Question about Karcher Garden
I've been told that I have a stuck unloader valve
Karcher HD3500 pressure washer. Where is this valve located and simply how to get to it to clean or replace
  • danielbar786 Jul 07, 2009
    Hi
    On my HD3500. The unloader valve is behind the pressure control knob. I have removed and cleaned and greased and re-installed. My problem is that when I put garden hose to inlet (good water pressure&filter is not dirty) I get no pressure out of the high pressure side. If I remove the unloader valve I then get pressure out of high side. I was told that I had a stuck unloader valve, that is when I first asked the question about where it was, since then I have done everything I can think of. It all boils down to if the unloader valve is in I get no water thru the head. The valve itself looks ok ( spring not broke and o-rings look fine) What is it that I'm missing.
    Dan
    Hi
    I will order new one today and see if it takes care of my problem ( I sure hope so), I'll keep this ticket open until then.
    Dan
  • 2,200 Answers
  1. Using a flat blade screwdriver, pry off the top silver cap from the top of the pump.
  2. Remove the black cap from the top of the pump.
  3. Using a T30 torx bit (sometimes referred to as a star bit) remove the two screws from the plastic unloader cover.
  4. Next, remove the thermo coupler and spring that sit in the pump housing. You won't have to remove the o-ring that sits on top of this coupler because it is integrated into the housing.
  5. Remove the spring from the cylinder.
  6. Remove the unloader valve from the pump. The easiest way to do this is to attach a garden hose to the pump and turn it on. The force of the water will push out the valve. If this alone does not remove it, you may have to start the machine to get enough pressure under the valve.
  7. Lubricate the unloader valve o-rings with white lithium grease. This will reduce the friction on the valve and allow it to move more freely. (as shown below)
  8. Re-assemble by reversing steps 1 through 6.
Valve looks something like this when you have removed it.
Hope this helps. If so please remember to rate my answer. Many Thanks.
Posted on Jul 07, 2009
  • 15,935 Answers
Ok - then if there are no more problems - accept the answer, and if you need additional help, please use the "continue with this expert" option.
Thanks for using FixYa!
2 Suggested Answers
  • 174 Answers
SOURCE: clean and unloader valve on Karcher hd3500
Hi:
Cleaning it is not enough. You need to make sure the o-rings are in good shape and grease it with a very very good waterproof grease. Here is a schematic of the pump. The unloader is parts 7 to 13 on D-2
Posted on Sep 10, 2009
I have a Karcher G2500HT. When I pull the trigger the pump will not engage. I pulled the pump off, checked the seals, and cleaned the screen. When I put it back on there was no leakage but the pump...
I would have to agree with your service department. The unloader valve works like this, When you press the trigger it closes and allows the water to build pressure through the pump. When you let off the trigger the valve opens and by-passes the water through the pump so you don't damge the pump. If this valve is sticking and remaining open the pressure will not build. You can remove this valve and clean relubricate with white lithium grease just a coating and this should clear up your problem. Check the port that the valve sits in and if you see gunk just clean with carburetor cleaner and blow it out with air compressor. A new unloader valve can cost between $40.00 - $60.00. Try to clean first before you buy a new one. The valve is usually located near the outlet that you connect your pressure hose to. If you can't find it go to jackssmallenginerepair.com and do a parts look up for your machine and you will see where this valve is located. Hope this helps.
Jul 20, 2011 | Karcher 2500 PSI Pressure Washer
Pressure off and on every few seconds with my karcher 3000BH
hi there rjcomer2
here is web site for parts
http://www.ereplacementparts.com/karcher-2500-11944010-pressure-washer-parts-c-33388_33389_33973.html
sounds like you have a unloader valve problem or a crack in the pressure manifold housing between pressure outlet and unloader valve assy allowing unloader to cycle on/ off
or some dirt trapped in the unloader valve seat , make sure you have good supply of water - ie good flow from tap to pump
try cleaning unloader 1st and fitting in line tap filter
hope it helps
pauly46
May 20, 2011 | Karcher 2500 PSI Pressure Washer
I have a Karcher Pressure and cannot get any pressure out of the unit.
karcher K3.97 MB when connected up to tap and switched on pressure poor and motor seems slow cleaned hose end, and filter looks clean
Apr 19, 2011 | Karcher Garden
No pressure on Honda 2400psi pressure washer
spill valve aka unloader valve is stuck needs to be cleaned and lubricated with grease re instaled
Jun 01, 2010 | Honda Karcher G2400HH-R Pressure Washer
Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Oct 02, 2009 | Honda Karcher G4000RH Pressure Washer
Karcher k3.86 lowered operating pressure and constant surging at idle, it back feeds into the water feed/supply hose until trigger is pressed
It sounds like your non-return valves are damaged. in the pump there are usualy 3 non-return valves, these are located under 3 large brass hexagonal caps. take the valve out and inspect them. if you are lucky they may just need cleaning, as sometimes foreign object that enter the machine with the water get jammed in the valve. if your unlucky the springs in the valve will be damaged and you will have to replace the valves. I hope this helps you out.
Sep 20, 2009 | Karcher K2.26 Electric Power Washer
Clean and unloader valve on Karcher hd3500 pressure washer -intermittent pressure on and off. Cleaned inlet screen. Think unloader valve is is under pressure knob? Will cleaning help?
Hi:
Sep 08, 2009 | Karcher Garden
No pressure / Karcher G 2400 HH
Hi ruthkapres:
Here is a diagram. The unloader/spill valve is #12 on page D2 or F2 depending on your model. You must pull it out, inspect the o-rings for dents or tears and make sure the valve is lubricated with a good water proof lubricant.
Jul 14, 2009 | Karcher G3025OH Pressure Washer
How to clean unloader valve..
The Karcher K2400HH and G2400HH do not have an unloader valve, they have a spill valve which is located under the black cap on top of the pump.
The spill valve needs to be removed and the side walls of the hole it sits in need to be wire brushed to remove deposits. then you can put it back in and put the pump back together.
Jul 03, 2009 | Garden
I have a Karcher HD3500 and was told Imay have a stuck unloader valve. Where is it and is there a diagram showing how to get to and clean?
Hi
The unloader valveis HERE
If you go to D-2 it is part numbers 8 to 13. If it is stuck it is not only important to free it up but also make sure no o-rings are damaged and lube it with a very good waterproof grease. Good luck.
Jun 30, 2009 | Honda Karcher G2400HH-R Pressure Washer
Garden Logo
2,043 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
