Question about Panasonic Palmcorder PV-GS9 Mini DV Digital Camcorder
My camers keeps on asking me to "press the reset switch" and reseting does not seems to fix any problem for me.
  • 62 Answers
I found the fix. It's so easy.
Take out the battery
When it says hit the reset button, hit the reset button.
Turn the camera to off
Wait 2 minutes
Put the battery back in.
Turn on the camera. It won't say reset anymore.
Posted on Aug 04, 2009
  • aidan232
    aidan232 Oct 18, 2012
    in what order please?
  • aidan232
    in order please? like in what order?
How do I reset Irulu V1 smartphone . It keeps asking for pin # but I never had one. I always used a pattern. Anyway a factory pin or hard reset plesse...
Make sure phone is switched off. Then press the volume up button and keep it pressed while pressing the power on button. Keep both buttons pressed until phone starts in utility mode. then you can use the volume button and power button to choose from the options.
Mar 15, 2016 | Cell Phones
Keeps asking me select user, then it restarts again
Reset it. and follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
·3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Dec 09, 2013 | Horizon T203 Treadmill
I have forgot lock code of 5233 can u plz help me
Just master reset your mobile by pressing call key,callend key camers keyand switch onoff key at the same time,note: this process will reset your phone so make the back up of phonebefore swith off.and remove the memory card.first swith off the phone and do this process
Apr 17, 2013 | Nokia 5233 Mobile Phone
TV will not remember settings Sony Bravia KDL 40S4011
Probably you are in "shop" mode of TV. Try to reset your TV and go through initial setup. Most important - choose "home" instead of "shop" when asked during initial setup. Resetting - keep up arrow pressed and switch of TV. Keep the button pressed when TV automatically switch back on. This will reset TV to factory defaults.
Apr 17, 2010 | Sony BRAVIA KDL-46V3000 Television
I have a Sony cybershot dsc-w55 and the screen in dark.
Some Sony cameras have a actual reset button...it would be mentioned in your owner's manual. If your's does not, try a manual reset. Remove the card and battery. Press all the buttons. Insert the card and then the battery and turn it on. This may not fix your blank screen.
Sep 04, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
It keeps on taking pictures over and over!
Hello totzz:
It seems that this camera may have a stuck button or a shorted circuit.
See if you can get to any menu options. Reset all, if you can. Then test it.
Sep 15, 2008 | GE A730 Digital Camera
Press the reset switch
Same "Push the reset button problem in panasonic gs 200 camera. i turned it upside down but it didnt worked out. its an expensive camera please please please tel me how to fix "Press the reset switch" problem
Dec 26, 2007 | Panasonic NV-GS11B Mini DV Digital...
EXILIM EX-760
Try resetting the camera. If that doesn't work then it is a repair issue.
In picture taking mode press menu
go to setup
go up to reset
press right arrow
highlight reset
press set
If that doesn't work then send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Nov 20, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
The camcorder keeps saying press the reset switch
no solution as yet mine did exactly the same and i lost all of my information on the disc. Suggest remove battery and open in record mode, camcorder will say error with information and ask if you like to repair disc, press yes and continue as normal!
Jun 07, 2007 | Panasonic VDR-D100 DVD Camcorder
Panasonic Palmcorder PV-GS9 Mini DV Digital Camcorder Logo
1,003 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
