Goodman package unit model number
Ever heard of a goodman package unit model #TGJ042100-1a?
    Sergeant:
  • 340 Answers
Nope! whats the problem
Posted on Jun 30, 2009
I just installed this unit and can not get the blower to run
Seriously depends on what unit you have. Model # & serial #? You can "jump" R to G at the unit. If its a standard Goodman AHU there may be a terminal block or just some wires that were factory installed outside of the unit. R to G will send 24v to the blower relay, sequencer or board (depending on model) energizing the relay and then returning to common. If you have tried that you should ensure you have proper line voltage 220-240vac. at the service breakers on the AHU.
May 18, 2015 | Goodman Manufacturing Goodman GPH1330M41...
Goodman package unit heat strips will not turn on
Put meter probes at in put terminal of the element if you read 220volts that mean your relay is good. if you got it there use amp meter on one leg of that element. You should read some amp draw there but if there is no amp draw it mean the element broke.
Nov 29, 2013 | Goodman Manufacturing Goodman GPH1530M41...
I need to know where 3 wires connect on a goodman pc036-1b rev e package unit air condtioner and central heat system.
Contact Goodman directly to request a wiring diagram for model pc036-1b, rev. e. It is important to specify rev. e.
Nov 01, 2017 | Heating & Cooling
How to wire high voltage goodman straight a/c package gpc1324 unit with 8kw heat kit
do any one have a old package unit is a goodman i want to see were heater on that package uint or take picture of that unit so i can see where the wire go at the heat
Aug 17, 2012 | Goodman Heating & Cooling
I have a 2.5 ton ac outside. the indoor unit downstairs in the basement is a goodman. a new a coil was put in about a month ago. which is a goodman product. ive heard goodman is not a good product. a
the inside coil and outside unit should be matching in tonages another word if you have 2.5 ton outside the inside sould be the same. it don't matter what brand name or who made it.
Aug 04, 2012 | Goodman CKL36AR36 Air Conditioner
Hi I have commercial hvac goodman unit and trying to change my filter, but i have no idea where the filter is located. the model number is GPG13480903AB
On this package unit, there are no places for filters inside the unit itself unless a technician rigged something up to accept one, but not a common thing at all. These units will use filter return grills inside the building. They are usually 2x2 grills on a dropped ceiling grid or could have a filter grill located right off the return plenum from the unit. Either way, it should be inside somewhere and easy to access. Hope this steers you in the right direction and good luck!
Aug 24, 2010 | Goodman Heating & Cooling
I'm trying find out if my old goodman unit was a
Hello WESLEY The unit mod# is 3 ton.If the inside part has an 048 number means together it produces 3.5 ton.If inside is 036 it is 3 ton together.If it is a split.If it is a package it is 3 ton.
Aug 02, 2010 | Goodman Heating & Cooling
Need wiring schematic for a goodman 4ton unit model #mle48-1b
There should be one packaged with the unit. Shut off the power and open the metal enclosure around the control board.
--W/D--
Aug 18, 2009 | Goodman Heating & Cooling
Keepe shutting down the heat.
Mark is right 5 tons is way too big and you are probably icing up. Even here in Az we size units to no less than 500 sq. ft. per ton and more like 700 sq. ft. per ton. What is the make and model number of your unit? I'm a Goodman Authorized Contractor so I should have most info on hand.
Feb 13, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
