Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
GE Profile bottom freezer not making enough ice
I have a GE Profile refrigerator (french door, bottom freezer) with an outside door dispenser for water and ice. Model PFSS6PKWASS. The ice maker makes ice but about half the amount the manual says it should be making over a 24 hour period. The freezer and refrigerator temperature seem fine. The water dispenser seems fine. I took out the water filter as a test but it did not change the water flow or amount of ice being made. If the problem is a control valve or temperature sensor are these integrated on the ice maker assembly? I ask because I have one that GE sent me a while ago when I had a problem with the tray. They sent the tray bucket and the ice maker but I only replaced the tray. Thanks.
  • 4,070 Answers
The temp should be around 5 degrees.
Posted on Jun 30, 2009
GE FRENCH DOOR REFRIGERATOR DOES NOT MAKE ICE
First thing to check is if the freezer temperature is going down low enough for the ice maker to work - around 10 degrees. The icemaker thermostat will not activate the mechanism (cam motor) unless this requirement is met.
Nov 27, 2013 | GE Profile PFSF6PK Bottom Freezer French...
Water Dispenser on GE Profile Bottom Freezer Refrigerator Not Working
When you press the water dispenser button, do you hear a noise like water is trying to come as usual. If so then your problem might be frozen chill water tank or failed chill water valve. If you don't hear the regular noise then the problem might be with the dispenser unit.
Nov 26, 2013 | Star Manufacturing GE Profile PFSS5NJX...
The ice maker will make the ice but I have to manually press the reset button to have the ice dump into the tray. It will not dump ice on its own. This is for the samsung RF217AB french door bottom...
Make sure the freezer is cold enough. If not this might cause problems of poor dispensing.
If your ice makes unit has a 'heater'build into it, it just might be that the heater in the tray does not work..if so, new ice tray dispenser.
Oct 25, 2013 | Samsung RF217ABWP (20 cu ft) Bottom...
Our GE Profile Ice maker is not making ice,and water is not cold?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 24, 2010 | GE Profile PFS22MBS Bottom Freezer French...
Purchased a GE Profile bottom freezer April 08. Has indoor water dispenser. Changed the water filter 60 days ago. Since then the amount of cold water dispensed has slowly decreased to a trickle. There...
Disconnect the water line where it comes out of the water inlet valve and see how the flow is when you try the dispenser. Disconntct the water line at the bottom of the freezer door where it goes into the door. If it flows good here it may be freezing in the door. Open the door till it thaws.
If it's good at the inlet valve and slow at the door, some models have a way to put a plug in and bypass the filter.
Aug 14, 2009 | GE Profile PFSF6PK Bottom Freezer French...
Reset Filter Indicator Light is on
Look for your model number from the sticker inside the fresh foods section of the refrigerator, usually on the liner near the door opening. Now, go to http://www.geappliances.com/service_and_support/literature/ to download a use and care manual for your model, as the reset procedure may vary by model. The filter is usually located at the very back right upper side of the fresh foods compartment, but again, it may vary by model.
Apr 11, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
My GE ice maker has forzen up with too much ice & wont eject
Unplug refrigerator, remove frozen food and use a hair dryer on the ice to remove it. Thanks, Sea Breeze
Feb 08, 2009 | GE Profile Stainless Bottom-Freezer...
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Nov 25, 2008 | Pds GE Profile Energy Star 22.2 Cu. Ft....
Refrigerators Logo
1,034 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
