Question about Orion Televison & Video
We have an orion 2501B TV.no vertical display
We have an orion 2501B TV. Upon turning it on this morning the picture has a problem. There is only a horizontal display of about 1/4 inch in height across the center of the screen. Sound is fine and colors appear to change along the horizontal display. There is just no vertical to the picture. Can I get an idea of what the problem is and approximate cost of repair. The tv was manufactured in 2001 and is hooked up to cable. Thank you.
    Genius:
  • 1,550 Answers
The vertical Ic maybe are damaged and some of the electrolitic capacitors near by
Posted on Jun 30, 2009
  •  Francisco Mauricio G
    Francisco Mauricio G Jun 30, 2009
TV no sound, picture bleached and skewed
model. serial numbers would be helpful.
Apr 19, 2014 | Televison & Video
Toshiba Color TV CF30D50 picture stretched vertically off-screen both at top & bottom - can find no adjustment knob - ??
The vertical sweep output section of your tV has the fault. Replace all the electrolytic capacitors [5 or 6 of them there] at one time. Height to the picture is more than normal is the fault now.
Aug 19, 2012 | Orion1934 19" TV
How do you fix a white horizontal line across top of Orion TV?
Hello eatkinson,
This denotes a problem with the vertical deflection circuit. This is more then likely the result of the vertical coupling capacitor failing. You will need the schematic diagram of the TV to find the capacitor in question. it is located between the vertical output stage and the vertical deflection winding of the yoke transformer. In addition check the continuity of the vertical winding of the yoke transformer this can cause the same problem. In any event the problem is that the vertical deflection signal is not getting to the yoke transformer or the yoke transformer is malfunctioning.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 08, 2009 | Orion1934 19" TV
Two vertical yellow lines
MABE CONTACT ORION SUPPORT FOR MORE INFO
Nov 06, 2008 | Orion STV2763 27" TV
32" Orion LCD TV Model TV-32082C Hello.Hopefully someone could give me an insight to my problem. Switched my TV on this morning and i have a black screen but with vertical grey bars on it. Switch off...
it sounds like a couple of you capasiters went out they are located on each corner of the tv if they are popped up then they need replaced as they are supposed to be flat on top
Nov 04, 2008 | Televison & Video
20" orion tv
Hello mel2003,
This problem is caused by the loss of vertical deflection. Either the vertical output section of your TV or the vertical coupling capacitor has completely failed. In any event you will have to have a TV technician fix this set, BTW I hope you have not been playing the TV with the line on the screen this will burn the TV screen.
I hope this helps
Thank you,
Shuttle83
Jun 16, 2008 | Orion1934 19" TV
32inch orion bad picture
Hii...
I'm absolutly have no idea whit thos tv set ( Orion ) but...your problem looks like mall function at the vertical circuits....can you see the ic or transistor nearst the FBT ? or you can type all the ic number/type and the Chassis of the tv set olso the Transistor around the Fly Back Transformer ?!
I hope it's can help you..
Hear from you soon
Thank's
[Vrya] be_cek@yahoo.com
Feb 23, 2008 | Orion1934 19" TV
Picture problems
Bad electrolytic cap(s) in vertical deflection section.
Nov 21, 2007 | Orion STV2763 27" TV
Televison & Video Logo
130 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
