purchase, in our case both times it seems to be a backlight failure. Did you wall mount your tv? If so when you take the base off it leaves a hole in the casing leaving circuitry visible. I think it's very easy to damage the ciruitry.
Posted on Nov 03, 2008
Lost remote control and bought a new one. The remote is working but does not sense on an airconditioner
Hi, so the new remote works? Are you saying that the new remote works but can't tell is the ac I'd on?
Without more information I would assume you have a two way remote that came with the ac, the remote you replaced it with may very well not be, especially if it's universal.
A two way remote operates by sending a code (message) to what it is controlling and the device is exspected to respond usally with confirmation the action happened.
Good luck and thanks
Questions? Just ask!
Nov 27, 2015 | Televison & Video
Problem with ac window unit panel and remote will not work,pushed all bottons to work and just wont.Could it be the mother load panel?
Sounds like a control computer board problem. Some times unplugging and leaving it for about 30 seconds and plugging it back in can recover from the fault.
Jun 29, 2014 | Crosley CAE15ESR 15,000 BTU Window Air...
Ask com lg ac window unit control panel stopped working
Hi Gina, Try turning off the unit at the electrical panel. turn off switch, wait 15 min. turn switch back to on position. Turn on AC unit. Hope this helps.
Oct 21, 2013 | Heating & Cooling
My unit requires remote control to operate remote control is lost what 2 do
Whether you have a thru the window model or a potable AC, the same controls that are on the remote are on the face of the unit. To operate it without the remote, turn the unit OFF and unplug it. Wait 5 minutes, then plug it back in. Wait 3 minutes & turn the unit ON using the controls on the front of the unit.. The controls will have reverted back to the original factory settings and you can now use the front control panel to operate & set the controls as you like.
If you want to purchase a new hand held remote, contact Haier Product Support 1-877-337-3639.
Hope this helped you and thanks for choosing FixYa.
Aug 02, 2011 | Haier Heating & Cooling
I have an split-type aircon (brand: General) remote control AR-DL2. it has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix...
i have general electronic ac brand i cant found universal remote can u find one for me what are the universal remote that compatible for my ac tq
Nov 29, 2010 | Heating & Cooling
Mt timer butoon is stuck on timer so unit wont work
All LG room air conditioners should be able to be operated without using the remote, by just using the controls on the unit. Replacement remotes are available from an LG service provider.
Jun 05, 2010 | LG Electronic Window Air Conditioner
I have general model AR-JE11 but it is not switching on or off or anything thru remote , i have chkd the remote with another same a/c and the remote is fine but i dnt know y it is not working ith one of...
Remote control unit are not working. I would like to buy one remote control. I live in dhaka, Bangladesh so how can I buy it? Model No: AR-JE11 for General AC 1.5 Ton Window type. My AC is working by manual on and off.
Mar 23, 2009 | General Heating & Cooling
Control seems to be working but unit not responding.
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Jan 21, 2009 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
273 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
