Question about Dell 946 All-In-One InkJet Printer
What does the connection from the printer to the cpu look like?
    President:
  • 3,278 Answers
The photo on the left shows Centronics (printer portion) to Parallel (CPU portion) cable connector.
The photo on the right shows a USB printer cable.
So, it depends what your printer uses.
what does the connection from the printer to the - moz-screenshot.jpgmoz-scwhat does the connection from the printer to the - moz-screenshot-2.jpgs=moz-screenshot-2.jpge1cf86d.jpg
Posted on Jun 30, 2009
Hp deskjet f4140
1.Uninstall the installed driver first.
2.Disconnect Data cable from CPU.
3.Then connect the printer with CPU.
4.Turn on the printer.
5.If the PC detect the printer, install it.otherwise check the data cable or ports are ok or not.
Aug 16, 2014 | HP Deskjet F4140 All-in-One Multifuntion...
Tip
100% CPU when printing
<span><span>If</span> <span>your</span> <span>printer</span> <span>is</span> <span>connected</span> <span>to</span> <span>your</span> <span>computer</span> <span>via</span> <span>a parallel port</span> <span>(</span><span>or</span> <span>LPT</span><span>)</span><span>,</span> <span>it can</span> <span>use</span> <span>100</span><span>%</span> <span>of</span> <span>your processor</span> <span>time</span> <span>for</span> <span>your prints</span><span>.</span> <span>In</span> <span>some</span> <span>cases,</span> <span>other</span> <span>open programs</span> <span>do not meet</span> <span>longer</span> <span>during printing</span><span>.</span><br /><span>This</span> <span>issue</span> <span>is</span> <span>related</span> <span>to</span> <span>the parallel port</span> <span>which</span> <span>is</span> <span>connected to</span> <span>your</span> <span>printer</span><span>.</span> <span>Windows</span> <span>does</span> <span>not support</span> <span>interrupts on the</span> <span>parallel port</span> <span>which</span> <span>leads him</span> <span>to use</span> <span>100</span><span>%</span> <span>of</span> <span>your</span> <span>CPU</span> <span>to</span> <span>your impressions</span><span>.</span></span><br /> <span>The</span> <span>only</span> <span>workaround for</span> <span>this</span> <span>problem</span> <span>is</span> <span>to</span> <span>abandon</span> <span>the</span> <span>parallel port</span> <span>to connect</span> <span>your</span> <span>printer to</span> <span>your</span> <span>PC</span> <span>and</span> <span>instead use</span> <span>the</span> <span>USB</span> <span>port</span><span>.</span> <span>We must</span> <span>make sure your</span> <span>printer</span> <span>supports this</span> <span>connection type</span><span>.</span><br /><a href="http://www.fixya.com/AnswerQuestions.aspx"></a>
on Jan 03, 2011 | Office Equipment & Supplies
Cpu fan is locked
The CPU fan if no longer spinning. To confirm this, you need to open the RIP cage cover. If the CPU fan is not moving, check if the CPU fan cable is properly connected to the J-Fan1 on the RIP board. If it not, please connect it properly. If it is connected, you will need a replacement RIP board.
Aug 01, 2012 | Lexmark X502N All-In-One Laser Printer
I am trying to add my new printer. I have a Lexmark Z517. When I go to add my printer I can not find this particular printer. Please help!
if you directly attached your printer to your cpu, then try to re-install the driver, but if you are only aquiring connection from the network then check your workgroup it should be the same with the cpu which the printer installed.
Sep 10, 2011 | Lexmark Inkjet Z517 Photo Printer
Not connect to printer to cpu
1.Take usb cable(along with printer two cables(1.Power2.data/usb cable)
2.Connect usb cable to printer and cpu.
3.Put printer Cd in cd drive.
4.Install / go to start-settings-Printer-Add Printer-select Local Printer-select usboo1-give your cd path-(like e:\)-next-Finish.
5.Now can see in printer page Cannon Imageclass and right click and set as default.
Jun 01, 2011 | Canon imageCLASS MF3240 All-In-One Laser...
Reset 051 fatal error OKI C9600n led printer
Service Error 051: Error
CU fan Error CPU cooling fan of CPU PCB is abnormal.
- Is the connection of the CU PCB Normal?
No - Normally Connect
Yes Replace fan
- Replace and restore fan?
No Replace CU PCB (Must Replace EEPROM)
Jan 25, 2011 | OKI C9600n Led Printer
How does the 3010cn connect to my cpu? I dont have any cables and no port except for a usb port
The Dell 3010cn will connect fine with a standard USB cable to the port on your cpu. Just connect the USB cable up, connect the power cable to a socket and run the installation from the software cd.
Jan 12, 2010 | Dell 3010cn Laser Printer
Cant install my canon 190 printer
Have you check the printer cable thats connect from cpu to printer
Delete all printer driver, access from Start->control Panel->Printer and Fax. Right click to printer icon and delete all printer driver. Turn it off.
Then turn CPU on but not the printer yet.
Then after windows screen completly appears, turn printer on.
If the computer says detect a new hardware, that means a connection
between CPU and printer is fine.
Then instal the software driver from CD. Good luck !
Sep 06, 2009 | HP Photosmart 8250 InkJet Printer
I purchased a new cpu and need to connect my lexmark printer to the new unit. my model number is x2350
Installing X2350 is really an easy task. You just need to connect the printer to the CPU with a USB cable and then install the software on to the computer. You can use the CD that came with the printer to install the software, If you haven't got the CD or misplaced it. You can download the software from Lexmark website. Please follow the link to download the software from the website.
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
please follow the above link and type in X2350 in the "search by model" field. This will take you to the download page where you can download the software. For more details on attaching the printer and installing the software, please click on the following link to download the setup sheets & user guides.
http://www.lexmark.com/publications/pdfs/2007/2300/en.html
Merry Christmas!
Dec 20, 2008 | Office Equipment & Supplies
Dell 946 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
