Question about Whirlpool Dryers
Keeps blowing circuit boards @ $300+ per blow. Kenmore HE4 Dryer. Product defect?????
  • 5,687 Answers
Yes Go to search and put in "kenmore he4 dryer defects". There is class action stuff on both the washer and dryer. The best temporary fix I saw was to clean the lint out of the machine and to use electronic contact cleaner on the buttons and computer board. BEWARE that this cleaner can remove the print from the keys so read the articles carefully. Hope this helps.
Posted on Jun 30, 2009
Kenmore electric dryer keeps blowing circuit breaker
either the heating element has sagged when it gets hot and is now shorting out to the dryer heater case,or possibly a defective drum motors bearings getting tigt or the motor windings are shorting out and drawing excessive current,or even possibly a wire vibrating during operation and shorting out at a wear spot on the insulation,but most likely if it shorts out at a preset time after start it would be one of the first two problems listed above,
Apr 20, 2012 | Kenmore 400 6942 Dryer
Kenmore elite he4 blows circuit breaker
your element or motor has shorted as these r the only components that r earthed within the machine so check these first
Nov 10, 2011 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite HE4 dryer has stopped blowing heat.
There is a hose that blows to outside, could be stop-up. Located on back of dryer.
Feb 01, 2011 | Kenmore Dryers
It takes several cycles to dry clothers in my Kenmore elite He4 dryer, it feels like hot air is blowing but the clothes are not getting dry any suggestions?
werw
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens. or you have a defective heat coil
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 28, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer runs and drys cloths but dosent cool down and stop
when was the last time you cleaned out the dryer?unplug the dryer,remove the bottom panel,take out the lint filter and remove the duct that it slides into.clean the duct out,vac out the inside of dryer,if you have a shop vac you can put it on blow and blow the lint forwards so you don't ha ve to remove the drum.put that back together and remove the vent line from the back of dryer,if it's a long run blow it out with a leaf blower,also make sure the outside vent is clear before you blow out the vent line,if the dryer can't move the air around it will run hot.
Jun 26, 2010 | Kenmore Elite HE4 Electric Dryer
My dryer check lint screen light continues to blink and the dryer wont work even after cleaning lint screen
Airflow through the dryer vent is restricted. Blow through the filter opening with a reversed vaccum cleaned. Set it BLOW instead of **** usually by putting the hose on the exhaust end.
Dec 14, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 does not dry the cloths all the way.
if dryer is filled with lint or vent line is blocked the clothes will not dry correctly,shop vac is great for this it sucks and blows,vac out what you can see and then blow out the lint from back and on motor,clean out the lint duct,where ever you pull out your lint filter either on top or inside dryer you have to clean out the duct.now go outside and check the flapper,if it isn't blowing open or hardly opening i use a leaf blower and take off the vent line from the back of dryer and blow it out,good luck
Nov 02, 2009 | Kenmore Elite HE4 Electric Dryer
It keeps blowing the breaker
hello it sound like a bad earth check for any loose wires if ok then it could be the motor gone down to earth
shaun
Aug 31, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Dyer blowing cold air
Try cleaning out the the vent tube. Sometimes lint gets caught up in there over time. Hope this helps.
Mar 12, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
90 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
