1998 Opel Astra 1.8 Logo
A
Anonymous Posted on Aug 05, 2014
The engine light error indicator stays on on the dashboard display
Please explain what the enjine light mean when it shows on the dash board display
Louis Mason Thomas
Level 1:
New Friend:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Mar 04, 2015
Louis Mason Thomas
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
17
Questions
Helped
7114
Points
36
If it FLASHES, it means IMMEDIATE attention
robert wales
Level 3:
  • Opel Master 4,977 Answers
  • Posted on Aug 06, 2014
robert wales
Opel Master
Level 3:
Answers
4977
Questions
0
Helped
1332451
Points
59541
It means there is a code in the computer that needs to be checked and repaired in order to turn off the light.
1helpful
2001 Buick Legal LS dash board mileage light is very dim, the svs light and antilock light stay on
If the dashboard mileage light on your 2001 Buick Regal LS is very dim and the Service Vehicle Soon (SVS) light and antilock light stay on, there could be a few potential causes for this issue. Here are some things you can check:
  1. Dim dashboard light: If the dashboard mileage light is very dim, it could be due to a burnt-out bulb or a problem with the dimmer switch. Try turning up the brightness using the dimmer switch, and if that doesn't work, check the bulb and replace it if necessary.
  2. SVS light and antilock light: The SVS light and antilock light staying on could indicate a problem with the car's computer system or with the antilock brake system. It could be caused by a faulty sensor, a wiring issue, or a problem with the computer itself. It's recommended to have the car's computer system scanned for error codes to determine the root cause of the issue.
  3. Battery or charging system: A weak battery or faulty alternator can cause electrical issues in the car, which could be related to the dim dashboard light and the warning lights staying on. Have the battery and charging system checked to rule out this possibility.
1helpful
4answers
My dashboard light of a cog with exclamation mark in has come on what does it mean
This is NOT a Tyre pressure sensor warning!
Don't know why people post this when they haven't got the foggiest idea.
It is a fault associated with the drivetrain which includes from the injectors on the engine to the transmission and possibly just a sensor malfunction.
There are multiple errors possible with this fault.
Requires a diagnostic OBD2 port analysis of the ECU to clear the fault codes and further analysis.
What would cause the enjine light to stay permanently on
You need to have your car hooked to a scan tool, it will tell you what the computer thinks the problem is.
My dash bored wont stay lite at night with my lights on in my 1992 Buick
There are few help links provided to resolve this issue of dash board light not working.Click the link below to go through its procedure:-----Dash board lights not working? http://repairhelpcenter.blogspot.in/2012/02/dash-board-lights-not-working-on-gmc.html
----------- light in the dash blinks? http://repairhelpcenter.blogspot.com/2012/01/overdrive-light-in-dash-blinks.html
-----------Orange O/D warning light flashing on dash? http://repairhelpcenter.blogspot.com/2012/01/orange-od-warning-light-flashing-on.html
---------gauge on the dash quit working on? http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html---------No 4x4 light on dash? http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
----------Digital Dash Display not working? http://schematicsdiagram.blogspot.com/2011/12/cadillac-seville-digital-dash-display.html
---------warning on dash and alarm sounds? http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
---------Light Stays On dash of car? http://schematicsdiagram.blogspot.com/2011/06/brake-indicator-light-stays-on-dash-of.html
----------The ABS and Traction Control Lights stays ON dash of car? http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
----------warning lights remains steady on dash? http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
---------light bulb under dash replacement?
http://schematicsdiagram.blogspot.com/2011/12/heating-knob-light-bulb-under-dash.html
Parking lights, tail lights and dash lights not working? http://technoanswers.blogspot.com/2012/01/parking-lightstail-lights-and-dash.html
How to replace Instrument panel and dashboard?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-instrument-panel-and.html
Tail lights and dash light fuse keeps blowing? http://technoanswers.blogspot.in/2012/02/tail-lights-and-dash-light-fuse-keeps.html
This will help.
Thanks.
1998 Plymouth Grand Voyager.........Dashboard instruments quit working and don't light up. Speedo, tach, fuel gauge, temp gauge, and mileage indicators and lights for same stopped working. ABS...
You have some wiring problems shorting out that is coming from the dash board so if you or anyone you know how to use a multimeter to check the wireing harnesses plus check any connectors that might be just very touching the connector of dashboard which means a bad connection to dashboard.
5helpful
2answers
Where do I find the meaning of various lights on the dashboard?
hi, all lights the first and important battery light this shows RED when the alternator NOT carging:
the oil light shows ORANGE LOW on oil:
the engine managment light shows when engine sensors detect faults shaped like an engine ORANGE light
head main beam BLUE when ON MAIN BEAM
indicator FLASHING GREEN light
hazard warning RED light
brake fluid low light RED looks like this ( )
brake handbrake ON RED light looks like this ( )
side light GREEN looks like a star
most of the important lights are RED or ORONGE gerry
1helpful
What does it mean when the dashboard indicator
that is your 'check engine' light.if it stays on, one or more sensors on your engine has sent a 'trouble code' to the on-board computer.a diagnostic code reader needs to be connected to it to determine the cause.
6helpful
Our dashboard light symbol that looks like the sun stays on
if its yellow and on the tachometer side of the dash it means you have a burnt out bulb.
16helpful
3answers
Ford transit van dashboard display not working
ive got a 55 plate 85 T260 swb crewcab 68000 miles, , i bought it 12 months ago, red light flashes on dash board most days, some times arratically, sometimes quite slow, and all clocks, speedo and dash does not work?????????
the smallest scratch and the van rusts, no under seal, there just a use it and dump it van.
i would just like to say fords are ****
Top Opel Experts
NOEL
NOEL
Francois Havenga
Francois Havenga
Are you an Opel Expert? Answer questions, earn points and help others
