When i turn on tv i get a message that says air flow is blocked tv will shut down
  • 261 Answers
It's probable that the inside of your Tv might be dusty, first of all i recommned you open the back of the TV and with a can of air (the one you can use to clean a computer) take off all the dust possible because the dust bunnies might be in the way, not letting the tv ventilate, if that does not work it might be that you have a defective fan which needs to be replaced
Posted on Jun 30, 2009
We have a wd 57732 a solid yellow light on when turn tv on message air flow block shut down in few seconds shuts off with two green lights flashing and solid yellow acks as if room temp to warm. sometimes...
The lamp needs to be replaced. It's on the back and easy to do. I replaced mine about 3 months ago and it was about $182.00. Hope this works, I know it's hard to fork out that kind of money at this time but once you do the TV will be as good as new. Take care
Jun 09, 2011 | Mitsubishi WD-57732 Projection Television
Area around TV is clear, nothing is blocking TV or air flow. When we use the TV we frequently get this message: The TV will shut off in one minute. Check to see if air flow is blocked. Happening more...
you need a new power supply unit these after some time get old and start over heating causing the tv to heat up intermediately if you take it to a repair shop and have that replaced it will be like new again
Feb 25, 2011 | Mitsubishi WD-52525 52" Rear Projection...
When I turn on my 65" the message displayed reads the air flow is blocked and the tv will shut down which it does. I've vacumed & cleared all openings. I have to reset the tv about (5) times before the...
ok what you have there is a faulty thernal sensor nitisubishi has issued a bulliten to serice centers so check with local service center the repair might be covered under warennty
Oct 14, 2010 | Mitsubishi Televison & Video
Air flow is blocked
In the 65" TVS there are 4 or more fans One of these is not functioning Probably the one over the power supply itself This will cause it to heat very quickly and shut down in a matter of about 20 seconds.
only way to find out which fan is not working isw to remove the back.
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Mitsubishi WD-65731 65" HDTV
I get a message that the air flow/fan is blocked, then the tv shuts down. It's not blocked. It's perfectly clean.
This indicates the TV is overheating. Lamp based TVs usually have two or even three fans. One may be having problems or not turning fast enough.
Mar 31, 2010 | Televison & Video
Air flow blocked...turning off in a few seconds message
"air flow blocked" means its getting too hot. or it thinks it is. it is quit common on these set that the thermal sensor has malfunction replaceing this sensor is your solution. since this is service bulliteen item at service centers of mitsubidshi products this may be an item covered under warrenty. so i would first check with you local service shop too see before
Jun 04, 2009 | Mitsubishi WD-65731 65" HDTV
52' DLP Mitsubishi HD T.V. gets an error message on the bottom of the screen ''T.V. will shut down. Check that air flow is not blocked'' T.V. is in the open and air flow is not blocked. There is also a...
most rear projectors will turn themselves off whenever the lamp is dead. what we call protective mode. in this case the yellow light may be for the lamp. otherwise check if all the fan are working properly.
But MAKE SURE you let sufficient time for the tv to cool off before unplugging the main.
hope this helps
please rate me!
Mar 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi DLP 1080p TV with air flow problems
Hello ags98,
First I would suggest that you re-seat the bulb and then check the cooling fan, and air flow path. In addition to checking the fan make sure all air flow ingress and egress vent are unobstructed.
I hope this helps
Thank you,
Shuttle83
Oct 01, 2008 | Televison & Video
Mitsubishi 1080 LP HDLP TV
tv screen goes blank but still have sound
Feb 17, 2008 | Televison & Video
Amber system light is on
had the same issue, we even had a personal fan blowing air behind the tv and the message always comes up right when we turn on the set and the tv turns itself off after about 30 seconds. did some research and it turns out there is no air flow problem just a faulty temperature sensor inside the set. Mitzubishi knew about this since 2006 but didn't really aknowlege it until more recently, they admitted it was a problem with the sensor and are now extending everyone's warenty by 2 extra years so if you got it with a year warenty and you bought it less than 3 years ago, call mitzubishi's 800 number and tell them the temperature sensor needs to be replaced, they'll get you in touch with the nearest service center and a service man will come out and replace the sensor at no charge for parts or labor. hope this helps
Jan 13, 2008 | Televison & Video
Open Questions:
Televison & Video Logo
534 people viewed this question
Top Televison & Video Experts
